Andy Freeman Posted October 11, 2010 Share Posted October 11, 2010 As the titles say, before I grab the iron and start cutting can anyone point me in the right direction. Cheers, Andy Quote Link to comment Share on other sites More sharing options...
John Privett Posted October 11, 2010 Share Posted October 11, 2010 You want a lead to (for instance) run two servos from one receiver output? Just join the same colour wires to each other - simple as that. So all reds together, all blacks together and all whites together (assuming Futaba - or slight variations of colours for JR, Hitec etc.) Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted October 11, 2010 Share Posted October 11, 2010 By the way - I suppose it is clear - the servos will run in the same direction. If this gives you trouble and you need to reverse one of them look at this thread. VA Quote Link to comment Share on other sites More sharing options...
Plummet Posted October 11, 2010 Share Posted October 11, 2010 Posted by Vecchio Austriaco on 11/10/2010 16:08:04:By the way - I suppose it is clear - the servos will run in the same direction. If this gives you trouble and you need to reverse one of them look at this thread. VA But of course if you are using the Y lead for ailerons, one servo will be mounted as a mirror image of the other, so you WANT them to go in the same direction because the mirroring means that the actual push-pull directions will be opposite. (Did that make any sense?) Plummet Quote Link to comment Share on other sites More sharing options...
kc Posted October 11, 2010 Share Posted October 11, 2010 Why not buy one? Prices are so low it seems you could not buy the plugs & wire for much less! Check out Giant Cod etc etc Multiple packs seems even cheaper. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 11, 2010 Share Posted October 11, 2010 Posted by kc on 11/10/2010 17:25:45:Why not buy one? it's andy freeman we're talking about here...... ken anderson...ne..1.. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted October 11, 2010 Share Posted October 11, 2010 Hi Plummet, On the aileron I normally mix by using 2 channels of the radio. This gives you also the possibility to use differential or a flap mix. But think of a split elevator, if the servos are in the middle of the plane and you have long snakes or pushrods you can solve it mechanically, if the servos are close to the elevator you cannot. One servo needs to run reverse. You can buy an expensive Y cable which has electronics inside doing the reversing for you or you can use a standard Y cable and reverse the servo as described. If you have a computer radio with enough mixers and channels you can also use two channels. Owning some spectrum stuff I can explain it for a DX7 if somebody is interested. The DX6 cannot do it if you are also mixing the ailerons. Cheers VA Quote Link to comment Share on other sites More sharing options...
JohnnyB Posted October 11, 2010 Share Posted October 11, 2010 Hi Guy's On another thread I posed the question regarding the wiring/setup of the flaps on the Multiplex FunCub. One suggestion was in fact the reversing of one servo by changing the wiring as described by Vecchio. BUT, another suggestion was - use a reverse 'Y' lead. So my question is - what is a reverse 'Y' lead, and how would it be wired up to operate the FunCub flaps. I do have a computer radio - Futaba FF9 - which I have converted to 2.4Ghz using the Speccy plug in module and the AR500 Rx. John. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 11, 2010 Share Posted October 11, 2010 HERE Quote Link to comment Share on other sites More sharing options...
JohnnyB Posted October 11, 2010 Share Posted October 11, 2010 Thanks Timbo, that was a super quick response and greatly appreciated. I've never heard of reverse 'Y' leads and have even searched for them, without success, during the last couple of days. Cheers, John. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted October 12, 2010 Share Posted October 12, 2010 Posted by kc on 11/10/2010 17:25:45:Why not buy one? Prices are so low .......................................... Good point, apply that to models as well, RTF models are far cheaper than fully built up by the time you have considered the time involved. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted October 12, 2010 Share Posted October 12, 2010 Possibly for flaps, a better solution is this it is cheaper than the reversing y lead, and will slow them down as well. I have a few, and they work very well. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted October 12, 2010 Author Share Posted October 12, 2010 Thanks for all the input guys. I do want it to potentially run 2 aileron servos. Common sense seems to have deserted me when initially thinking about this. I forgot that the servos would be placed in mirror image and that would of course reverse the outputs. Silly me. Ken, yes I am too tight to buy one! but in my defence i have already cut the connectors off to feed the wires through the hole i had to cut in the wingribs.. Quote Link to comment Share on other sites More sharing options...
kc Posted October 12, 2010 Share Posted October 12, 2010 Well the reason I suggested to buy instead of make was for reliability! It is very difficult to solder these connectors etc and easy to make a weak joint ( mechanically weak or electrically poor ) if you are not experienced. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 12, 2010 Share Posted October 12, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
