Handyman Posted November 27, 2024 Share Posted November 27, 2024 I have a OS FX .91 glow engine which I bought from the BMFA Auction. I am looking for a silencer, as there was no silencer with it. The silencer mounting holes need to be 42mm apart to suit this engine, I have tried several suppliers for a suitable silencer, but no joy so far. I dont have a part number for it, but I have an Evolution .61 that has a silencer that would fit it and it has mounting holes set exactly at 42mm so even a silencer from an evolution engine should fit, as long as the spacings for the mounting bolts are 42mm apart. So here's hoping that someone can help me out, but in the meantime I will continue to search the web. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 27, 2024 Share Posted November 27, 2024 Would this fit? https://www.justengines.co.uk/shop/exhaust-systems/four-stroke-exhausts/four-stroke-mufflers-silencers/65-91-fs-silencer-baffled-2/?v=79cba1185463 Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted November 27, 2024 Share Posted November 27, 2024 (edited) H Just engines have what you are looking for,91 size 2 stroke engine silencer with 42mm centres JEN 91 Give Andrew a call and he will sort it for you JIm Edited November 27, 2024 by Jimbo565 typo 2 Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted November 27, 2024 Share Posted November 27, 2024 5 hours ago, Handyman said: I have a OS FX .91 glow engine which I bought from the BMFA Auction. I am looking for a silencer, as there was no silencer with it. The silencer mounting holes need to be 42mm apart to suit this engine, I have tried several suppliers for a suitable silencer, but no joy so far. I dont have a part number for it, but I have an Evolution .61 that has a silencer that would fit it and it has mounting holes set exactly at 42mm so even a silencer from an evolution engine should fit, as long as the spacings for the mounting bolts are 42mm apart. So here's hoping that someone can help me out, but in the meantime I will continue to search the web. Have you tried Slough Radio Control Models? While the silencer is out of stock they may be able to give you a supply date. This link also gives you the OS part number of the silencer. Quote Link to comment Share on other sites More sharing options...
Handyman Posted November 27, 2024 Author Share Posted November 27, 2024 6 hours ago, Shaun Walsh said: Would this fit? No Shaun. My engine is a 2 stroke not a 4 stroke https://www.justengines.co.uk/shop/exhaust-systems/four-stroke-exhausts/four-stroke-mufflers-silencers/65-91-fs-silencer-baffled-2/?v=79cba1185463 Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted November 28, 2024 Share Posted November 28, 2024 (edited) Handyman, The silencers for the Irvine 61 and 72 MkII are virtually identical to the OS 91FX one. They all have 42mm bolt pitch. A search for one of those may get you what you need. Just engines don't have them though so you will need to look elsewhere. ETA, Sussex have these, not the fully quiet type but available from supplier stock which usually means a couple of days. It looks compatible but you will need to check the bolt pitch. https://sussex-model-centre.co.uk/products/91601a-sc-silencer-91-108-mkii Edited November 28, 2024 by Andy Stephenson Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 28, 2024 Share Posted November 28, 2024 The range of SC engines just reintroduced are OS clones and a spare silencer should be readily available . Perkins are distributors so any / most m9del shops shouldbe able to supply one. Or try Perkins direct, Probably a lot cheaper than an OS part. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted November 28, 2024 Share Posted November 28, 2024 OS want about 50 quid for one but the alternatives are half the price. Quote Link to comment Share on other sites More sharing options...
