barryt Posted September 23, 2012 Share Posted September 23, 2012 Thanks Graham, I appreciate your advice. I am flying some aeros, practicing inverted circuits at the moment. I am not finding it easy to return to straight and level flight after the aeros without setting my throttle to the trim speed for level flight. I am self taught so i don't really know if i should be retrimming continuously. My model noteably climbs with excess throttle and sinks with insufficient throttle. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 23, 2012 Share Posted September 23, 2012 That sounds like a thrust line problem rather than trim. If it's a conventional model then try to angle the propeller shaft down a bit - washers under the appropriate motor mounts can achieve this. If it should be a high mounted above wing motor then you may need upthrust - the same but angling the thrust line up a bit. It's all about how the thrust acts in relation to the centre of lift... The key is a little at a time until your model doesn't pitch excessively with changes of power - pulling up into a slight climb at full power is the aim for a training/scale type model and neutral changes for an aerobatic one. Edited By Martin Harris on 23/09/2012 16:04:52 Quote Link to comment Share on other sites More sharing options...
PatMc Posted September 23, 2012 Share Posted September 23, 2012 Barryt, your model may just be a bit nose heavy. Try moving the cg rearwards in small increments. Add a little weight to the tail (or remove some nose weight) re-adjust the elevator for straight & level. If the nose still pitches up repeat this until either the nose pitching up is minimal or the model becomes uncomfortable to fly because the cg is too rearward. Quote Link to comment Share on other sites More sharing options...
Rex Keene Posted September 26, 2012 Share Posted September 26, 2012 I'd thought about putting a 7.4v LiPo in my Dx6, but was worried that it'd be an over voltage. Can you confirm the unit can stand the larger battery? Quote Link to comment Share on other sites More sharing options...
