Edgeflyer Posted November 29, 2022 Share Posted November 29, 2022 On my X20, When using bootloader then plugging in the USB lead to a windows 11 laptop, the laptop gives the message power surge at the usb port, then disables the port. I would expect the X20 is self powered so don't understand. I am able to update firmware by putting the SD card into the laptop but it would be nice to use the direct pc to X20 connection. Quote Link to comment Share on other sites More sharing options...
Andy48 Posted November 29, 2022 Share Posted November 29, 2022 Unless I'm mistaken doesn't the X20 charge through the USB port which would account for the power surge. Also how much current will the Laptop USB port support? Usually one port will supply more. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted November 29, 2022 Share Posted November 29, 2022 Early USB 1.0 ports were limited to 500mA later versions went up to 2 Amps. Could this be the problem if you have an older laptop. Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted November 29, 2022 Author Share Posted November 29, 2022 Running windows 11 in a 2 year old ms surface pro. The recommended way to update is to use the usb port. So it presumably should work. Maybe I will try when the tx is fully charged. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 30, 2022 Share Posted November 30, 2022 I'm not a techy type but thought I'd just mention the instructions on my Garmin Sat Nav . It has two leads supplied with it one is for charging the other is for data teansfer ie updates. Could your equipment be the same ? Just a thought. Quote Link to comment Share on other sites More sharing options...
