Daniel Jehan Posted September 27, 2010 Share Posted September 27, 2010 Hi, I am building my first plane from plan - Tony Nijhuis dogfight double spitfire. I am looking fro suggestions to get the plan outline onto the wood for cutting. Regards Dan Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 27, 2010 Share Posted September 27, 2010 Daniel, I trace the parts from the plan onto card using carbon paper (yes you can still get it!!!) & then cut out card templates. I use these to draw around onto the wood with a soft pencil or Bic biro....doing it this way allows me to make use of the existing straight edges of the wood...if you lay the plan over & trace directly onto the wood its very hard to see exactly where you are in relation to the edge. I usually get the plan copied at Protaprint o avoid messing up the original & this can offer another alternative....place the plan over the wood & use a warn iron to "iron" the plan onto the wood (set the iron to "Wool" that should work) This will transfer an image onto the wood but can also warp your wood if you're not careful........the card templates work best for me!!! Quote Link to comment Share on other sites More sharing options...
kc Posted September 27, 2010 Share Posted September 27, 2010 I find the most accurate way is to trace the shape onto tracing paper ( greaseproof paper on a roll form Tesco, Boots etc ) using a straightedge where possible. Then the tracing is stuck to the wood using small pieces of double sided tape and then cut right through tracing paper into wood with the scalpel. Again use a straightedge if possible. On balsa the cut is made right through but on ply it is just scored. Then run a very sharp pencil around the score marks and cut using a saw or heavy duty knife for ply up to 1/16. If you can photocopy the plan then the photocopy is stuck on with doublesided tape and cut right through. The latest printer /scanner copiers seem to copy exactly to size and some can have the hinged lid removed to copy into the middle of a large plan. ( weight the plan down with books onto the glass )Edited By kc on 27/09/2010 16:23:20 Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted September 27, 2010 Share Posted September 27, 2010 Another quick method - for example to draw out balsa fuselage sides, is to cut out small squares in the plan at a few points on the outline. Lay the plan over the wood using the 'windows' you've just cut out to align a suitable straight edge of the plan with a straight edge on the balsa underneath. Pin through the rest of the outline into the balsa - You'll easily be able to see these pin marks to draw an outline. Check balsa sheet edges are true first - they're often not! This method obviously means making little holes in the plan, but it doesn't really spoil it. Edited By Richard Wood on 27/09/2010 16:50:37 Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted September 27, 2010 Share Posted September 27, 2010 Have a look at this blog - a bit further down. This is how the lazy Austrian guys do it. You need a scanner and an ink-jet printer as well as textile transfer sheets. You have to scan the plan - or a part of the plan - first and you have to be sure not to change scale. To do this draw a scale mark on the original plan - for instance a line showing exactly 10 cm. Make a second mark 90° to the first one. Make a test print after scanning on ordinary paper to see if both marks are still 10 cm. If yes follow the procedure as described. Don't forget to mirror immage the scan! Good luck! Quote Link to comment Share on other sites More sharing options...
GONZO Posted September 27, 2010 Share Posted September 27, 2010 Try this SITE for decal/transfers paper and iron on tranfer paper for scaning plan then print and transfer to wood. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted September 27, 2010 Share Posted September 27, 2010 Nice link Gonzo, have you or somebody ever tried the waterslide papers they are offering? If yes - any comments - experience? VA Quote Link to comment Share on other sites More sharing options...
twinstar Posted September 27, 2010 Share Posted September 27, 2010 instead of printing a copy of the the plan and ironing it onto the wood you can simply draw around the parts on the plan using a biro and tracing paper, then iron the back of the tracing paper on a mild heat, down onto the wood and the ink with transfer across.bad idea for very thin balsa though. heat will warp it. on some awkward shapes what ive done is to cut a template (tracing paper), making sure its accurate to the plan, then tacking it onto the balsa with tape / dabs of pritt stick, then marking dots about every 5mm around the edge of the tracing paper, the template is then removed and the dots joined up. you then cut outside of the line and offer it up to the plan, you can then trim the part accordingly with a david plane or sanding block until its just right.. its a bit of a faff but sometimes works well for me. just try different techniques and see which works for you, though as important as accurate parts is accuracy and straightness in the build much of which comes with experience / practice.. rulers wheever possible, use clamps so stuff doesnt move, use a flat building board that will allow pins into it. Make sure all parts that are the same on both sides of the plan are actually the same on both sides and not slighly different, (do this by holding both of them together to make sure, ligning up their flat edges against a flat surface usually exposes any ares aheres theres a difference between them) measure lots, use set squares wherever theres a 90 join (eg a rib to a spar) and when you do cut parts use a sharp scalpel. when cutting through the balsa make sure the blade is at 90 degrees to the flat surface of the balsa and not some other almost 90 degree angle as otherise one siude of the part may be a bit bigger or smaller than it should be. straight scalpel blades are for cutting curves, becuase they are narrower in depth and curved scalpels are for cutting strght edges. Always cut along a metal ruler where possible, rather than freehanding it... the list is endless. Quote Link to comment Share on other sites More sharing options...
GONZO Posted September 27, 2010 Share Posted September 27, 2010 VA, sorry I have no experience of the waterslide papers Quote Link to comment Share on other sites More sharing options...
