Martin McIntosh Posted July 7, 2007 Share Posted July 7, 2007 I recently bought a 6ex via the USA which has a Sanyo 600mAh nicad installed in the Tx. This starts life at 11.1V at end of charge, the usual 10.4V by the time I get to the field. Fine, but after a 15 min. flight it is down to 9.7V. 30 mins. later, when left switched on, it is down to 9.5V which has been checked with a calibrated digital meter. The the battery has been checked for performance on a cycler, and is up to scratch. I have not as yet measured the current drain but would be interested to hear from other users of this Tx. Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted July 7, 2007 Share Posted July 7, 2007 Hi I have a uk 6exa, Slightly dif to yours but the same on batt drain. I have used mine till bleeping many a time. If there is a cure to its batt eating then please let me know.Best regardsLee Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted July 8, 2007 Share Posted July 8, 2007 I too have the set .But it has a 700mah Tx I have re cycled it (my way with a small 12V bulb where i can access connections to check volts & amps under a 360 ma load from the screw type bulb ( yes you might have trouble finding one this century !)I have just checked the read out on the Tx after being fully charged 2 weeks ago & it's blinking on 10.1 V. BUT if I leave it switched on after the re-charge it lasts an amazing 2 hrs 20 mins .I keep graphs of time versus voltage on this load so I can keep on the lookout for any change in duration .QUESTION Does the Tx use more power when being "twiddled" than when just allowed to run down on it's own .We know obviously that Rx batts do as they power servos .I suppose the answer is to buy some Nih replacements ,& another charger & etc etc -----etc .Off we go to spend more money Eh !?(again)I must cut down on eating on a daily basis & other luxuries Grumpy Myron Just realised I havn't helped with your enquiry much have I ? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 8, 2007 Author Share Posted July 8, 2007 Thanks for the responses. Think I will fit a 2400 pack for peace of mind. Flew it in an i/c aerobat for the first time today with no problems, but whist setting up in the shed the ailerons (flaperons) were uneven, with one servo intermittently delayed either going to position or returning to neutral by, I guess, 1/4 - 1/2 sec. Also the rudder rates seemed to have a mind of their own with low rate increasing the travel slightly no matter what travel value I entered. Restoring to flight mode cured the aileron problem, but not the rudder. Having previously used JR radio I am not familiar with the quirks of Futaba, but this situation seems rather strange to say the least. Quote Link to comment Share on other sites More sharing options...
dizzypanic Posted July 8, 2007 Share Posted July 8, 2007 Do that, I have a new 2400mAh pack in my skysport 6A...and it lasts for ages. The supplied pack is also only 700mAh. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 27, 2007 Share Posted August 27, 2007 Go LipO my friend...' tis the future - NOW PS as a JR user why did you go for that naff cheap plasticky 6ex 2.4Ghz, rather than a Spektrum which is to all purposes a JR . Programming is identical to what you are familiar with too !Taxi !!! Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 27, 2007 Author Share Posted August 27, 2007 `Cos I did not fancy that strange dual Rx set up. Also I thought that I would give Futaba a try. Will stick to JR in the future.MM. PS. my experience with lipos would not give me enough confidence to entrust them to a Tx. Cannot see the point either. MM. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 27, 2007 Share Posted August 27, 2007 My experience with LiPos is EXACTLY what inspired me to convert all my gear to them, as described in my article on here "LiPo for radio gear". I have around 50 different LiPo packs of varying sizes, in many different types of aircraft, as well as my 2 transmitters. I have 4 different chargers, and 2 balancers, and can honestly say I have never had a single incident or concern with any of it. I am cursed with a very disciplined and tidy mind, and I am sure that this is the main reason for my success with them. As for the advantages, well how about only having to charge the tr up on your birthday ? Seriously, I fitted a 2500 m/a LiPo pack into my Spekky approx 3 months ago, I have logged over 11 hours flying on it, including around 1.5 hours yesterday, and the meter still reads 11.1V. Considering your opening remarks about poor battery life in your tr, I find it very odd that you are so reticant about trying a Lipo pack !! These were just MADE FOR YOU. It will be charged in 1 hour from "flat" ( whenever that may be ) and will then remain fully charged and ready for instant, spontaneous use, for months and months and months.... Whats more, it cost just £13 !!The " strange " dual receiver set up you mention is not strange at all, and applies actually to only one of the current range of Spektum receivers, the others all being a single unit, and of considerably smaller size. I have had absolutely no problems in positioning or fixing any of them into any of my models, including one of these full size dual AR7000 rcvrs into a small 17 oz AUW ALFA Sabre EDF Jet. