Dave Towell Posted January 31, 2009 Share Posted January 31, 2009 Don't know of this is in the right thread but. Gorilla Glue is now avalibe at FOCUS diy stores. Just came in yesterday to my local store and apparently is a new line they are all going to stock it. Just thought I'd let people know. Quote Link to comment Share on other sites More sharing options...
winchweight Posted January 31, 2009 Share Posted January 31, 2009 You can get it in "Charlies Stores" too. Quote Link to comment Share on other sites More sharing options...
iawnski Posted January 31, 2009 Share Posted January 31, 2009 thought focus going bust? Quote Link to comment Share on other sites More sharing options...
Dave Towell Posted February 1, 2009 Author Share Posted February 1, 2009 Dont think focus going bust, but if it is, best I buy a decent stock pile of the stuff then!!!!!!! Quote Link to comment Share on other sites More sharing options...
Erfolg Posted February 5, 2009 Share Posted February 5, 2009 Is Gorrilla glue, just another Polyurethane adhesive? Just like Henkels "Elch Pro" Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted February 5, 2009 Share Posted February 5, 2009 What woudl be good is if you had an aliphatic glue for gluing like the curved leading edge sheeting on, then you spray activator and it sets like super glue, whereas super glue automatically drys whether activator is used or not Quote Link to comment Share on other sites More sharing options...
Dave Towell Posted February 5, 2009 Author Share Posted February 5, 2009 Just use some of there glues. they had 2 difrent types so got a small bottel of each just to try them out after hearing so much about them thought I'd give it a go. so decided test them on test pices of scrap balsa, depron, plastic and metal (dural scraps). OH MY GOD!!!!!! SETS LIKE ITS BEEN TIG WELDED Ones a clear liquid looks a bit like super glue the other one is a brown gloopy thing and looks a bit like a strange contact adhisive. Technical descriptions aren't they! They set so solid its amazing. Some seped out onto my NEW work bench and could hardly get the thing off. there is no way that the glue joint will fail, the wood will fail first. will use them again excellent stuff just wish the curing times a bit quicker. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted February 5, 2009 Share Posted February 5, 2009 Unless your name is Tony Nijhuis only buy the small bottles, it lasts for ages and larger quantities tend to set in the bottle. After use squeeze out all the air from the bottle and cap tightly. The clear one is the fast setting variety and the brown is a bit slower. In the open the fast one foams up to four times its original volume and the brown about double, so don't use too much or you'll end with a wing as a building board. My favourite use is for reinforcing flimsy ARTF structures, just run a THIN bead along any suspect joint and it will foam up and form a very strong fillet. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 5, 2009 Share Posted February 5, 2009 Erfolg...yes. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted February 6, 2009 Share Posted February 6, 2009 Just goes to show how important the brand name is. Calling your glue Elk or Woodmate, does not sound half as impressive as King Kong glue, or maybe Bulldog grip. I have used at least two brands of Polyurethane adhesive or glue. The current is the Henkel Elk, used Woodmate and I believe Tercel. They were all D4 grades, water resistant. I personally use them infrequently on models. Generally as now on general timber work, as it is water resistant fills gaps. The downside if your joints are not good it osses out, as it foams. Good fit ,no foaming. If used over a large thin area, that is a little like a diaphram, it needs weighting, to prevent the surface lifting. My main reservation is weight. Just generally preffer PVA and Superglue for models. I have noted it is the wood that usually fails not the joint, in my experience. Elk costs£8 for 750g, Geocel £9 for 500ml. Any good timber merchant stocks them or there equivalent. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 6, 2009 Share Posted February 6, 2009 hello ---anybody out ther use the hot glue gun's--i bought one c/w some stick's of glue tried it on some ply- impressed with the strength of the joint---but been from the old skool--thought better stick to the everyday stuff(white glue/superglue and epox)anybody out there use one on a regular basis/anygood/strong etc........................... thankyou ken anderson........................... Quote Link to comment Share on other sites More sharing options...
Erfolg Posted February 6, 2009 Share Posted February 6, 2009 Ken I have now used a Hot Glue Gun, having built the Ballerina. It was suggested that the CF to Depron joint could/should be done this way. The resulting joint was not quite what ideally as I would like, which is a beutifully curved trasition to the Depron. Instead a blob, OK, functional. The author warns against over enthusiastic use, to prevent excessive weight accumulation. Seems some stick the servos onto ply sheet by this method. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 6, 2009 Share Posted February 6, 2009 hello erfolg--thanks for that--i'll hang fire for some more feedback. ken anderson................................... Quote Link to comment Share on other sites More sharing options...
Dave Towell Posted February 6, 2009 Author Share Posted February 6, 2009 Hot glue is all I use on depron it works realy well dosn't add to much wieght as long as its not over used. I put servos in with the stuff, just tape round them first so you can remove it later. just becareful not to use to much near any joint you want to sand as it do not sand very well. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 9, 2009 Share Posted February 9, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dave Towell Posted February 18, 2009 Author Share Posted February 18, 2009 Never noticed hot glue going soft in the summer. will have to keep a eye on that in the summer. Mind you when was the last time we had a summer????????? Quote Link to comment Share on other sites More sharing options...
