Ernie Posted October 23, 2008 Share Posted October 23, 2008 Hi, Yes, there are some good 35MHz bargains around...ie I can let you have a Futaba RX for next to nothingernie Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 23, 2008 Author Share Posted October 23, 2008 well, im tempted to just start off with a basic tx/rx then maby move onto the one i linked above... what model/price would you think would be decent? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 23, 2008 Share Posted October 23, 2008 I have a 6EX AP 35Mhz Tx on ebay right now here if yo are interested in taking a look to get some idea of what they go for. Quote Link to comment Share on other sites More sharing options...
David McMullan Posted October 23, 2008 Share Posted October 23, 2008 Hi CallumA good place to buy all sorts of good second hand gear is the BMFA Classified Ads section. I've bought from it and had absolutely no problems cos its all modellers on there.Site addy if its allowed www.bmfaclassifieds.co.ukDavid Quote Link to comment Share on other sites More sharing options...
shaun bellringer 2 Posted October 23, 2008 Share Posted October 23, 2008 hi bruce just put bid on you radio gear .looks good. have you any rx with it ? hopefully going to link with my set being the same ,also dedicate it for sim also . Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 23, 2008 Author Share Posted October 23, 2008 am i the only one who is looking at http://www.bmfaclassifieds.co.uk/detail.php?id=69411 and thinking a bit too good to be true? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 23, 2008 Share Posted October 23, 2008 Thanks for that Shaun. I am hanging on to my 35Mhz Rxs at the moment not ready to move to 2.4Ghz. There are lots of cheap 35Mhz Rxs around both new nd second hand. Can you open up your private message link by enabling it in your profile. Then we can message each other without clogging up Callums thread. Please respond using the message member link at the end of this message. Quote Link to comment Share on other sites More sharing options...
David McMullan Posted October 23, 2008 Share Posted October 23, 2008 Hi CallumGreat site!!!! Recommend it 100%.....It's 1000% better than fleabay!!!!! Davidps I just picked up a less than 1 yr old Futaba 2.4GHz 6ex complete for £80 inc next day recorded delivery Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted October 23, 2008 Share Posted October 23, 2008 The 6EX is a sound piece of kit, I have a collegue been flying for over a year on one, only incidents have come from dumb thumb / showing off syndrome. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 24, 2008 Share Posted October 24, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 24, 2008 Author Share Posted October 24, 2008 Looking currently at the http://alshobbies.com/shop/lookupstock.php?pc=4628&Desc=But it says it works with ppm and pcm selectable... what does it mean pcm selectable?... would it be cheaper to get a pcm rather than a 8 ch Futaba FP-R138DP (http://cgi.ebay.co.uk/Futaba-FP-R138DP-8-channel-35MHz-PCM-receiver-RX_W0QQitemZ170272721282QQcmdZViewItem?hash=item170272721282&_trkparms=72%3A1298%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14)? and will that one be compattable?(slightly differant model number to the one that al's hobbies says) Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 24, 2008 Share Posted October 24, 2008 The Rx you link to is PCM and is compatible with the 6EX. PPM Rx are cheaper to buy new and are usually cheaper second hand. PPM and PCM are methods of encoding the Tx signals when they are sent to the Rx. PCM will be better at rejecting spurious signals as will Duel conversion. It will depend on where you fly what will be best for you I use almost all PPM Single conversion (they are cheap) and have little problem with glitching. Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 24, 2008 Author Share Posted October 24, 2008 bidding on an ebay transmitter at the moment, any reccomendations on a good 2nd hand recciver for the Futaba 6EX-PCM . Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 24, 2008 Share Posted October 24, 2008 As standard the 6EX comes with 136F this is cheap and cheerful but works fine for me. I picked one up brand new for £25 recently. Normally with Futaba Rx if it has a P in it it is PCM F for PPM and D for duel conversion. I have used many different Rx from different manufacturers (you can mix and mach with PPM but not PCM) and I have found them all to be acceptable. One of my favorites are Corona micro Rx. Google corona receivers to find suppliers. Quote Link to comment Share on other sites More sharing options...
William Halgarth Posted October 24, 2008 Share Posted October 24, 2008 Hi Callum, just to say im getting on really well with the flyinging wings V-trainer. I got mine with a 2.4 Spekrum 6xi which i also really like. The v trainer is easy to lauch , fly and land. Its fun to fly and strong if the ground bumps into it. Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 25, 2008 Author Share Posted October 25, 2008 Found a Futiba R137F on ebay, fairly cheap, bidding now Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 25, 2008 Share Posted October 25, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ernie Posted October 25, 2008 Share Posted October 25, 2008 Hi Eric, bet that one is not on the spill chick..Hi Callum, Is it new? If not, I suggest you do some pretty extensive testing before you put it up in the sky..You'll get stacks of advice on the forum re. that subjecternie Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 25, 2008 Author Share Posted October 25, 2008 got outbid, so meh... its one of those things where you can find alot on ebay, but getting a decent deal isnt that easy. might try the other adea for 2nd hand. Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 25, 2008 Author Share Posted October 25, 2008 ha ha... someone at the spell-checker central offices should be given a swift slap for that one Quote Link to comment Share on other sites More sharing options...
Ernie Posted October 25, 2008 Share Posted October 25, 2008 Callum can you not stretch to a new Fitubia 2.4 system..That way, you have eliminated a whole bunch of problems...Cook her a nice candlelit meal, and pop the big question..How's about a new radio?ernie Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 25, 2008 Author Share Posted October 25, 2008 ha ha ha. in my bank account at the moment is about £150 left of my overdraft. i realy cant afford a new one... Best i can do at the moment is money for x-mas and see if that can do it... I do have a job atm, so my funds are going up nicely, but still... when you have a 2k overdraft some things are a little more important. Once i have about 300-400 im hoping to start properly thinking about buying a Rx/Tx and model...etc. Currently im just keeping an eye on E-bay and aquiring bits and bobs cheaply. For example: just bought a Futaba G155 Gyro for 99p (+£5 p+p Steep postage, but for 99p on the unit itself i cant realy complain).I know what your all thinking, as a learner I dont need a gyro, but I have an 'project' in mind that i would like to do at some point, and I cannot say no to a £5.99 gyro. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 26, 2008 Share Posted October 26, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Callum Fraser Posted October 26, 2008 Author Share Posted October 26, 2008 not exactly. Quote Link to comment Share on other sites More sharing options...
