Stephen Grigg Posted May 6, 2010 Share Posted May 6, 2010 With the difficulties at the field with horses,we cant fly alone as we keep having to shoo them away.With this in mind Ive sent off to Galaxy for a Fun Cub.Should be able to fly with the electric fence up and on Quote Link to comment Share on other sites More sharing options...
birdy Posted May 6, 2010 Share Posted May 6, 2010 I'll be watching; I quite fancy one. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 6, 2010 Author Share Posted May 6, 2010 Hi Birdy,Ive already had an Easystar,Twinstar,Easy Cub and Mentor,so this on is a natural progression.Ive ordered there Power Pack also,not sure if Ill bother with the glider towing bit though Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 8, 2010 Author Share Posted May 8, 2010 There is a delay because Galaxy hav run out of Power Packs Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 14, 2010 Author Share Posted May 14, 2010 The Fun Cub arrived from Galaxy today.Multiplex have run out of Power trains so Galaxy have supplied the following,A JP 650 O/R 1100(c35-201) motor with aJP40amp ESC and Overlander 200mph 11.iv 3s batteries,I say batteries because I bought 3.Theyrecomend a 12x6 prop,let the building begin.Our club is having an indoor meet next Thursday and Ive bought the Parkzone J3 Cub for that. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 15, 2010 Author Share Posted May 15, 2010 Ive checked it all out,same usual construction,same top quality.Looks smaller than th Mentor,apart from the wheels,looks ideal for the job.Ill start it tonight Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 16, 2010 Author Share Posted May 16, 2010 After a couple of repair jobs were completed I started the Fun Cub.Drama ,instead of having 2 left and 2 right wing nut halves,I had 3 of one and one of the other.Problem solved,I found a complete one removed from a previous Mpx Model,whoopee.I had soon completed the fuselage,secured the u/c and fitted the rudder,stabiliser and elevator.I then secured the wing rods and glued the wings together.Im about to do the aileron servos,and cut the ailerons free.Im going to fit flaps,an option also.Ive managed to find plenty of servos kicking around to use as well. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 16, 2010 Author Share Posted May 16, 2010 Ive done the ailerons and cut out the flaps,the hinges for the flaps are unusual,so ive left them to dry overnight Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 16, 2010 Author Share Posted May 16, 2010 Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 16, 2010 Author Share Posted May 16, 2010 As you can see,its coming along nicely,it has unusual aileron horns,and different flap hinges.The big wheels are BIG, Ive found no fault with the build so far.its all been the usual Mpx efficient build.Its the first time Ive managed to get the cowl clips to hold it on perfectly Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 17, 2010 Author Share Posted May 17, 2010 Fitted the flaps and tested them and the ailerons.As I suspected,you need areverse Y lead for the flaps,so Ill wait until that arrives bsfore I continue.Want to get the flaps right before I glue the servos in position Quote Link to comment Share on other sites More sharing options...
Klippy Posted May 18, 2010 Share Posted May 18, 2010 What sort of radio do you have Stephen, surely you can fit the servos to different channels and then reverse in the radio. The plus is that you can program some differential, I think you might need it.Edited By Tony Prince on 18/05/2010 06:58:46 Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted May 18, 2010 Share Posted May 18, 2010 Tony what does differential do on flaps? Quote Link to comment Share on other sites More sharing options...
Klippy Posted May 18, 2010 Share Posted May 18, 2010 Exactly right Bruce! Stephen was talking Ailerons, then switched to Flaps Duh, it was early in the morning though. Quote Link to comment Share on other sites More sharing options...