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 28, 2007 Share Posted August 28, 2007 Just 'cos you can afford your top of the range 2.4 stuff (as you call it )don't knock us folks on small incomes for what we can actually afford EVEN if we'd all like the best gear available Now I'm back to being grumpy ---Happy now? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 28, 2007 Share Posted August 28, 2007 Myron. To whom is this addressed? I have NEVER called my spektrum system "top of the range" because it is not, it is merely classed ( and priced) as an entry level set. I thought you also had an entry level ( Futaba ) version of a 2.4Ghz set yourself..... ?? Who is it exactly that is "knocking folks on low incomes" ? As a pensioner myself, I can assure you that I certainly have to watch the pennies ( 'er indoors is like an eagle with what I spend , and being confined to her resting period has not changed that !!)There...now I am grumpy too Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 28, 2007 Author Share Posted August 28, 2007 The reason that I would not at the moment put a lipo pack in a Tx is that out of the eight or so that I have bought, two have suffered from cell swelling, despite being very carefully used well within their C rating along with lipo guards and balancers. Don`t mind that happening on the bench but not in my tranny! These were what is considered top of the range packs too. Anyone know where I can buy single cells to repair the packs since I too am on a budget and cannot keep going out and spending 25 to 100 quid each time one requires replacing. Martin Mc. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 28, 2007 Share Posted August 28, 2007 Hi Martin.... fair enough, you have been a little unlucky though. I frequently remove the back cover to just have a good "looksee", and ALWAYS remove any LiPo pack from my planes before charging...as I shall do when the time arrives to charge the tr So far ( touches melamine covered wooden desk ) I have had more problem with dreaded black wire corrosion over the years, than LiPo swellings. Personally I worry more about the myriad of other things that can and DO go wrong with our equipment, than I ever do about LiPo swelling. As I say....never had a single prob to date ( firmly GRASPS desk with BOTH hands ) PS - I have purchased single cells from both Aurrora, and also the E/A Co.http://www.modellhaus.co.uk/acatalog/copy_of_Maverick_Power_Lithium_Polymer_Batteries.htmlThese are also good for smaller sizes...had a fair few from them http://www.indoorflyer.co.uk/index.asp?function=DISPLAYCAT&catid=44 HTH Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 28, 2007 Author Share Posted August 28, 2007 Thanks Timbo - don`t let go of that desk though. MM. Quote Link to comment Share on other sites More sharing options...
Tom Sharp Posted August 29, 2007 Share Posted August 29, 2007 Timbo, in the USA modellers have experienced fires in transmitters where they have not removed the lipo from the Tx to charge. Do you have any comments? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 29, 2007 Share Posted August 29, 2007 Yes. They are fools. Quote Link to comment Share on other sites More sharing options...
Jacques Posted December 4, 2007 Share Posted December 4, 2007 You might check out VApextech for Tx packs made with NiMHs at 2300 mAh. They seem good to me and give good service. J. Quote Link to comment Share on other sites More sharing options...
El CID Posted December 4, 2007 Share Posted December 4, 2007 Any suggestions where you can lipos for the Futaba 6EX 2.4, BRC dont have them and United Hobbies/Hobby City are not replying to emails.Lipo size required: 112mm long, 50nn wide and 15mm deep Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 4, 2007 Share Posted December 4, 2007 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 4, 2007 Author Share Posted December 4, 2007 Me too neither - would not use them in a tranny or non electric set up. Have had several fail so far but luckily not in the air. `Good` quality ones to boot, and looked after carefully. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 5, 2007 Share Posted December 5, 2007 Hmmm Say no more . Sorry Timbo but am not yet convinced I should not go any more advanced than Nimh's. {Xmas pressy I hope} Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 5, 2007 Share Posted December 5, 2007 El Cid - it's probably a size issue with that set as it uses a flat NiCad pack and Li-Po's are chunkier. I've used a Li-Po in my FF9 all summer without a problem. Quote Link to comment Share on other sites More sharing options...
Peter Burry Posted December 11, 2007 Share Posted December 11, 2007 Just a note to Eric Bray; actually some paints can and do self combust. Any paint using drying oils (such as linseed oil) will heat up during drying. The usual problem is of paint rags left in a heap; the rags act as insulation to stop heat escaping, the centre of the heap heats up; the hotter it gets the faster the chemical reaction until finally the heap bursts into flame. It's a well known phenomenon (though little to do with model aircraft). Quote Link to comment Share on other sites More sharing options...
