David Ashby - Moderator Posted July 18, 2007 Share Posted July 18, 2007 Hi KelvinThe BMFA have cleared 2.4 so you can use it anywhere. They recommend that you have a black pennant on the tx in the way in which 35mHz Tx's have an orange pennant.Thery also recommend (very sensibly in my opinion) that clubs operate a 2.4 frequency board alongside their 35mHz control board/system. The reason here is that many 2.4 flyers still fly 35mHz and they may put down a 2.4 transmitter and switch on the 35mHz Tx without getting a peg - their mind will still be in 2.4 mode! David. Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 18, 2007 Author Share Posted July 18, 2007 So there are no clubs out there that won't accept you using a 2.4Ghz Tx then?I really like the look of the new Futaba set. Select modes 1 to 4 and no crystals to worry about, etc Quote Link to comment Share on other sites More sharing options...
MARK EDWARDS Posted July 18, 2007 Share Posted July 18, 2007 Hi Greg,have alook at the Chriss Foss Uno WOT.It can be built as a 3 or 4 channel trainer.It will proberly take a couple of weeks to build if you are new to this hobby.Powered with a os 40 engine this is capable of performing loops,rolls inverted flight,outsideloops and spins.It has good handling and stabillity and good slow speed handling.Hope this is of some help Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 18, 2007 Author Share Posted July 18, 2007 Yes, I've seen that model Mark. It looks good for aerobatics, but am I right in thinking that the wing has no dihedral at all? I'd imagine with no dihedral it would be a rather tricky plane to control for a a novice? Quote Link to comment Share on other sites More sharing options...
Lord Lucan Posted July 18, 2007 Share Posted July 18, 2007 Hi Greg,The UNO WOT has foam wings, so you can build it with as much or as little dihedral as you want (With appropriate application of sanding block). It's a little smaller than the 40 sized trainers, and of course more expensive. The build is definitely more involved, but you will at least know how to fix it if (when?) you break it. Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 18, 2007 Author Share Posted July 18, 2007 Ah, o.k. I knew it had foam wings but didn't realise that you actually shape the wing dihedral yourself.I'm still thinking going for an ARTF such as the Boomerang or Tutor, and then having something such as the WOT for my second plane.For info, my aim is to eventually end up flying 3D aerobatic models - so I'm looking a progression path that will take me there! Quote Link to comment Share on other sites More sharing options...
Michael Hambleton Posted July 19, 2007 Share Posted July 19, 2007 Hi guys im new to R/C flight, but thought i'd add my two pennies worth if thats okay......I have or rather had an Arising Star with SC 46 engine and a futaba 6EX. First flight was fantastic, very easy to fly the build was straight forward and getting the C of G was simply a case of putting the wings in place and lifting it as per instructions (excellent for us novices). However as Shaun Chant rightly stated in his first reply It went nose first at full throttle into the ground :( the Engine is fine only had to replace one servo and crystals. Will post some pics when i get time the accident was not my fault however i did take it with good grace!!!! and have now ordered a new tiger trainer :) Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 19, 2007 Author Share Posted July 19, 2007 Any idea what went wrong Michael? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 19, 2007 Share Posted July 19, 2007 Greg Yes, there should be no reason why a UK club should stop you using 2.4.Good luckDavid. Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 19, 2007 Author Share Posted July 19, 2007 Cheers David.Right, I'm away out to buy my Tutor 40 aircraft. I've decided to go with it.Just buying the plane today. I'll be getting the engine and radio gear, etc online at a later date.Think I'll be plucking for the OS46LA engine unless anyone thinks otherwise?Also, the new Futaba 2.4Ghz radio set. Quote Link to comment Share on other sites More sharing options...
Michael Hambleton Posted July 19, 2007 Share Posted July 19, 2007 Apparently it was my fault for Freezing at the controls and not passing it back quick enough! :( Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted July 19, 2007 Share Posted July 19, 2007 Good to see you've gone with the tutor. Refering to your earlier comment, I put together a boomerang for a friend and the wings were not a very good fit and didn't stay in place. Had to disconnect the epoxy and re-glue it! Don't know whether it'll ever fly, he doesn't seem to be bothered to finish it so I can't comment on the flying! Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 19, 2007 Author Share Posted July 19, 2007 Just bought my Tutor 40 airframe today. It looks great except for one thing. It looks like a small hole has been accidently punctured on the side of the fuselage at the rear - near the tailplane.I think the model shop probably only has one of these in stock. I'll call them tomorrow. Question is, if none are in stock, should I wait for them to order new stock in? Or can / should this small hole simply be patched? The hole is approx 1 inch long and 1/2 inch wide. The film and balsa panel have been punched through.What do you guys think I should do? Quote Link to comment Share on other sites More sharing options...
