Tony Harrison 2 Posted October 26, 2021 Share Posted October 26, 2021 I can shop around for myself, of course, but right now I'm after some lightweight wheels around 100mm diameter - three required. They don't need to be flash, just acceptable quality/appearance and not too expensive. Any recommendations? Thanks, Tony Quote Link to comment Share on other sites More sharing options...
Brian Sweeting 1 Posted October 26, 2021 Share Posted October 26, 2021 Don't know what you want them for but at that diameter then childrens kick scooter wheels made the grade for my recent home built land yacht, complete with ball bearings. Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted October 26, 2021 Share Posted October 26, 2021 The SLEC ones are reasonably light for an airwheel. Much nicer than a foam wheel, I have not compared weights directly but they are not heavy. https://www.slecuk.com/wheels/wheel-with-grey-hub Similar available from other model shops. Quote Link to comment Share on other sites More sharing options...
Martin Dance 1 Posted October 26, 2021 Share Posted October 26, 2021 Thinking around Brian's suggestion try B&Q or a good local hardware/ironmonger shop. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted October 26, 2021 Share Posted October 26, 2021 An RC sand yacht, now there's an idea... Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 26, 2021 Share Posted October 26, 2021 Picture shows a 100 mm HK foam wheel. It’s good on 4 kg hacks. They are 28 g a wheel. If in a 4 kg hack sleeve the hub with a brass tube. They wear, but slowly. Cheap as chips. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted October 26, 2021 Author Share Posted October 26, 2021 Gentlemen, thanks - I should have said the wheels were for a high-wing trainer weighing around 5-6 pounds. The standard as-fitted wheels are about 60mm and I think they're too small for a rather lumpy grass field. Will check out those SLEC wheels, Dad, and the HK ones Don. rgds Tony Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 26, 2021 Share Posted October 26, 2021 Slec grey hub air wheels for me as per dad_flyer's post. JP sell some that look identical, in white. Seem to last for a very long time and don't decompose when exposed to a two stroke. My experience, those lightweight foam ones get a bit soft and soggy in glow models. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted October 27, 2021 Author Share Posted October 27, 2021 11 hours ago, Nigel R said: Slec grey hub air wheels for me as per dad_flyer's post. JP sell some that look identical, in white. Seem to last for a very long time and don't decompose when exposed to a two stroke. My experience, those lightweight foam ones get a bit soft and soggy in glow models. Thanks Nigel - the plane in question is electric, so no fuel-decomposition problems. I don't know who "JP" refers to...? rgds Tony Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted October 27, 2021 Author Share Posted October 27, 2021 13 hours ago, Dad_flyer said: The SLEC ones are reasonably light for an airwheel. Much nicer than a foam wheel, I have not compared weights directly but they are not heavy. https://www.slecuk.com/wheels/wheel-with-grey-hub Similar available from other model shops. I like the idea of air-filled instead of foam, and SLEC has some at 88mm diameter that would suit, at a fair price - but so far as I can see, their postage charges start at a basic five quid... rgds Tony Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2021 Share Posted October 27, 2021 "JP" = J Perkins, e.g. these https://www.pegasusmodels.co.uk/product.asp?type=&dept=5&maingp=Aircraft&prodid=1008104 Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted October 27, 2021 Author Share Posted October 27, 2021 (edited) 23 minutes ago, Nigel R said: "JP" = J Perkins, e.g. these Thanks Nigel - I took a look. They're foam wheels, like most, and I like the idea of those air-filled ones that SLEC sell. They just confirmed to me their postage - I think a fiver minimum p&p is too much given the low cost of the wheels, though. Seems I can buy three foam wheels 95mm dia on Ebay from HK for a tenner incl p&p... Anyway, these recommendations are informative, much appreciated. rgds Tony Edited October 27, 2021 by Tony Harrison 2 forgot something Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted October 27, 2021 Share Posted October 27, 2021 (edited) Sussex Model Centre have similar usually. Something like https://www.sussex-model-centre.co.uk/airwheel-nylon-hub-73mm-3-0-pk2 Edited October 27, 2021 by Dad_flyer Link Quote Link to comment Share on other sites More sharing options...
Brian Sweeting 1 Posted October 27, 2021 Share Posted October 27, 2021 19 hours ago, Rich Griff said: An RC sand yacht, now there's an idea... Rich, I based mine on a plastic pipe model from Andrew Newton from down under. Drainpipe land yacht 1 Quote Link to comment Share on other sites More sharing options...
kc Posted October 27, 2021 Share Posted October 27, 2021 The best source of wheels is probably to take them from an old model! The postage from SLEC would probably cover many more items, and their range of fittings and balsa means they surely would have something else you or a clubmate would need soon. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 27, 2021 Share Posted October 27, 2021 1 hour ago, kc said: The best source of wheels is probably to take them from an old model! The postage from SLEC would probably cover many more items, and their range of fittings and balsa means they surely would have something else you or a clubmate would need soon. I’ve always noticed, fly past, 2 meters up, 5 out, and the wheels always look good, as in round. And that’s a slow pass. Now I spend good money on good wheels, but on nice airframes. Hacks, trainers, they break in the end. Quote Link to comment Share on other sites More sharing options...
