Basil Posted April 17, 2023 Share Posted April 17, 2023 Hello all , once again, another queery !!!! I have some decals supplied with a kit, mainly model name , some lines and the like. How do I apply them as there are no instructions as how to apply them. Dont know how to get them off the sheet et. Are they transfers or stick ons. I really dont know how to identify types in order to know how to proceed . I have never used any decals as strange as it may seem. Thanks in advance. Bas Quote Link to comment Share on other sites More sharing options...
toto Posted April 17, 2023 Share Posted April 17, 2023 Hi Bas, I'm a newbie myself so not sure. The decal types may vary from model to model but one thing I am sure of is that the surface that you intend to stick it to must be clean of dust and or greasy residues etc. So first thing before trying to apply them is ensure the surface area is clean. It maybe helpful for others or you pit a picture up or give details of the model type. I'm sure someone will be along with some advice. Good luck once you've sorted it out. Toto Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted April 17, 2023 Share Posted April 17, 2023 Hi If of the self adhesive type, best to put them through soapy water to help them slide into position. Don’t drown or soak them. A simple pass through soapy water is enough. S Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted April 17, 2023 Share Posted April 17, 2023 5 minutes ago, Stuart Z said: Hi If of the self adhesive type, best to put them through soapy water to help them slide into position. Don’t drown or soak them. A simple pass through soapy water is enough. S And if it's not electric, a coat of fuel proof varnish 24+h hours later. Quote Link to comment Share on other sites More sharing options...
paul devereux Posted April 17, 2023 Share Posted April 17, 2023 (edited) If it is a foam kit they will be sticky-backed which you have to peel of stiffish paper. They may be like this anyway- you should be able to peel them fairly easily. Edited April 17, 2023 by paul devereux Quote Link to comment Share on other sites More sharing options...
Basil Posted April 18, 2023 Author Share Posted April 18, 2023 Sorry but I am unable to add pictures, dont know how!!!!. I am electric. Toto its an old flair kit. Bas Quote Link to comment Share on other sites More sharing options...
