Stephen Jones Posted October 23 Share Posted October 23 Anyone building the Autogyro that is in this moths copy of RCM&E. I have made a start on one and have completed the blades and noticed that the side picture is wrong. Lucky my blades are spinning in the right direction. The body is cut out and ready for gluing tomorrow. steve. 1 Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted October 24 Share Posted October 24 5 hours ago, Stephen Jones said: Anyone building the Autogyro that is in this moths copy of RCM&E. I have made a start on one and have completed the blades and noticed that the side picture is wrong. Lucky my blades are spinning in the right direction. The body is cut out and ready for gluing tomorrow. steve. I thought I might have a crack at one of these, let us know how you get on Steve. 👍 1 Quote Link to comment Share on other sites More sharing options...
Outrunner Posted October 24 Share Posted October 24 Watching with interest, I intend to build one too. 1 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 26 Author Share Posted October 26 Maybe the Title needs to be change, never mind here we Go with some pictures. So cutting the parts out of 5mm Depron only a small amount is needed. As you can see here. Not much is there. Here i have glued on the motor doubles sanded the rear of the fin and glued on a short length of Carbon rod. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 26 Author Share Posted October 26 Here I may have gone over kill with the 0.8 Ply for the mast support. Also in the picture you can see a 2g servo and a 5g brushless motor and 0.8mm ply for the motor mount. A plastic tube that slides nicely over the CF rod is used as a plain bearing for the blades while a washer and nut are their to allow for good spinning rotation. And heat shrink tube to secure it while a further plastic tube insures it is tightly held in place. Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 26 Author Share Posted October 26 Landing gear, When it comes to Landing gear for indoor models in the past I have struggled to get them to work correctly. So I opted for a better solution which i hope this method will cure. So here I used some salvaged push rods that have a threaded end onto which a clevis can be attached however I have decided to use them to hold the wheels in place with thin plastic tube. I also found some thin brass tube that will act as a bush for the wheels while also ensuring that the wheels do not foul on the landing gear or retaining tube. Of course the push rods where only threaded on one end of the push rod so i Used two push rods and opted to join them by soldering some thin brass tube. This has two advantages. 1. it keeps the heat while soldering them together away from the plastic wheels. 2. Allows me to lay the landing gear on a flat surface while soldering and thus keeps them perfectly lined up and true, so no more towing in or out. Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 26 Author Share Posted October 26 I opted for a tail dragger configuration as this will be lighter. Ready to glue the final ply motor mount over the landing gear and when the motor is screwed into place should insure all is secure. Radio to be installed next. Steve. 3 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 29 Author Share Posted October 29 So as it was time to fit the Radio gear I soldered on the ESC wires to the motor. Which worked but was in reverse. I struggled to get the wires to solder in place the second time around and when testing the motor did not run correctly. So a close inspection of the wires. Looks like one of the wires has snapped off. A further look and the rest snapped off. 🤐 So this motor is now junk. So a word of warning be very very careful as the wires are easy to snap off. Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 29 Author Share Posted October 29 So I decided to take a motor off one of my other indoor models and use that instead. This one is a 9g Motor so will have plenty of power. A small 240mAh 2s Lipo temporary stuck in place with some double sided tape. A small Receiver and a 2g servo and a 6Amp ESC. Total weight is 64 grams Now waiting to be tested in the Gym. Steve. 6 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 19 Author Share Posted November 19 Flew this model today. Complete success turning both left and right equally as well. Nice and slow flying video to follow. Well please with it. Steve 😊 1 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 19 Share Posted November 19 Looking forward to the video 👍 1 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 19 Author Share Posted November 19 Here is the Video, Enjoy I did. After much Trimming it flies great, Nice and Slow too. Steve.😃 4 1 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 20 Share Posted November 20 Going to have to get some depron 😀😉 1 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 20 Author Share Posted November 20 3 hours ago, Frank Skilbeck said: Going to have to get some depron 😀😉 And some flexible foam too. I reckon you can get all you need from B n W .😉 White Depron foam and soft under floor foam. Steve 😊 Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 20 Share Posted November 20 It flew really well. Stephen always brings some of the most interesting aircraft to the NW Area Indoor at Rochdale. Very creative. 1 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 21 Author Share Posted November 21 19 hours ago, Martyn K said: It flew really well. Stephen always brings some of the most interesting aircraft to the NW Area Indoor at Rochdale. Very creative. Thank You Steve Quote Link to comment Share on other sites More sharing options...