Pete B Posted May 18, 2010 Share Posted May 18, 2010 Stephen, I think Multiplex missed a trick here. I've just looked at the instruction manual and they have indeed cut the flap servo spaces so that they are laterally reversed, thus needing a Y lead or programming to set them up. It will be easier and quicker to just cut a new location next to one of the servo locations and mount the servo so that both are in the same sense laterally - saves a lot of messing about. Cut the hole so that the plane of servo rotation remains the same to line up with the flap horn.Pete Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 18, 2010 Author Share Posted May 18, 2010 I did consider this Pete,but went for the Y lead option.Ive the Futaba FG8,more than capable to carry out your suggestion Tony,but Im the weak link.Itll be enough for me to figure out how to programme the switch to the flap channel.I fitted the Power train this evening and Sat confused as the ESC played copius tunes at me.As I couldnt find any instructions I moved the throttle and all went deathly quiet.I then found I had movement except for the throttle.I discovered that needed reversing .Seeing one of the tips on electrics I had not fitted the prop so all was well.AtA safe distance I checked the prop direction and watched as the model sailed backwards across the floor.Swopped 2 motor wires and all was fine.I then tested the motor,and all I can comment is there is bags of power and it is very responsive.Its coming along very satifactorily. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 18, 2010 Share Posted May 18, 2010 MPX probably designed the plane to work with their entry radio set which has very good 4 servo wing programming, but then again your FG8 should be more than capable. Be worthwhile checking out, you could then mix flaps in with ailerons (faster roll rate) or have crow braking for steeper landing approaches. But probably more importantly you will be able to program the flap positions separately so you can get them moving the same without messing with the mechanical linkages too much. Be brave ditch the Y lead, put a post on the Futaba section I'm sure somebody will be able to help. As regards the ESC, yep Futaba throttle direction is the reverse of JR/Spektrum and MPX. Quote Link to comment Share on other sites More sharing options...
Klippy Posted May 19, 2010 Share Posted May 19, 2010 Stephen, I'm a bit concerned about this 'Y' lead, in my experience a 'Y' lead will parallel the output from the radio to 2 servos, but the servos will still move in the same direction. If you want to reverse the sense of one of the servos you're going to have to use a reversing lead, it's a lead with a bit of electrickery in it to reverse the signal pulses so the servo moves in the opposite direction. Hope I've made sense and not misread the postings, again Quote Link to comment Share on other sites More sharing options...
Pete B Posted May 19, 2010 Share Posted May 19, 2010 Afraid you have, Tony - Stephen mentioned his need for a Y lead a while back With his 8FG, I'd do as Frank suggests, use the flap channel for one servo, a spare channel for the other and mix the two, which will give him the means to precisely adjust the flaps individually. Far better than using any sort of Y lead with the associated problems of setting up the flaps mechanically. Pete Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 19, 2010 Author Share Posted May 19, 2010 The way Mpx have there push rod connections and a diagram of where to put the servo arm at 70 degrees when the servo is centred I believe will make the setting up of the flaps quite easy.The reversible Y lead arrived today,and yas Tony you made perfect sense even though you were a little late.Galaxy feel the way Im doing it should be the safest nothing can go wrong,can it Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 19, 2010 Author Share Posted May 19, 2010 The Fun Cub is completed and ready for its maiden flight tomorrow.C of G is spot on with the battery at its most forward point maybe a little nose heavy,but if so easily altered by moving the battery back,plenty of room for this.Only problem is Its been a while since I charged Lipos and I cant find the charger lead.May be have to charge them at the field tomorrow Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 19, 2010 Author Share Posted May 19, 2010 Quote Link to comment Share on other sites More sharing options...
NigelH Posted May 20, 2010 Share Posted May 20, 2010 I've seen the vids. Looks good. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 20, 2010 Author Share Posted May 20, 2010 And I can report it is good.The power train gave unbelievable take off,around 15 min flights with a lot of gliding,didnt use the flaps yet..Vertical climbsand up very high in seconds,Acrobatic,flies upside down well,so much fun I kept running out of battery Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 21, 2010 Author Share Posted May 21, 2010 Had 3 good flights tonight,havent managed to get a landing I consider satisfactory yet,but did some touch and goes.which helped.There is a club competition ,you take off.climb for 30 seconds,power off and glide until you land.Longest flight wins.The Fun Cub climbs vertically so fast,Im fairly sure that if I climb for 30 seconds Ill have trouble seeing it.Im going to ask a club mate to time it to a comfortable height and see where that takes me and how long.After my last flight I horse watched for others, then these things passed over our strip,whilst takinf off and landing.I missed the best shots as usual Quote Link to comment Share on other sites More sharing options...
