Andrew Moore 7 Posted July 27, 2018 Share Posted July 27, 2018 General but basic question (new to hobby):- I'm about to put a different IC engine in one of my models (OS 46 to OS 55). Do I have to worry about thrust angles ? I suppose what my question is really is are there some sort of down/right built into most models (Firewall ?) or all engine mounts ? I will be using a new radial engine mount as the OS 55 wont fit my existing mount. When I look at existing motor/mount it looks fairly straight with little or no down & right thrust already there. Do I need to be concerned ? Quote Link to comment Share on other sites More sharing options...
Kim Taylor Posted July 27, 2018 Share Posted July 27, 2018 I'd say if it flew ok as it was, then don't worry, just fit the new engine exactly as the old one came out. Can always be adjusted at a later date, if necessary. Just my opinion, mind - others mileages may vary!!!!!!!!!! Kim Quote Link to comment Share on other sites More sharing options...
Jon H Posted July 27, 2018 Share Posted July 27, 2018 most artf models have it all built in for you. Kits/plans tend to have the angle noted and expect you to build it in. In your case with only a small power upgrade i would just leave it alone Quote Link to comment Share on other sites More sharing options...
J D 8 Posted July 27, 2018 Share Posted July 27, 2018 Easy enough to adjust radial mount if needed with washers between mount and bulkhead. As Kim says though if it was good before leave it alone. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted July 27, 2018 Share Posted July 27, 2018 The mount itself will (should!) have no offset or angle. As said, leave existing setup as is, it will be ok. Quote Link to comment Share on other sites More sharing options...
