ARTF Servo help
I've just done my maiden flight with the Heron Glider. Almost lost the plane due to the aileron servo going berserk. I have read the comments about this issue on forums but how do I remove the servo as it is apparently glued into position? Cannot remove the thing without damaging the wing. Any advice?
The servo problems are usually as a result of a voltage or signal degradation with the long leads. Check that all the plugs & sockets are really clean & making good contacts, with a good voltage available to the receiver.
Then if you still need to replace just run a modelling knife blade around the edges, minding the lead, & lever out with a wide thin flat blade, like a table knife. The ARTF's come out quite easily, however if it has been constructed from the kit & cyano'd in then it may be a struggle & impossible to extract without some damage. Fit the new servo with UHU Pro.
....and welcome to the forum!
