Tony Nighuis Mini Jet Provost Advice
Hi,
     Just acquired, the supposed prototype, Mini Jet Provost at the BMFA swapmeet today.
Stupidly, forgot to ask any questions
Lovely Model but its fitted with a stabiliser.
Never had one of these.
I have bound the rec to my spektrum nx6 and all works fine.
However having connected the battery and placed the Model level I switched on the stabiliser and after a short time all seems well.
If I move the Model laterally the ailerons move to correct the Model ,if upside down it applies full aileron.
Elevator also works in the correct sense.
If I state the two position "a" switch I can stop the roll stab function but not the pitch function.
So the question are ....
.1. Am I arming the system correctly?
2. Should I try to allocate a 3 position switch to the isolate function?
3. What make/model is the stab system?
Thanks...hope to maiden it this week
Bill
It's the 'Vector' gyro, as fitted to many of the Arrows models 50mm EDF series. In the Arrows models they come pre-programmed & are not adjustable, I've not come across programmable versions but they may be available. I've not seen it with an external switch, the switching on mine is via a 3 position switch to spare channel on the Rx that goes into the input 'BS'
Here's a scan of the instructions as supplied by Arrows:
20240616_Vector.pdf
Well flight 1..gust stab only my handlaunch
Just descended into the grass.
Flt 2 stab fully on, handlaunch went great flew quite fast tried the other stab positions not very good so left at full stab.
Forgot with edf not to get slow round finals and just missed the ground at full up elevator.
Tried the same thing but with more power much better.
Two further flights using 3s 1500 cells all good. Lived to flight another day.
Bill
  • Like 5
