Ronseal diamond hard floor…
r6dan
I know this was used with glass cloth a while ago, anyone using it these days? I’ve got easy-kote but it’s expensive and I’m poor these days lol
this is blasphemy fir me coming from a boat building back ground too but I o my have my kitchen to work in so no epoxy as it’s smelly lol
so… whose using what with glass cloth
I use Easy Composites EL2 epoxy. Using digital kitchen scales, I found I had to use too much to get an accurate mix so I invested in a cheap ebay micro balance to accurately weigh out 10g at a time. I also now use Peep-ply which increases the expense but does reduce the amount of epoxy remaining on the surface, it leaves a much more consistent surface finish and holds down the glass to eliminate voids. Also it has the advantage that only one coat of epoxy is needed.
Use the same process for sheeted foam core wings. I then put them in clothing vacuum bags and pull a vacuum and leave for 24 hours. This produces great results.
Edited by TigerOC
I used to vac bag/breathere/peel ply at work, much better surface finish isn't it
  • Chris Bott changed the title to Ronseal diamond hard floor…
I use Ronseal Hardglaze.
it usually requires, 2 or 3 coats, particularly over Blue Foam.
It is harder than most other commercially available WBV. Some trade WBV are rock hard, although not all.
It is more expensive than some WBV, but does the job much easier.
Nothing to dislike.
