Lipo powered Rx.
Albert Ace
The receivers aren't the issue. Its the servos. JR servos burn out quite quickly above 6V, especially if worked hard. The general consensus is that Futaba servos are more tolerant, but any servo not rated for higher voltage will have its life significantly shortened by running it on an excessively high voltage.
LiFe generally cells are better than LiPo or LiIon cells, as they are 3.3V per cell (6.6 for 2S Vs 7.X for LiPo/LiIon). They also don't have a tendency to burst into flames if mischarged like LiPos, making them safer to charge in situ.
You really need to find out what your servos are rated to.
Pete
Grumpy, just curious. Been using Nimhs forever, and I'm the club 'you're not charging that right' moaner.
A lot of people fast charge Nimhs, usually in 1 to 2 hours. I always use standard wall charger and  leave 6 to 10 hours, depending on use.
Like I said, just curious.
Albert
  • Thanks 1
Pete
My Futaba standard sport servos i.e. 3001s do not work correctly on anything over 6.5V as I found out when I was dabbling with changing over from nimhs a while ago. They are rated at a max of 6V so not surprising really. I believe Futaba's inexpensive new standard servos are still only rated for 6V max, but their standard digital servo (at twice the price) is rated to 8V.
Servo Shop's website is very good for servo data.
Edited by Cuban8
JD 8, what caused the distrust of 3001, and Life combo.
 In the days of NiCad, a 3001 died when the gear train got slop. Nowadays, still with a box of 3001’s, mine die of slop if driven by a LiFe cell. No idea if the hours are shorter, don’t care much, slop gets eliminated as a servicing issue, not crash forensic examination.
Dont know much about NiMh, early adopter, using cheap cells, grew a dislike before I even head of enloop types. By then too late, or more to the point, little desire.
Life, leave at storage level, last minute desision to fly, 20 minute charge and it’s good to go.
