martin collins 1 Posted July 21, 2020 Share Posted July 21, 2020 I have made a couple of VW like cylinders for the side of my jodel but want to make the dummy exhausts, the front one of which has quite a tight curve as it goes round the cylinder head to then face in the opposite direction from where it came. I tried a bit of black wiring but it won`t stay bent to the radius, any suggestions? Quote Link to comment Share on other sites More sharing options...
Michael Barclay Posted July 21, 2020 Share Posted July 21, 2020 Diameter of pipe? Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted July 21, 2020 Author Share Posted July 21, 2020 1/4" outside diameter......... Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 21, 2020 Share Posted July 21, 2020 I'd go for aluminium tubing bent using a car brake pipe bender after annealing it but if you don't have access to one, model shops stock small bending springs to support the tubing - without something similar the pipe will kink... You might be able to fill it with fine sand and bend it round a suitable former but it may not be easy to get a smooth curve. Edited By Martin Harris on 21/07/2020 18:02:01 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted July 21, 2020 Share Posted July 21, 2020 I had a 3D printed engine for my Magnatilla. but wanted to add some nice bronzed exhaust pipes for effect -I tried some quite thick wire but it didn;t look how I wanted it, then I had a brianwave and found that silicone fuel tube fotted with CA at each end was perfect add a couple of cableties to simulate exhaust clamps. A quick coating of metallic copper paint and it was just the sort of exaggerated cartoon scale rotary engine I was looking for. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 21, 2020 Share Posted July 21, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