Dane Crosby Posted November 26, 2013 Share Posted November 26, 2013 Hi all, As I posted in another thread, I am trying EPO for the first time (always been wood before). I will soon need to glue my Bixler 1.1 fuselage halves together. In addition to a hot melt gun (Bosch), I have UHU POR, Various strengths and thicknesses of Cyano, Canopy glue, 5 Min Z-Epoxy, and modellers PVA. I have recently been given a bottle of Gator Glue. Is this any good? It looks a little like Gorilla glue. Anyway, What is the best way to stick the halves together to give a neat join with good strength. I have searched the forum but failed to find a solid answer to this. Quote Link to comment Share on other sites More sharing options...
Dane Crosby Posted November 26, 2013 Share Posted November 26, 2013 Ah, I have managed to answer my own question after a bit of research. Gorilla Glue: Diphenylmethane diisocyanate, isomers and homologues 45% to 60% Gator Glue Diphenylmethane diisocyanate, isomers and homologues 10%-30% So, Gator is a similar chemical construction, just a bit less gloopy stuff. Prbably takes longer to set but less foamy. I'll report back on a test piece. Quote Link to comment Share on other sites More sharing options...
StarLoc FiveStar Adhesives Posted November 26, 2013 Share Posted November 26, 2013 Posted by Dane Crosby on 26/11/2013 11:28:11: Ah, I have managed to answer my own question after a bit of research. Gorilla Glue: Diphenylmethane diisocyanate, isomers and homologues 45% to 60% Gator Glue Diphenylmethane diisocyanate, isomers and homologues 10%-30% So, Gator is a similar chemical construction, just a bit less gloopy stuff. Prbably takes longer to set but less foamy. I'll report back on a test piece. Its not that easy with polyurethanes, MDI is the isocyanate, the very reactive (and very very toxic  part , but to form a glue it is reacted with other components to form the reactive polyurethane, the polyurethanes can be made from a vast amount of chemicals, even natural things like sugars, the components are mixed , under nitrogen to prevent side reactions, always more MDI is used to leave a reactive end group on the polyurethane, the reactive group is required to crosslink in contact with water generating carbon dioxide gas in the process ( foaming the glue ) The polyurethane (strong) part of the glue is not actually listed , the other is just left ove from the reaction, different levels have different properties in the adhesive, but the main difference would be the other reactant in the polyurethane,the reactants are formed from chemicals such as polyethylene glycol , butylene glycol etc all have different properties of hardness and cure speed, rigidity , bond strength etc They may all sound similar glues but could be totally different, with no real differences on the data sheets Edited By StarLoc FiveStar Adhesives on 26/11/2013 12:09:43 Quote Link to comment Share on other sites More sharing options...
Dane Crosby Posted November 26, 2013 Share Posted November 26, 2013 Many thanks for the reply. It does all seem to be complicated so I am no further forwards in "guessing" what fixative to use to glue the two EPO Bixler fuselage halves together. The edges to be joined are very long and convoluted. There are also ply parts that enter opposing slots to be glued. All this comes together at the same instant. I don't want the glue which was applied at the start of the process to have gone off before I get to the end. What should I use ?? Maybe I should have stayed with wood which I have coped with for decades! Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted November 26, 2013 Share Posted November 26, 2013 Hi Dave I used Gorilla Glue on the Foam Fing wing to bond the Pine LE. to the foam Fing wing. Sticks like the proverbial but it does foam up and a beast to sand. End result cut the excess back and covered with red Gorilla tape (another first). David Quote Link to comment Share on other sites More sharing options...
Plummet Posted November 26, 2013 Share Posted November 26, 2013 If you like Gorilla Glue, then you might like **LINK** It comes either in a bottle or a sealant-gun cartridge, in 5 or 30 minute types. It sets (fairly) clear, Needs good clamping because it foams. It is a lot cheaper than Gorilla. Plummet Quote Link to comment Share on other sites More sharing options...
Erfolg Posted November 26, 2013 Share Posted November 26, 2013 I have used the 45 minute stuff, as well as Woodmate and Elk, all every bit as good as Gorilla in performance. The one thing that Gorilla does have in its favour is that small bottles can be purchased, which are much easier for modellers to handle. Although at twice the cost. I think you can tell that Gorilla is aimed at the DIY trade, in that you are told to squeeze out as much air as possible after use. The trade stuff, assumes that you will have used it all before it starts to go of. I must admit that I have in the past been dismissive of Polyurethane adhesives, in that PVA does most jobs far better at lighter weight build up. However I have recently used it with polystyrene foam to woad and also ply doublers to balsa (instead of impact adhesive). I tend not to use water based impact adhesive, so for foam, Polyurethanes are better. With respect balsa/ply laminations, impact is marginally better, in that it is easier to use, no weighting required. Quote Link to comment Share on other sites More sharing options...
Wiltshire Flyer Posted November 27, 2013 Share Posted November 27, 2013 I saw gurilla glue in homebase and screwfix today, can u really use them to assemble a model? Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 27, 2013 Share Posted November 27, 2013 Posted by Wiltshire Flyer on 27/11/2013 00:12:04: I saw gurilla glue in homebase and screwfix today, can u really use them to assemble a model? It's hard to beat for some jobs such as fitting retract mountings in a foam wing or anywhere that gap-filling is useful. I've even used as a filler when building carved wood cowls. Once foamed I find it easy to sand and quite light. Quote Link to comment Share on other sites More sharing options...
