Its a what?
Phil Winks
http://i292.photobucket.com/albums/mm4/phil-0107/kangaroo.jpg
not a brilliant photo but go on see if you think its what I thought it was a clue is it 1st flew on the 25 may 1948 and its specs are
Purpose: Single Seat Long Range Fighter
Crew: 1
Wingspan: 36 feet
Length: 36 feet
Wing area: 23 sq. feet
Takeoff weight: 10,764 lbs
Engine: Rolls Royce Griffon 61 V12; 2,035 HP at 7,000 ft.
Max. speed: 320 KTS (593 km/h) TAS at MSL
Ceiling: 39,000 feet
Range: 2,206 NMs (4089 kms) with aux. external fuel at 5000 FT
Armament: 6 x 12.5 mm MG, 10 rockets
bet andy and brian googled the photo file name lol come on be honest did you not think it was a p51 unfortunately they are right unless I'm mistaken 1st flew a while before the p51 the give away is the fuse is much bigger in section and the scoop is further forward a tad and has an exit vent
http://skyraider.allaboutwarfare.com/files/modelling/P-51D_vs_CA-15.jpg
Made by the "commonwealth aircraft corporation" in austrailia just look at the specs though thats one hell of a top speed for the time
Here's a lookalike that good old eric pointed out to me uncanny resemblance the japanese zero and the american t6-g harvard texan
http://i292.photobucket.com/albums/mm4/phil-0107/t6harvardtexan.jpg
http://i292.photobucket.com/albums/mm4/phil-0107/Zero_Akagi_Dec1941.jpg
a quick look at the specs 1st the texan
General characteristics
  • Crew: two (student and instructor)
  • Length: 29 ft (8.84 m)
  • Wingspan: 42 ft (12.81 m)
  • Height: 11 ft 8 in (3.57 m)
  • Wing area: 253.7 ft² (23.6 m²)
  • Empty weight: 4,158 lb (1,886 kg)
  • Loaded weight: 5,617 lb (2,548 kg)
  • Powerplant: 1× Pratt & Whitney R-1340-AN-1 Wasp radial engine, 600 hp (450 kW)
Then the Zero
  • Crew: 1
  • Length: 9.06 m (29 ft 9 in)
  • Wingspan: 12.0 m (39 ft 4 in)
  • Height: 3.05 m (10 ft 0 in)
  • Wing area: 22.44 m² (241.5 ft²)
  • Empty weight: 1,680 kg (3,704 lb)
  • Loaded weight: 2,410 kg (5,313 lb)
  • Max takeoff weight: kg (lb)
  • Powerplant: 1× Nakajima Sakae 12 radial engine, 709 kW (950 hp)
And you can see the zero was slightly smaller but mainly much more powerfull 950hp over 600hp in the texan.  the zero's top speed was 331mph and the texan a much more sedate (as befitting a trainer) 208mph the take off weight differs a little but this is a lovely example of how two very similar airframes can be made very different in performance
Right lets have another go this is the 3rd time I've tried to post this. keeps timing out on me and the 1st time was at 5 O'Clock on the change over day so it didn't stick
Any way the plane is a PHILLIPS ST2 SUPERTWIN here's a photo of the one you photographed ben taken on the same day looks good for an electric model don't you think
