martin collins 1 Posted May 8, 2021 Share Posted May 8, 2021 With retirement now looming large there are many aircraft i would like to build but there are no plans available to use. I have seen some wonderful creations produced from 3 view drawings, how do you go about doing that? Looking at using foam and depron to keep the cost (and weight) down, any help or links to helpful web sites appreciated.................M Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted May 8, 2021 Share Posted May 8, 2021 What takes your fancy, depron is so cheap and quick to build, the SU 27 prop in slot is easy to build and fly for a starter, but a bit noisy from the slot recently built a Sunderland, F4 Phantom , Li.ghtning and TSR2 , all from outlines to give angles and propoortions. All from depron and blue foam A good site for ideas online is SEMFF, South East Michigan Foam Fliers , hundreds of plans for free Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted May 8, 2021 Author Share Posted May 8, 2021 Mostly WW2 stuff, Italian and Japanese, both seriously under modelled...........M Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted May 8, 2021 Share Posted May 8, 2021 (edited) Anything is possible but it depends on your experience and devotion to the project. I assume you have built and flown warbirds as that is your interest, and I do not include ARTF in the build category. Have you tried modifying any of your machines? If you have done the above, then go for it as you probably will have the knowledge required. Next issue is finding enough reliable data and pictures to formulate a plan from. Be wary to try and create from one source as a lot of machines got modified during their lives so a later version may not look like the original version. Good luck Edited May 8, 2021 by Andy Gates Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted May 8, 2021 Author Share Posted May 8, 2021 Answer is yes to all the above, not an ARTF person, built from plans, kits and have adapted models to suit, also converted many glow models to electric. Will choose a plane and bring it to the forum for some more advice. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted May 8, 2021 Share Posted May 8, 2021 Here is a link to one I made. http://www.amgwebsites.f9.co.uk/faireygordon.htm Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted May 9, 2021 Share Posted May 9, 2021 Hi Martin, if you search My late lamented Seafury in the search panel you will find a build of mine using Depron foamboard and balsa. I scaled the plan x5 from a scale drawing of a 60 powered Seafury. I used the former outlines but changed the construction totally, the formers were enlarged on my printer the fuselage side view was drawn out on wallpaper lining paper, cost about £2 a roll. Depron may be the problem now as it is not easy to find and the places that do sell it are asking more than the current price of balsa. I am going to cover the next model I make by this method with Maker foam, it is relatively cheap at £4 .25 for a sheet 40"x30" it is thicker than depron 3/16" as opposed to the 1/8" depron I covered the Seafury with. Just have to reduce the size of the formers to suit. Quote Link to comment Share on other sites More sharing options...
