Gloster Gladiator fuel tank position
I'm currently building a Gloster Gladiator and trying to work out the best position for the fuel tank.
It will only fit between the firewall and F2 in a transverse position or behind F2 which will place it on the C of G.
The question is is it ok for the tank to be transverse or if behind F2 will the longer fuel run be ok?
If you use a round tank, then use a hole saw to cut the clearance hole in F2. The lack of sharp corners will avoid raising stresses in the remaining parts of F2.
If you use a rectangular tank then make the rectangular cut-out by drilling holes in each corner of the cut-out in F2 and then fretsaw between the holes. The radiused corners of the cut-out will again prevent stress being raised in F2.
