Swift Glider
Swift Glider
A design and build project I have started.
So here is the design in CAD
Which is a little too big for my building table so I have decided to have ago at making the wings in separate parts that I can put together on the hill.
This will be a 1st for me as I have only ever made a one piece wing before as the wing joiner I am using Aluminum tube and steel rod already not sure that was the right move as I am struggling to get a smooth fit without sanding the steel rod.
Steve
Edited by Stephen Jones
no pictures
  • Like 2
6 hours ago, John T said:
Looks like an interesting project Steve.
Just out of interest, what CAD package are you using?
It is Turbo Deluxe 21. I have all the turbo deluxe versions from 14 to 21 as they where on sale at Maplin so every time their was a updated version I got it as it only cost £9.99 a bargain foe the diy enthusiast like me. But they have stopped doing the deluxe versions.
Steve
On 07/11/2022 at 17:43, Stephen Jones said:
Hi MattyB,
The aerofoil is one I modified over the years last used on my Guppy which has great high and low speed characteristics.
It is Symmetrical and I got it along with a load of other as a free pull out in a magazine but unsure which one as the page only gives page number and date.
Ok, but looking back at that thread it seems your Guppy has a tail:
Whilst I’m sure your model will fly, without a specialist plank flying wing aerofoil (its sweep is low enough that it can be considered a plank rather than a chevron wing) it won’t be able to match the performance of wings with something like PW51 or PW98. This is because plank aerofoils are completely different in design to those optimised for use with a tail, meaning you will have to carry far more reflex on your section to make it fly. Unfortunately this will add drag and hurt your performance in the turns.
https://www.aerodesign.de/profile/data/pw-airfoils_attachment.pdf
Edited by MattyB
  • 6 months later...
I have done some more work on the wings now that the weather is warmer in my loft/ workshop.
I am un decided at the moment weather to make the servo covers out of 1/16th ply and screw all the way through to hold both the servo and hatch in position. 🤔
Steve.
  • Like 2
  • 1 month later...
Forgot to add some pictures.
As the wings are removable I came up with this idea to lock them into position and be able to remove them again with out fear of them coming lose mid flight.
So I fitted a Pinned hinge and removed the pin.
Here you can see the two half's of the hinge fitted into the wing half's.
Simply slide the wing together.
And if you have fitted them correctly they will marrie up every time.
Insert a pin of the right length for a secure slop free locking system.
Steve.
Took this one to the Slope Today.
Now, ether my calculations where spot on or I was dead lucky as I did not have to alter anything.
No Trim, No alteration to the CoG.
It just flew 1st time without a hitch.
I am well pleased with it, This is only Phase one of the model design more to follow.
And I will post a video of it as soon as I have edited it.
Steve. 😁
  • Like 4