Tommeh Posted July 19, 2007 Share Posted July 19, 2007 I'd get a new one mate, no rush is there, and you have paid your money you deserve what you expected Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 19, 2007 Author Share Posted July 19, 2007 Yeah, I've been thinking about it since my earlier post and I'm def going to get a replacement :-) Quote Link to comment Share on other sites More sharing options...
Tommeh Posted July 19, 2007 Share Posted July 19, 2007 good luck, don't let them give you any hastle ;) Quote Link to comment Share on other sites More sharing options...
Aslan Posted July 20, 2007 Share Posted July 20, 2007 Just make sure the slot isn't for a pushrod, for the rudder or elevator.Check the manual first. Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 20, 2007 Author Share Posted July 20, 2007 It's not a slot though. It's clearly damage to the airframe. You can see the broken balsa and torn covering. Also, the cardboard in the box has the same hole punched through it. Quote Link to comment Share on other sites More sharing options...
Aslan Posted July 20, 2007 Share Posted July 20, 2007 Back with it so.Small tears and punctures like these do happen.It could be a small repair. We all have fixed them at one time or other, it's your call Greg.Good luck. Quote Link to comment Share on other sites More sharing options...
Dave M Posted July 20, 2007 Share Posted July 20, 2007 I'd take it back, it might not stay perfect, but you should start that way. Plenty of oppertunities to damage it yourself. For minor skin/covering repairs look at the advice in the new thread "Plane Repair Help PLEASE !!!It has good advice , (from the usual suspects).All the best,Dave Quote Link to comment Share on other sites More sharing options...
Greg Lloyd Posted July 20, 2007 Author Share Posted July 20, 2007 Well, I took it back today and now have a 100% perfecto Tutor 40 airframe. I wonder how long it'll stay like that? ;-)Anyway. Seems a quality piece of kit. Looking forward to building it up and getting my wings.Heading up to my local club soon for some introductions and hopefully a bit of training. Quote Link to comment Share on other sites More sharing options...
Peter Eve Posted August 28, 2007 Share Posted August 28, 2007 I'll be ineterested to see how you get on. I've made a Tutor 40 and flown it a couple of times with the help of an experienced flyer - but no buddy box - I just took over when it was in the air for the first time! I had only spent a few sessions with an electric Super Cub but they paid off. I feel that the 40 could be a bit slower for a trainer but I can handle it. I'm using 2.4 - my friend is really envious. The only problem I've had is that after only 4 or 5 landings the undercart is already doing the splits and they weren't heavy arrivals. Has anyone strengthened the legs? Quote Link to comment Share on other sites More sharing options...
Lord Lucan Posted August 30, 2007 Share Posted August 30, 2007 Hi Peter,It's the naff piano wire that most ARTF manufacturers use on their aircraft. My Tutor 40 did exactly the same thing - right up to the point that the noseleg bent through 90 degrees during a takeoff run.I converted mine to a taildragger - reinforce the floor in the area in front of the servo bay with a decent sheet of ply, and fit a "proper" undercarriage from a model shop. If you can get one made from two pieces of piano wire bent and soldered togather, all the better. Make sure the wheels are pretty much in line with the leading edge of the wing. Fit a tailskid (a semicircle of the same ply you used for reinforcing the floor would be good). Check the C of G os still in the right place and you're ready to fly again.Ground handling is a bit more tricky, but other than that you won't notice any difference. Quote Link to comment Share on other sites More sharing options...
Peter Eve Posted September 3, 2007 Share Posted September 3, 2007 That's an interesting thought, personally, having (years ago!) learned to fly a Tiger Moth, I prefer tail draggers. That was some achievement of yours to do that to the nose wheel, I assume it was on grass! So far mine is OK but if it does what yours did I shall follow your lead. What engine and prop did you use? I've got an Evolution 46 and a 10 X 7 prop and the throttle seems very low in cruise mode. Quote Link to comment Share on other sites More sharing options...
Lord Lucan Posted September 3, 2007 Share Posted September 3, 2007 It was indeed from grass - the nose leg had been pretty well weakened by repeatedly being bent on landing, and the rabbit hole I ran into whilst taking off didn't help.The engine was a OS 46la and the prop was a 10X6 graupner. Cruise was just under 1/2 throttle. Quote Link to comment Share on other sites More sharing options...
