cymaz Posted November 27, 2022 Share Posted November 27, 2022 I’ve notice on a couple ARFTs the clear top layer ( a bit like clear cellophane) is coming away. I'm sure there are other planes like this. Anyone found a solution to the issue of RC decals peeling? Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted November 27, 2022 Share Posted November 27, 2022 Lamfilm over the top. Same over the leading edge to stop the edges catching and lifting in the airflow. 1 Quote Link to comment Share on other sites More sharing options...
Jon H Posted November 27, 2022 Share Posted November 27, 2022 I have had success with some zap canopy glue (or similar) thinned to the consistency of milk and then applied between the layers with a small paint brush. Smooth it down the a paper towel, and if it needs a little more a covering iron can get it all smoothed out. Make sure there is no oil or dirt between the layers before you try this and i recommend you start with a cool iron and work up the temp as needed. 1 Quote Link to comment Share on other sites More sharing options...
Mr Ficky Posted November 27, 2022 Share Posted November 27, 2022 I used the following sealing pen that I think I got from the RCHut in South Wales. From memory it'll do about 3 planes and cost around £15. Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 27, 2022 Author Share Posted November 27, 2022 Three good ideas...obviously a common thing Quote Link to comment Share on other sites More sharing options...
