Rob's F-86F NASA 228 research aircraft build
Thanks Guys. The next job was painting the black and yellow sections on the plane same as before. Then, here is what I have been doing with the markings. I decided to have a go myself as (a) this is a model I am learning from and (b) I'm mean! I found the odd markings like the NASA meatball logo on the internet and downloaded the correct fonts for the lettering. I then typed/assembled them on a simple word document changing the size as required. I also found a decal set for an F86 with all the small lettering - it was the wrong scale and cost $150! So instead of using that I grabbed some of the lettering and markings from a pinterest file and then edited them in Photoshop so they would be the right size and colour and print ok. I printed everything out on my home inkjet printer on ordinary paper and cut them up to check the size was right - I tweaked some of the sizes. Then I printed them out onto inkjet decal paper and sprayed this with matt varnish.
The result - not all have been placed yet. This was quite painless actually. I recommend these inkjet decals. There are some issues in that the eagle-eyed will notice that you can't print white so a transparent paper will just show the colour below. You can get white backed decal paper but then you have to cut exactly around every part of the image - not practical for most things. Also any pale colour will show the colour below - however, I have a fix for it. I will try it for the RESCUE arrows which are yellow and see if it works... img_2256.jpg
So here is how I fixed the issue of using transparent decal paper on dark backgrounds. The pictures speak for themselves really. I used low-tack FROG tape to cut out the mask, cheap acrylic art paint brushed onto the model.
Here's the model with all the panel lines and decals added. Just some weathering to do before a final coat of varnish or lacquer. I have a tin of satin varnish here but I will have to brush that on. Or I could get a spray can of acrylic lacquer from Halfords (they are open if you order in advance online) but they only have gloss. I have done a sample and I'm tempted to try the brushing. Any advice?
Also I forgot to mention earlier that I set up the CG and it needed a further 50gms of lead in the front of the battery box - Im just using 4 AA sized Nimhs for my receiver battery. Total weight inc. battery is 1.92kg (4.23lbs)
Thanks for that advice guys. Graham - I had tried to buy the Molotow stuff when I got the paint but it was out of stock and still is - its great paint so I guess it would have been as good. Anyway, I have ordered Halfords acrylic lacquer as Peter suggest - and they have satin too which looks a better match as it says its for spraying over all paints. The gloss says says its for metallics (though Im sure it would have been ok). Im waiting for a little jar of tamiya silver to do my weathering - my old one was empty.
Hi Rob,
Hope you don't mind me jumping in with a short note concerning your 'rescue' decals.
You're right when you state that light colours show difficulties to cover darker ones, like your red fuselage.
Painting a white layer in between, as you did, brings a far better result. But it might be quite fiddly depending on the shape of your decals.
After several tests, the best result I obtained was bringing the water transfer onto thin white self-adhesive vinyl, cutting the needed shape and apply it as a vinyl marking.
Hi-end vinyl like Oracal even has a grey tinted support layer under the white to give a 'shield' to the underlying colour.
It's a lot easier than painting a layer in between. wink
Hope this helps
Cheers
Chris
Thanks Chris - that sounds like another good way to do it.
Im nearly there now. I have done some 'light' weathering, just a bit of silver paint around the scratch points and black paint to form dirt lines.
Edited By robk on 10/05/2020 12:45:31
And here it is finished and ready to go. I reckon it wouldn't have been done without all this enforced 'home' time. Its not going to be the best F86 at the Orme by any means, but I have learned a lot, tried out new processes such as glassing, decals, spray painting so I am glad to have done it. After all the hours put in there will be some butterflies when I chuck it off the edge of a hill - hopefully in the not too distant future...img_2340.jpg
  • 3 months later...
