Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 Yes you can use the same version of companion for both radios. You just set up a profile for each. Obviously you have to be careful to use the right backup file for the right radio etc, but that's not difficult. Quote Link to comment Share on other sites More sharing options...
MattyB Posted July 18, 2018 Share Posted July 18, 2018 There is one additional reason to go to OpenTX that shouldn't be underestimated - if you do have a problem with FrOS there's only a tiny number of people using it who can help you. I know multiple X10 and X12 owners as well as 50 or 60 X9D owners (which of course can only run OpenTX); literally none of them use FrOS. Contrast that with OpenTX, where the pool of information online is absolutely huge (especially at OpenTXU, RCGroups and Youtube). Most clubs also have at least one or two users you can talk to in person. Both systems are necessarily more complex than a basic 6ch "big brand" TX complex (you couldn't have all that cool functionality without some additional options to choose from), but only one has a huge, vibrant end user support network to help you when you need to improve your understanding. Edited By MattyB on 18/07/2018 10:40:14 Quote Link to comment Share on other sites More sharing options...
Caveman Posted July 18, 2018 Share Posted July 18, 2018 Just to add my thoughts.... I'm a Taranis user and I do most of my model setup directly onto the tx, not because I'm against using the Companion, but at the field it's much simpler to make amendments and adjustments without having to resort to a PC. I'm not so sure that I'd find it easy to find my way round the tx menus if I wasn't familiar with them. GDB Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 School boy error, I need to buy an sd card today but did t look what size I need...can anyone tell me what type and storage volume I need ? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 I have a 16Gb micro SD in mine. Probably overkill on size. PS mine is an X12 but I'm assuming X10 will be the same.Edited By Chris Bott - Moderator on 18/07/2018 12:00:57 Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 Cheers mate, much appreciated! Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 Just connected it up to try and back up the system and my lap top wont see the x10..... its a new lap top running windows, great start! Quote Link to comment Share on other sites More sharing options...
trebor Posted July 18, 2018 Share Posted July 18, 2018 I've got this to look forward to I've had my Taranis over a year now and never updated it or used companion. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 Ok is there a section in the upgrade document covering using Zadig to replace the usb driver? (Careful with Zadig, do NOT use it with TX connected to PC while switched on) Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 haha well we can both struggle, read, watch and annoy the guys on here with endless questions haha Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 Yep Flashing instruction paragraph 7 tells you all about Zadig. Before this it hasn't told you to connect Tx to PC. So you're jumping the gun. It's important to follow the instructions. Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 ive plugged my x10 in to the usb port, the cable icon is on the radio screen but its not showing up on my computerr, any ideas why? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 Yes I think it's because you haven't done as I suggested above.Edited By Chris Bott - Moderator on 18/07/2018 20:36:21 Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 whats Zadig? Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 got it! its a driver booy thingy! Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 For some reason the FrSky hardware and Microsoft don't play perfectly together. You'll find that every now and again, with a Windows update, Microsoft will think it knows better and will pick the wrong driver again. So when you have these symptoms again, just go through the Zadig process again. As detailed in that instruction sheet. Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 ok cool, ill give it another go tommow, this softwear better be worth all the faffing about! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted July 18, 2018 Share Posted July 18, 2018 I did all the Zadig interface stuff to use Companion but, to be honest, I do all my model set ups on the transmitter as I did with my Taranis and my Mutliplex 3030 before that. On the Horus it's very easy to use and it means I check it on the actual model as I'm setting up. What I do on my PC is backups and images from photos of my models which is fun but not absolutely necessary. Geoff Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 18, 2018 Author Share Posted July 18, 2018 That’s interesting, so am I right in thinking I can put open tx on the sd card and not actually have to connnectvthe radio to the computer at all ? I’ve been faffing and read so much info I can’t make heads or tails of it, I think I’ve just confused myself 😂 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 18, 2018 Share Posted July 18, 2018 No you can't. What you need to do is stop guessing and do exactly what the instructions say. That's why they were written and you can get in a real mess if you don't Sorry if I sound like a broken record, I won't mention it again but you're on your own if you try to make it up as you go along. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted July 18, 2018 Share Posted July 18, 2018 Sorry if I was being confusing, as Chris says, you need to do the interface for backup etc. Just follow the instructions and all will be well. They are very good and extremely helpful. Geoff Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 19, 2018 Author Share Posted July 19, 2018 No that makes sense, I’m terrible at following instructions but I’ll follow to the letter! Quote Link to comment Share on other sites More sharing options...
trebor Posted July 19, 2018 Share Posted July 19, 2018 I'm still waiting for mine, it's gone on a summer break and spent nearly 24hrs at Heathrow Airport Quote Link to comment Share on other sites More sharing options...
r6dan Posted July 19, 2018 Author Share Posted July 19, 2018 now im really confuzzled hahahaha i got a pm off Mike Dailey, one of the the chaps who writes all the how to guides on open tx site who actually said he doesnt bother with it on his Horus x10 as the new frsky OS on it is so good!! Quote Link to comment Share on other sites More sharing options...
trebor Posted July 21, 2018 Share Posted July 21, 2018 I am a bit disappointed with the case as the switches are right under the lid, for the sake of an extra 10mm and some padding I really wanted the alloy case but the price put me off Quote Link to comment Share on other sites More sharing options...
