Peter 'Ivanna Crashalot' Savage Posted March 12, 2010 Share Posted March 12, 2010 Bottom sheeting And again! Pushrod snakes Tail wheel mount! All together! The tail fairing Fin from the side The wheels and the servos Heres my CUSTOM glue holder for cheap unstable glue pots Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 13, 2010 Share Posted March 13, 2010 Looking very good indeed. Looking forward to seeing the finished model Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 13, 2010 Share Posted March 13, 2010 Is there meant to be two C2s? on in 1/32 ply and one in 1/8th? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 13, 2010 Share Posted March 13, 2010 I f you look at the picture in the article you will see that F-1a is the same as C-2 but is used to face F-1. THis seals the eadges etc. Then the cowl is built on C-2. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 13, 2010 Share Posted March 13, 2010 Ah right, I don't have any thin ply, can you see any problems in doing f1a in 1/8th liteply? I will do this on 35mhz, just need to make sure I put the aerial up! Edited By Peter 'Servo Scrounger' Savage on 13/03/2010 18:44:18 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 13, 2010 Share Posted March 13, 2010 You might as well leave F-1a off. but I suppose you can use 1/8" liteply. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 14, 2010 Share Posted March 14, 2010 I think I will put it in, so that when the cowl is off it can't get kinked, I am determined to get it as smooth as a babies' Derrier!!! You can see a sort of fault line, from where i built it before, with less building experience, then on the other side, where I have taken my time and have done a good job Need to repair the switch on the fret saw to make it easier! don't suppose anyone has a spare switch for a draper 20" fretsaw? official spares are long since available! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 14, 2010 Share Posted March 14, 2010 What sort of switch is it. I imagine that it will be a standard type so somewhere like Maplin should have a suitable equivalent. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 14, 2010 Share Posted March 14, 2010 Well it is the speed pot and a push pull switch all in one so I highly doubt they will have one Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 14, 2010 Share Posted March 14, 2010 It is a J-NOBLE U85DR switch, done a search on the internet and no luck Quote Link to comment Share on other sites More sharing options...
Terry Meakin Posted April 7, 2010 Share Posted April 7, 2010 Hi Came across this thread and couldn't resist joining in. I've recently finished my Feugray and am just waiting for some decent weather to first-fly it but thought I'd post a couple of pictures of the finished article. It's powered by a J'en 37 which fits right inside the cowl as you can see with just a small hole for the glow start - a really tidy installation. In the background, the one nearest the Feugrys tail with the Yosemite Sam cartoon on the side is a Lil' Bandit and the tail with blue and yellow rays on belongs to a Cap 21 - along with the white wing with Mudry on top and the red trailing edge. Both are favourite planes of me and my son so can't wait to fly the new one. Thanks Peter. Edited By Terry Meakin on 07/04/2010 20:03:40Edited By Terry Meakin on 07/04/2010 20:05:35 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 7, 2010 Share Posted April 7, 2010 Nice model. I hope you like her as much as the others. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted April 8, 2010 Share Posted April 8, 2010 I think I am going to put a smoke system on mine so I have put a hatch under the fuel tank, I have also put a hatch at the back for any lead I may need to add. Oh and I have finished sheeting the bottom fuse. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted April 24, 2010 Share Posted April 24, 2010 Bit confused as to why C2 at the bottom, is 1/8th wider on each side, is there meant to be a 1/8th inch step at the cowl? i reckon it may be a drawing error because you mention the cheeks are made of 1/2" balsa but it is 1/2" minus the 1/8 spacing. Heres the covering I have done on it. http://vanepicosthename.tumblr.com/post/541395163/heres-the-covering-job-i-am-doing-on-the-plane Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 25, 2010 Share Posted April 25, 2010 C-2 is supposed to be the same shape as F-1 PLUS all the sheeting. In other words when C-2 is placed agains the completed front of the fuselage it should be the same size as that. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted May 19, 2010 Share Posted May 19, 2010 Cracked on, got C2 cut out and screwed to f1a and I am going to get cracking on building the cowling around it Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted May 31, 2010 Share Posted May 31, 2010 This makes it a lot easier to show. Tried to cover the cheeks while they were on the plane but ended up getting annoyed and throwing them across the room in a rage I then carefully ripped them off and covered them seperately I have regained all sanity lost now! Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted June 2, 2010 Share Posted June 2, 2010 Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 2, 2010 Share Posted June 2, 2010 Hi Peter,that engine starts amazingly easily,but it looks like your starting it backwards,I can here when you rev it its not n ice to put a person to a name,hope the cold gets better. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted June 2, 2010 Share Posted June 2, 2010 Nope, it is running the right way, I have to confess, it is noly that easy to start when it is heated up! I don't quite get what you mean by its not nice to put a person to a name, I assume you didn't mean the put the 'not' in! I am trying to become a super popular youtube person *shameful youtube channel advertisement alert* so subscribe if you want to be updated about my videos XD I would have been taxiing it around the garden but the balance is way too far forward for that now, will sort all that out when the wings are done. I have one aileron finished which is what is holding me back, and all the other projects!!! Peter (vanepico on youtube! :P)Edited By Peter 'Servo Scrounger' Savage on 02/06/2010 22:32:16 Quote Link to comment Share on other sites More sharing options...
