Pix - E Major
Tim Hooper
I've been rather taken with the lines of the old Keil Kraft Pixie.
This little rubber-powered freeflighter boasted a huge 23" span, and looked like it should belong to the Auster family.
Anyway I thought it might be nice to re-draw the design at around 42" span, add a sprinkling of electric power, and a couple of advisory control surfaces for some calm-weather pootling.
So out came the crayons......
We're aiming for a pretty minimalist structure here - the fuselage will be made from 1/8 square stickery, whilst the wings are plug-in affairs.  All the flight loads (such as they are) will be taken by the underwing struts.
Anyway, here's a wing that I knitted myself;
I've jacked the tip up by 1Permagrit block to allow the fitment of the root rib.  At this scale this is so much better than messing about with one of those silly little gauge things.
The tail surfaces couldn't be any simpler - just 1/8 strip.
Here's the first fuselage side being framed up.
I'm aiming for an AUW of 17oz or so.
Power will come from a budget set-up;- bell motor, 15A ESC and 2S 1300 li-po pack, 9x6 prop.
tim
Edited By Tim Hooper on 01/06/2010 10:39:54
Edited By Tim Hooper on 01/06/2010 10:44:49
Posted by Bruce Richards - Moderator on 01/06/2010 12:08:07:
Looks sweet Tim. I bet it flies really slowly.
 I'll let you know Bruce - but I don't thinking we'll be breaking any speed records with this one!
A little more progress this morning.  F1 and F2 are universal to any aeromodeller!
Thank Phil!
For a colour scheme I'm envisaging a mixture of white Litespan, combined with silver and dark green Solite to give a civilian look.
I did contemplate camoflage briefly (think RAF Auster or Bird Dog), but it seemd too dour for such a pert little model!
The better half has already comped up a suitable logo for the wing anyway!
tim
I've just spent a happy couple of hours faffing about with the stringered rear deck.
I started out with the central stringer, and the sloping aft former, then added the smaller mid former, then crammed all the rest of the stringers into the little bit of space that was left!
tim
Thanks for the feedback gents!
It's always good to read the comments of other modellers - it's a real boost.
I've had a bit of a re-think about the front fuselage sides, and have added to their depth so as to match the outlines of the final cowl shape.  The problem is that I need to have the bottom of the cowl removable as a battery hatch, and this the easiest way of achieving that.
I also planked the top of the nose with 1/16 balsa strips.  I'll trim them to length later.
tim
Oh yes this is very nostalgic.....I did actually have a rubber powered Pixie when I was about 11 or 12 but if my memory serves me I overwound the motor (for a really long flight!!!) & it crushed the fuselage.......you'd be amazed how short a fuselage can get in this type of situation ....
Looks great Tim.......next months free plan perhaps
Hi steve , This has already been done as a free plan back in 1989 check out my hobby stores its on sale for ?5.97 this is the plan I got as a free plan it was done over two issues . Pixie 2.5 is 2.5 times larger than the original and power by a 2.5 diesel it was also done with the kind permission of Keil Kraft . Although it did not fly straight of the board it had to go through some modifications before it became a fine flyer for those lazy summer afternoons.
Edited By Stephen Jones on 10/06/2010 08:23:30
Hi Tim,
Despite its  size a diesel 2.5 or OS 15 fp is all that was needed and that was over Kill as only need 1/4 power to fly and the 4oz tank lasted for more than 1/2 an hour as it was quite happy gliding around . And as for the radio no need for ailerons  rudder elevator and throttle was perfect according to the builder . This is one i also built as a child and so when the plan came out i just had to have it . Funny thing is to this day i have never got round to building it , maybe some day soon   .
Posted by Stephen Jones on 12/06/2010 14:55:54:Funny thing is to this day i have never got round to building it , maybe some day soon   .
 Go for it, Stephen - it's just to pretty not to be built!
I've reached my favourite stage of any build; the bit where I get to pin/tape it all together and get to see what it'll look like as a finished model.  I'm not displeased!
The weight of this 42" model (including motor and prop) is currently less than 7oz.
What is very apparent though, is that it's quite nose-heavy as it stands, so my original plan of having the 2S cell-pack in the nose needs a serious rethink.  I'll probably end up putting the micro servos in the tail, and the battery behind the undercart.  No matter, it's all very do-able!
tim
Hi Tim,
Looks very nice , i see you have not built the tailplane to scale and the elevator is much reduced is size . This is one of the modification that had to be made in order for it to fly correctly . And with that low weight yours should also fly well .    I look forward to seeing the finished model along with a video    of it flying  .
Posted by Stephen Jones on 18/06/2010 21:24:31:....... and the elevator is much reduced is size .
 Stephen,
Well spotted!   The elevator is intended to operate in a purely advisory capacity.....
More progress today.  With the airframe sanded down, I thought it was time to make a start on the cabin glazing.
tim
Hi Tim,
As usual a very neat job of an interesting subject, I remember building the original. Have you considered cream and racing green for a scheme I tried it on the Quiver and found it quite pleasing.
Cream litespan, dark green Tamia acrylic, silver trim, Blue wonder 1300 Kv, on a 1500 2 cell lipo  7 x 4 wooden prop and pootles around on little more than quarter throttle for ages.
Chris.
It doesn't take long to cover a small model, does it?
  That kink in the lower edge of the rear window gave me food for thought for a couple of days as I pondered just how work a two-tone colour scheme around it.  In th end I opted to extend the line of the upper rear longeron forwards until it reached the rear of the cowl.
Whilst I was thus engaged, Netty set to with the PC and comped up a suitable logo for the wing, which was then printed onto clear adhesive film, sealed with spray varnish and then stuck in place.
tim
