Graff Posted April 28, 2024 Share Posted April 28, 2024 Hi, I have a quarter scale Sopwith pup that's getting some upgrades, it really needed a spruce up of the nose. I also needed to put a baffle around the engine for cooling. I have a three-cylinder Saito radial engine in it, and to mimic the nine cylinders of the original, I had to put two cylinders between each cylinder. The prototype that I'm modeling has a Monosoupape and my idea was to make a look-alike... A quick effort in Fusion 360 paid off: I designed it to fit over the Saito radial. The print turned out really nice, it's high temperature ABS filament. The test fit was good, but it left room for improvements. I will get back when the printer is done printing out the revised version. 12 Quote Link to comment Share on other sites More sharing options...
stu knowles Posted April 29, 2024 Share Posted April 29, 2024 Very clever! Wish that I hd your skills 1 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted April 29, 2024 Share Posted April 29, 2024 (edited) Neat a 6/9th scale Monosoupape.😉 I appreciate there are scale issues but the Mono was not the usual engine in the Pup. I believe it was only used in the Home Defence version where despite its considerable cost its extra power allowed the Pup to more quickly reach the altitude of the Zeppelins and Gotha bombers. Perhaps scale cylinders that match the three IC ones might actually look neater. Just on an excruciating scale point the Mono Pup cowling was quite complex with four "hooded" vents in the cowl front which I believe matched the air inlet period of the single valve. Note also the four external reinforcements. There is a picture of a Pup Mono cowling with 6 reinforcements. Clearly flexing (and fatigue cracking?) of the aluminium "horseshoe" cowling was an issue that was not found in the "full" cowling used on the 80hp Le Rhone. Of course with electric power the ultimate scale feature is possible with the rotary going round with the prop. A much smaller scale Pup The electric motor is the crank case. It even all stays together at full power. Edited April 29, 2024 by Simon Chaddock 2 Quote Link to comment Share on other sites More sharing options...
Graff Posted April 29, 2024 Author Share Posted April 29, 2024 Well, not all Monosoupape Pups had that cowling. My dummy engine version 2.0 that I printed out is now mounted on the plywood baffle to be glued to the engine cover. I've only primed it yet, but with some aluminum paint and detailing it will look better. The cooling of the engine will be so much better as a result. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted April 29, 2024 Share Posted April 29, 2024 I looks like the Pups in those pictures have the 7 cylinder 80hp Type A Monosoupape which used a simpler cowl. If your Pup has 9 Monosoupape cylinders then it is the Type B-2 100hp engine which apparently did need the more complex "hooded" cowl. Quote Link to comment Share on other sites More sharing options...
Graff Posted April 30, 2024 Author Share Posted April 30, 2024 The problem is that I've seen too many restored and/or replica Pups with the "wrong" engine.... I can at least show the judges this: As proof of motive power so to speak. 😁 Sure, a LeRhone dummy would have been better, but it wouldn't have worked with the Saito radial. Quote Link to comment Share on other sites More sharing options...
Graff Posted April 30, 2024 Author Share Posted April 30, 2024 This is the result: 9 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted April 30, 2024 Share Posted April 30, 2024 Only the Clerget rotary engines had twin pushrods. Some 7 cylinder 80hp 7Z engines were fitted to Pups but I have not found any period pictures of such an installation. The 9 cylinder 130hp 9Bf Clerget was standard for the Camel until replaced by the 150hp Bentley BR1. Quote Link to comment Share on other sites More sharing options...
Graff Posted April 30, 2024 Author Share Posted April 30, 2024 Yes, but I don't think that the clerget had ever been mounted in a pup? The real engine has to be visible so the cooling stays adequate. And it has two pushrods..... That's a good enough level. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 30, 2024 Share Posted April 30, 2024 Well I for one thinks it looks pretty darn good. 2 Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted May 1, 2024 Share Posted May 1, 2024 Yes, a great job that really does look the part. It will add enormously to the scale look of the front of your Pup. Impressive work. Quote Link to comment Share on other sites More sharing options...
