Doug L Posted May 16, 2023 Share Posted May 16, 2023 Does anyone know if the R2008SB S-FHSS has the same "range" as the R7006SB FASSTest receiver?... the reason for asking is the smaller R2106 park receiver operating on S-FHSS is only 300m? I cant find the range of the R2008SB listed in the Futaba specification, its just states Full Range, so one assumes it would be the same "range" as the the R7006SB albeit fixed to S-FHSS and less telemetry. Thanks. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 16, 2023 Share Posted May 16, 2023 Doug, If it says full range then it's not a park-fly type receiver so you can be confident it will work in any model. The R2008SB has two antennas which is another way you can tell it's good to go. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted May 16, 2023 Share Posted May 16, 2023 As above for LOS model flying but if thinking of FPV use I would not know. Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 30, 2023 Share Posted May 30, 2023 Try this, it might have info about range as well Quote Link to comment Share on other sites More sharing options...
