David Ashby - Moderator Posted June 28, 2009 Share Posted June 28, 2009 Flying buddy Pete had one of these at the patch today, It's a Breeze trainer from Ashford Model Centre (they were called Wholesale Planes) - £32 - 59" span, all-wood, looked to be well made, flew really well, can't get much cheaper!! Link. Edited By David Ashby - RCME moderator on 28/06/2009 21:36:21 Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 28, 2009 Share Posted June 28, 2009 Nice looking trainer ,and a good colour scheme.\\\\easy to see.Important when your learning Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 1, 2009 Share Posted July 1, 2009 Just needs a nice .32 in it!!!! Quote Link to comment Share on other sites More sharing options...
tricksta Posted July 7, 2009 Share Posted July 7, 2009 ive been looking at the breeze at punkies in hinckley he does the same artf for £29.95 so will be getting one of those ! Quote Link to comment Share on other sites More sharing options...
DAVID CLIFFORD Posted July 7, 2009 Share Posted July 7, 2009 nice looking plane. £32 this motor esc combi link £56 I.C conversion nice sc 40 2 stroke £43 this type of battery battery £ 15 - £20 each. only 1 flight per battery flight battery Rx battery £15.99. At least 3 - 5 flights per charge doesn't say what type of servo's but i would guess 4 x MG midi's e.g HS85's servos at £22.00 each £88 If normal 3003's 4 x for £32.50 3003's prop prop £6 all up for £202! if 3003's £146.50 I.C £184 ish. + whatever fuel you use but more than one flight each visit. If 3003's then £128.50. Sounds good to me. D the interested Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted July 7, 2009 Share Posted July 7, 2009 You could make it alot cheaper than that! If you shop around you could easily drop the price of motor and esc to about £30(cough giant cod cough). I wouldn't trust those lipos from Ebay, as many on here will tell you. You'd end up buying decent ones anyway. However, the money saved on power train could go towards lipos. RX battery, would hope to get more out of it than that! Save yourself a tenner and buy a £5 JP one from your LHS. As for servo's. you'd get away with 9 gram jobbies! My E-Pioneer (61") uses 9gram servos very well on a power setup more power full than the one you state. Don't forget, you're not doing 3D manouvers, its a trainer. If you really wanted standard servos BRC do nice ones, 4 for £15. £6 for a prop! £1 for one from the internet. By my calculations I've just saved you £28. If you wish David, Ill give you the links for the stuff, or you could cast your eye over the E-Pioneer thread and look at what people have set their models up on. Ben Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 7, 2009 Share Posted July 7, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted July 7, 2009 Share Posted July 7, 2009 Matter of opinion isn't it Phil. Either way it'll cost you around £15. I suppose standards could easily be moved into your second model as well. I have to say, 9gram servos are a little slow, and don't give much movement. Anyway, It looks like a nice model, wish it was around when I started! Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted July 7, 2009 Share Posted July 7, 2009 Would go well with a 4s A123 cell, more expensive but faster recharge. Quote Link to comment Share on other sites More sharing options...
DAVID CLIFFORD Posted July 8, 2009 Share Posted July 8, 2009 Motor and esc on GC looks ok. Have had mixed dealings with them in the past and has not always been good. Batteries from EBay? i have 15 now and all have come from Hong Kong. Never had an issue with any of them. Perhaps they wont last as long as Rhino or Flightmax (which if i understand correctly are made in China!) but i pay a fraction of the cost so can buy three times as many for the same price. I bought some from Aeronuts nearly 2 years ago now and have only just thrown them away. I paid around £10 each for them, 2200 3 cells. Pretty good value and reliability if you ask me!! The prop i quoted was a wooden one as well so a bit more dosh but more authentic. D Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted July 8, 2009 Share Posted July 8, 2009 David C, I agree with you on cheap Lipos I have bought load and the have given excellent service. But I do not think there is such a thing as an "authentic" prop fro and electric trainer.Edited By Bruce Richards on 08/07/2009 13:24:14 Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted July 8, 2009 Share Posted July 8, 2009 looks like ill have to try those Ebay Lipos. Not worth it on smaller batteries though, postage is quite high. Wooden prop is more likely to break Quote Link to comment Share on other sites More sharing options...
DAVID CLIFFORD Posted July 9, 2009 Share Posted July 9, 2009 Probably right Bruce! I must say that i had a wooden prop on my hangar nine piper cub at first but it was not cheap. i swapped to APC after i broke it, which Ben rightly points out it is more likely to do. Phil, having followed the link to the trainer it does not give a size of servo! Does it take standard? D the curious Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 9, 2009 Share Posted July 9, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
DAVID CLIFFORD Posted July 9, 2009 Share Posted July 9, 2009 Te he do i feel like a berk D the red faced Quote Link to comment Share on other sites More sharing options...
James Marr Posted August 8, 2009 Share Posted August 8, 2009 I got one, bought dirt cheap chinese servos, 32 SC two stroke, dry battery pack , decent spektrum Rx, all cost £122. Not as fun as most of my models but it was dead cheap and I'm happy with it =] Quote Link to comment Share on other sites More sharing options...
