David Pearce 4 Posted July 2, 2019 Share Posted July 2, 2019 I have a Great Planes Mr Mulligan ARTF. The recommended motor is Rimfire 32 with 800Kv and a 12” x 8” prop. That’s a rather expensive, and rare, motor and I’m hoping to use a motor I already own. This is a 900Kv motor which delivers the required 800+ watts using an 11” x 5.5” prop. My question is; will the large fat cowl have an effect on the power and would I be better off buying a new motor, of lower Kv, to swing a large diameter prop? Is that 1” important? (Fitting a larger prop to my existing motor would raise the current too much.) Your advice would be appreciated. Thanks. Edited By David Pearce 4 on 02/07/2019 10:33:14 Quote Link to comment Share on other sites More sharing options...
J D 8 Posted July 2, 2019 Share Posted July 2, 2019 It is often said that 1" more is important. There is often a concern that with radial cowls much of the inner part of the blades is in front of the motor but most of the thrust comes from the outer half of the blade so I think in your case you need to stick with the recommended diameter. Larger prop with less pitch would likely be alright. Edited By J D 8 on 02/07/2019 11:41:09 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted July 2, 2019 Share Posted July 2, 2019 Interesting stuff.......so much so, I have just measured all of my radially cowled models and their props. All three were pretty much 2:1. That is to say the prop was twice as wide as the cowl. The biggest, a 50 cc Gilmore has a 22 X 10 prop and the cowl is 12" across. This would seem to confirm what JD8 has said above. D.D. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted July 2, 2019 Share Posted July 2, 2019 David As a rule of thumb the outer 1/3 of any prop does 2/3 of the work so you need to check the cowl diameter to your 11" prop. As quite a proportion of the prop will be 'blanked' by the cowl you might find a 12 x 5.5 when in place does not actually exceed the motor's current limit. Experimentation and a Watt meter are the order of the day!. Quote Link to comment Share on other sites More sharing options...
David Pearce 4 Posted July 2, 2019 Author Share Posted July 2, 2019 Thank you all for your input. I agree more testing and measuring is required. I'd rather get it right the first time so, if there's any doubts, I may well go for a lower KV motor. Thanks again. Quote Link to comment Share on other sites More sharing options...
