Rocker Posted September 16, 2018 Share Posted September 16, 2018 Just brought a Saito FA 125a engine .They recommend using Saito Glow Plugs ,surprise ,surprise .They are not easy to get but I am sure the OS F Type glow plug would be OK .What glow plugs are other people using on there Saito FA 125.Must say this is the first Saito I have brought and I am well impressed .Still have to run it in but well happy with it Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 16, 2018 Share Posted September 16, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted September 16, 2018 Share Posted September 16, 2018 My 72 appeared to run better on an OS F. BTC Quote Link to comment Share on other sites More sharing options...
John Stainforth Posted September 16, 2018 Share Posted September 16, 2018 OS F works fine in Saito 125. Spend time to really tune the engine well, getting the low end right. You know when you've got it right, because the revs do not change when you remove the glowdriver, and transition smoothly right across the range from slow idle to flat out. Also the fuel consumption is remarkably good when the engine is optimally tuned. Then you don't really have to touch the settings much, ever again. Quote Link to comment Share on other sites More sharing options...
Subalib Posted September 16, 2018 Share Posted September 16, 2018 Rocker I have a Saito 125 and it has run happily on an OS 4 stroke plug for years. Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted September 16, 2018 Share Posted September 16, 2018 Another vote for the OS F plug. Mine runs happily on 5% though. Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted September 16, 2018 Share Posted September 16, 2018 Used the Saito plugs to put a couple of tanks through my 82's, then swapped to OS F. Immediate and vast improvement, highly recommend the OS F. 12% nitro in mine run really well. Edited By Richard Wills 2 on 16/09/2018 18:49:20 Quote Link to comment Share on other sites More sharing options...
