Don Fry Posted August 9, 2021 Share Posted August 9, 2021 (edited) David, the designation “plug” tap is also known as an intermediate or second tap. In France these are the terms I see used. Be aware, the taps you see in economy sets of taps are usually taper, or first taps. I have checked, I have not got a 4mm plug, and I suspect most casual tool users only buy a plug if the need it for a job. Wurth tools, good stuff, available in France, called it this, “TARAUD MAIN, TARAUD INTERMÉDIAIRE HSS, DIN 352” you only need the tap. Your engineer friend wii have a handle to screw it with. Edited August 9, 2021 by Don Fry Handle info. Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 9, 2021 Share Posted August 9, 2021 Given the nature of the job, you could probably get away with grinding the end off a normal tap. Its a bit of a bodge, but to tap one hole in aluminium you would get away with it. Quote Link to comment Share on other sites More sharing options...
David Davis Posted August 9, 2021 Author Share Posted August 9, 2021 Thanks for the advice gentlemen. I'll give it some thought. Jon pm sent. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted August 9, 2021 Share Posted August 9, 2021 40 minutes ago, Jon - Laser Engines said: Given the nature of the job, you could probably get away with grinding the end off a normal tap. Its a bit of a bodge, but to tap one hole in aluminium you would get away with it. Cheers Jon, that is good to know Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 9, 2021 Share Posted August 9, 2021 Unless you take up Jon's offer of supplying a modified bolt, just be very careful that the replacement is a suitable length and doesn't bottom in the hole when you tighten it or you may split the housing or leave the head tightened unevenly. At least being machined from billet, the material should be less prone to fracturing than a typical cast crankcase... Quote Link to comment Share on other sites More sharing options...
David Davis Posted August 10, 2021 Author Share Posted August 10, 2021 I have taken up Jon's offer. Quote Link to comment Share on other sites More sharing options...
