MarkVP Posted February 1 Share Posted February 1 Hi there, I'm returning to RC after about 15 years... I'm bewildered by how things have moved on! I've rescued the glider below from the loft, and I wonder if anyone can help with the following questions- 1- What is it? (Its 2 channel rudder/elevator with solid balsa wing and GRP fuselage). 2- Can someone recommend me a suitable transmitter and receiver + battery setup for this (and ideally one which would also be suitable for my ancient Zagi which has yet to be rescued from aforementioned loft). 3- Could I electrify this? I'm thinking some kind of tiny brushless motor in the nose, folding prop and just enough power/endurance to get up to a couple of hundred feet a few times in order to start thermalling. I suspect it is too small but I have no idea what is possible with modern tech. If it is possible can anyone recommend me a battery/motor combo which would likely work? It is 147cm span, 10cm chord. fuselage is 3cm wide and 4cm deep under the wing, about 5 cm deep in the cockpit area. Thanks in advance, I'm grateful for any help! Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted February 1 Share Posted February 1 Hi Mark and welcome. Jpegs are the best pic type to attach, so you're best posting them below. Quote Link to comment Share on other sites More sharing options...
MarkVP Posted February 1 Author Share Posted February 1 oops try again- Quote Link to comment Share on other sites More sharing options...
Matt Carlton Posted February 15 Share Posted February 15 If you were to cut a hole in the fuselage under the wing, you could potentially move the servos back. That would leave space for a small Lipo. It looks like you could conceivably fit the power unit for an F5k model in there. Something like this: https://www.armsoar.com/products/f5k-armsoar-powertrain-1806-kv2450-20a-esc Which is very compact and on 3S would be ample. So the quick answer is yes, depending on how much effort you are willing to make to acheive it. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted February 16 Share Posted February 16 (edited) Hi Mark, I can’t identify the model but I am sure someone will be along soon who can. Your glider conversion looks possible. As an alternative you could leave the servos where they are and cut a hole in the fuselage beneath the wing for the receiver, provided the control pushrods don’t get in the way. You could try Robotbirds for a suitable motor/ESC. Send some photos and a few details including weight and span. This motor as a suggestion? 4Max can probably suggest a suitable powertrain too. Good luck with your project. ps, does it really have a solid wing when the fuselage is so light? Edited February 16 by Piers Bowlan Quote Link to comment Share on other sites More sharing options...
MarkVP Posted February 21 Author Share Posted February 21 (edited) Thanks for the info guys. Much appreciated. I've removed all the old gear and opened up as big a hole as I dare under the wing. Having looked at the access and googled the sizes of batteries my plan is to relocate the servos under the wing, and have the batt/Rx speed controller up front. Its hard to convey how clueless I am with the electric side of things! I have no idea what size motor is compatible with what battery, what mAh I should go with, what the compatible connectors are etc etc. I like the look of the F5F powertrain suggested above but it has an XT30 connector and I can't seem to find any batteries with XT30 connectors? Most seem to have XT60U-F? 🤷♂️. Its a lot of googling! I'm toying with the idea of making a removable/interchangeable nose cone/motor so that I can fly it as a pure glider if required! See how I get on. Yes it has a solid wing! I remember it used to fly beautifully for a rudder/elevator model. As soon as you touch the rudder it would quickly roll into a nicely balanced turn with hardly any perceptible yaw. I always assumed it was down to the very sharp dihedral on the wing tips (the original kit showed the tip panels heavily radiused on the leading edge but I left them square to preserve the wing area). Can't wait to fly it again... although I'm probably about to ruin it with all the extra weight! Edited February 21 by MarkVP Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted February 21 Share Posted February 21 That is such a nice fuselage that it seems a shame to butcher it. Why not put a motor on a pylon up above the wing, where the shaft and prop will be protected? You can then fly it as a pure glider still if the opportunity arises. 2 Quote Link to comment Share on other sites More sharing options...
MarkVP Posted February 27 Author Share Posted February 27 Went with the Armsoar powertrain suggested above and some 3s batteries. I'm very impressed with how small and light the motor and batts are! I think the batt and motor combined might actually be lighter than the old receiver battery I was using in it 15 years ago! I chopped the nose off, the fuselage is oval in section not round, so I experimented shoving different size penny washers into the nose until I found one that was the right size to "persuade" the front of the fuselage into a perfectly round section to match the spinner. I then used that washer as a basis to set about making a bulkhead from some surplus carbon which I must have laid up about 10 years ago (knew that would come in handy). Lots of in and out to get it to the required shape, but its dry fit now and looking pretty good. The spinner isn't a bad match for the shape of the fuselage. The motor power cables can be persuaded to fit under the canopy and the canopy itself is almost there, just needs slight modification... The tolerances are, shall we say, "toight". There must be all of 0.5mm around the front of the motor. Drilling the motor mount holes in the right place in the bulkhead to achieve clearance was an absolute torment! Been a while since I've worked with something this small and delicate- good for the soul. Next step is to tack in the bulkhead with some epoxy, remove the motor and then glass in the bulkhead properly... Ps- Can anyone recommend a transmitter which would work for this and a selection of other stuff- flying wings, helicopters etc? Ideally less than 200? 1 Quote Link to comment Share on other sites More sharing options...
MarkVP Posted 18 hours ago Author Share Posted 18 hours ago Probably the slowest project ever but its done. I originally bought a 500mAh battery but it was tiny in the fuselage and too light! With a 1000mAh batt no lead is required to make the c of g work. It flies brilliantly and I'm amazed by the power! It climbs almost vertically and a 5-10 second burst of power is enough to get high enough to glide around for what seems like ages. Now all I need are some thermals. Great fun! 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted 16 hours ago Share Posted 16 hours ago I guess you bought some radio gear then..... Quote Link to comment Share on other sites More sharing options...
MarkVP Posted 14 hours ago Author Share Posted 14 hours ago 1 hour ago, GrumpyGnome said: I guess you bought some radio gear then..... Yep took a significant amount of loitering on facebook marketplace but eventually acquired a second hand Spektrum DX8. Amazing bit of kit. and PS- after a bit of practicing this afternoon I can now manage to get this thing to climb away vertically 😁. The last time I flew an electrically powered model they could barely climb! Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted 13 hours ago Share Posted 13 hours ago Electric flight, and the capabilities of radio, has come on in leaps and bounds Quote Link to comment Share on other sites More sharing options...
