Nick Stock 2 Posted August 13, 2018 Share Posted August 13, 2018 I've been working on the tail section of this kit - planing and sanding to necessary profile. I just have some tidying to do before glassing the Horiz stab and covering the elevators before final assembly. I plan to cut my own control horns by hand from pre-cured carbon fibre sheet. Can anyone advise on my current design (pictured below) - whether long enough hence resultant pushrod travel or else? Thanks Nick Edited By Nick Stock 2 on 13/08/2018 10:30:54 Edited By Nick Stock 2 on 13/08/2018 10:43:58 Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 13, 2018 Share Posted August 13, 2018 Im sure it would be plenty. You certainly wont be using 20 degrees deflection so i cant see a problem with this. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 13, 2018 Share Posted August 13, 2018 Looks good to me. I make it 20 degrees when: 1. Servo travel is 50 degrees 2. Servo horn attachment is 15mm from centre of servo disc. I assumed the elevator is about 25mm thick, ie total hinge to linkage is (1/2 x 25mm) + 19.5mm. Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted August 13, 2018 Share Posted August 13, 2018 Just a thought. Is the elevator hinge point really where you show it in the diagram? Aren't they normally hinged at the centre of the circle that forms the radiused leading edge, rather than at the leading edge itself? If so, that would affect the geometry of your diagram. Edited By David Ovenden on 13/08/2018 13:41:05 Quote Link to comment Share on other sites More sharing options...
Nick Stock 2 Posted August 13, 2018 Author Share Posted August 13, 2018 Thanks you both. Together with this and Tim's Seagull Model Hurricane setup, I committed to a vertical distance of 25.4mm/1" from lower surface of the elevator to the hinge point. This I hope will err on the side of 'big servo arm movement = less control surface deflection' which I understand is vital to warbird setups - particularly Spits. Quote Link to comment Share on other sites More sharing options...
Nick Stock 2 Posted August 13, 2018 Author Share Posted August 13, 2018 Posted by David Ovenden on 13/08/2018 13:35:26: Just a thought. Is the elevator hinge point really where you show it in the diagram? Aren't they normally hinged at the centre of the circle that forms the radiused leading edge, rather than at the leading edge itself? If so, that would affect the geometry of your diagram. Edited By David Ovenden on 13/08/2018 13:41:05 David good point - perhaps in the actual full size the hinge point was/is some distance within the leading edge. However my Robart hinges have their hinge points effectively dead in the middle between the outer most part of the leading edge and the trailing edge of the horiz stab, perhaps at most within a few mm. So I take the view now that as long as I'm in the right ball park, I can adjust surface deflection with the position of the pushrod at the servo end (inwards or outwards) and then fine tune with my transmitter (end point). N Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 19, 2018 Share Posted September 19, 2018 Nice bit of carbon cutting there too Nick😊 Quote Link to comment Share on other sites More sharing options...
