Loaded Dice 30 EP
  • 3 weeks later...
After a long wait, I got to Maiden my Loaded Dice 30EP today in chilly but beautiful conditions. Ran 4 batteries through getting close to 10 mins each time. Had to add a bit of down trim but otherwise good. Really pleased with how it performed. Pulls vertically nicely, lovely axial rolls and big loops. Still early days for me to refine my aerobatics but I'm sure this will be a great plane to practice with. Had to clear a low hedge on the landing runs and it floated straight on past the strip, so took a few attempts to bring her in. Landing gear seems nice and strong and ground handling is good, with easy taxying / steering. Dead chuffed with the colour scheme, looks great in the air and the darker red bottom wing contrasts well with the white / yellow uppers. Looking forward to learning what it can do
  • Like 5
Looks very nice Dave.
How do you insert/ retain the battery, can you post a photo showing the battery compartment?
Trying to decide whether to put the battery hatch on the bottom as per the plan or on top for ease of access.
Hi Shaun,
I cut a hatch after shaping the fuselage, then checked the Cg. I needed the battery hard up to the front bulkhead for balance.
I built an open ply ramp for the battery to sit on against a small strip of dense foam at the bulkhead, and CA'd a reuseable tie strap around the frame. Unfortunately I cut the hatch a bit short so the battery is a squeeze to get in and out.
A top hatch would be easier but the plane is small and light so is easy to turn over. A bottom hatch keeps the nice looking lines of the fuz uninterrupted and I find turning over encourages me to check all the control horns, clevis nuts and servo arm screws before each flight. (found one loose yesterday).
Hopefully the photos show what I meanBatt3.thumb.jpg.8a08ee0c62b692fc9db70736f3717879.jpgBatt1.thumb.jpg.d095465c2d8b39aa226a134a5b23a7a3.jpgBatt2.thumb.jpg.ce659cc8e770ff6a38eda768624ef9b2.jpg