Grahamd Posted September 28, 2010 Share Posted September 28, 2010 Simplest way ? nip into a haberdaheries (or hobbycraft) and get a dress makers pin wheel (used for marking out patterns onto material. Put wood under plan and trace using wheel (makes small pin holes in plan and wood, but is 100% easy and accurate). Quote Link to comment Share on other sites More sharing options...
sparks59 Posted September 28, 2010 Share Posted September 28, 2010 Posted by Grahamd on 28/09/2010 13:17:15: Simplest way ? nip into a haberdaheries (or hobbycraft) and get a dress makers pin wheel (used for marking out patterns onto material. Put wood under plan and trace using wheel (makes small pin holes in plan and wood, but is 100% easy and accurate). I like that idea! Must try it! Cheers Grahamd sparks Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted September 29, 2010 Share Posted September 29, 2010 I agree with Steve Hargreaves. It takes a little more time initially but you have a ready supply of templates if later repairs are needed, at which point you will save time. Paper often distorts when ironed. Quote Link to comment Share on other sites More sharing options...
Ady Hayward Posted February 19, 2011 Share Posted February 19, 2011 Hi, My preferred method is to trace the parts on to a sheet of A4 paper with a 2b pencil, then turn the sheet over on to the wood and trace again the outline on the reverse side. It leaves a pencil trace on the wood. Turn over the paper again and repeat. You get both sides to then leave traces on the wood. Ady Quote Link to comment Share on other sites More sharing options...
Martin Roberts Posted June 10, 2011 Share Posted June 10, 2011 Hi guys, I know this is a relatively old thread, have you thought about puting trace paper in you copiers/printers, I get an A0 trace print for a couple of dollars (AUD) at my plan printer (approx. 1 1/2 pounds UK), then you can keep the original safe and clean in the draw, you get to turn the trace over for the mirror image, then whatever you build it is exactly opposite hand, additionally any thing you have printed/copied etc can be instantly aligned on the timber without a need for holes/viewing ports etc..... hope this helps you all...we are used to looking at the bottom side of a plan down here in the land down under!!!!!!! Marty Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted April 18, 2012 Share Posted April 18, 2012 I just scan the plan in parts allowing an overlap then stick them together, cut out the bits you want then stick them down to the wood with PritStick, after cutting out the parts just moisten the paper and peel it off. If the part is long and thin then allow plenty of waste around the sides so the print doesnt distort as you paste it down,apply a thin even coat of PritStick to the wood not the paper,, if the paper bubbles or cockles then leave it as it will shrink out back to normal as it dries. I have been using this method for years, only waste is a bit of paper and ink, doesnt damage the plan and no real fiddly bits to handle. Edited By Terence Lynock on 18/04/2012 01:08:40 Quote Link to comment Share on other sites More sharing options...
Djay Posted April 18, 2012 Share Posted April 18, 2012 Seconded Terence's method. Just copy the part onto thick photocopy paper, cut out, stick to the wood or lay it on the wood and draw around it, and cut marginally oversize. remove the paper and check it aginst the plan and sand to correct size if required. Does not take to long, and you have the paper template for reusing part if required. Darryl Quote Link to comment Share on other sites More sharing options...
Roger Bird Posted April 18, 2012 Share Posted April 18, 2012 I use the same method as Terence and Djay to good effect. As well as using realy cheap glue sticks I use 'clear plastic tape' as well. This unsures a captive template whilst cutting and also gives the template a nice permanent plastic coating. (no streching or tearing). These templates can then be stored and be used again and again. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted April 18, 2012 Share Posted April 18, 2012 The wheel method is easier now HK have Mr Spike in stock. I add one to every order in case they become hard to get again. Mr Spike and carbon paper work well. Quote Link to comment Share on other sites More sharing options...
Miketgd Posted April 18, 2012 Share Posted April 18, 2012 You could always ask your father-in-law!, Quote Link to comment Share on other sites More sharing options...
John F Posted September 5, 2013 Share Posted September 5, 2013 If there is only one wing on the plans how can I get a reverse photocopy or ensure an easy way of transferring it? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 5, 2013 Share Posted September 5, 2013 Lots of possibilities here; the traditional one is to rub a little oil on the plan - it makes it "come out" on the otherside so you just turn the plan over and work on it. To be very traditional parafin was the prefered medium for doing this. The modern way is to have the plan scanned at a print shop - then get them to print out that bit - but backwards! Another way is to "pin-prick" the main points of interest through the plan - ie spar and rib locations etc - then again turn the plan over. There are probably others,... BEB Quote Link to comment Share on other sites More sharing options...
Mowerman Posted September 5, 2013 Share Posted September 5, 2013 Some print shops can print copies onto tracing paper. Edited By Mowerman on 05/09/2013 16:32:43 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 5, 2013 Share Posted September 5, 2013 Ah yes - I forgot that one - trace the plan then turn the tracing paper over,.... BEB Quote Link to comment Share on other sites More sharing options...
GrahamC Posted September 5, 2013 Share Posted September 5, 2013 For parts... 1] Copy relevant section of plan with printer/copier 2] Cut roughly around parts required 3] Sellotape parts to balsa. 4] cut through paper template and balsa in one go. Simple really! For the 'other' wing 1] Trace essential information on to a large piece of grease proof paper. [Rib positions, and spars... the work of 10 minutes] 2] Build one wing on the tracing. 3] Turn the tracing over and build the other wing on the other side, with confidence that it is an exact mirror copy. Edited By GrahamC on 05/09/2013 16:41:18 Quote Link to comment Share on other sites More sharing options...
