TH Posted July 17, 2019 Share Posted July 17, 2019 Hi Guys, I have to correct my latest bonding error, no, not my wife. Does anybody know a way to break a joint bonded with aliphatic please ? Thanks in advance. Tony Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 17, 2019 Share Posted July 17, 2019 Soaking in acectone, vinegar and water mix will soften it. Steaming will also soften it. Otherwise, it's a fine glue Quote Link to comment Share on other sites More sharing options...
will -0 Posted July 17, 2019 Share Posted July 17, 2019 Soak in water usually works for me. Depends how deep it goes! Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 17, 2019 Share Posted July 17, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 17, 2019 Share Posted July 17, 2019 That, comrade, is going to cost you. I would reduce the damage with an offer of a hairdo, a pedicure ( distraction therapy). Check the terms of your will. Quote Link to comment Share on other sites More sharing options...
john s Posted July 17, 2019 Share Posted July 17, 2019 I'd try steam Jason, just use some protective clothing and gloves to make sure you don't burn yourself. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 17, 2019 Share Posted July 17, 2019 Do not use heat. Aliphatic resin polymerises with heat and then never comes apart. If one applies the glue to bother surfaces and allows it to dry one can then bond them with a domestic iron. I have bonded leading edge sheet to a wing by this method which I learned from an American mag years ago Quote Link to comment Share on other sites More sharing options...
paul d Posted July 17, 2019 Share Posted July 17, 2019 That's interesting Peter, thank you! I presume it could then be used for "iron on coverings" such as litespan? Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 17, 2019 Share Posted July 17, 2019 But when hot, it is plastic. The post asks, how to part a joint. Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted July 17, 2019 Share Posted July 17, 2019 Andy Hardman still had Balsaloc a week or two back. I still can’t persuade him to tell me what’s in Prymol though. BTC Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 17, 2019 Share Posted July 17, 2019 Posted by paul d on 17/07/2019 19:06:18: That's interesting Peter, thank you! I presume it could then be used for "iron on coverings" such as litespan? Possibly.I have never tried that but it sounds logical. I just bought some Balsaloc for something else Edited By Peter Miller on 17/07/2019 21:06:39 Quote Link to comment Share on other sites More sharing options...
