Cant install Phoenix updates
r6dan
Dan there is a quirk with one of the later updates that needed the tx plugged in before starting phoenix. if that does not work go to the system tab on the toolbar and click the check for updates box that should "force it " to look for the new u/d's.
  • 2 months later...
Hi,
I have a Phoenix disk it,s version 5.01
I couldnt get the upgrades to "join " the phoenix programme,
ie .they downloaded and just sat there as programmes but made no difference to my sim when I ran it ,
I was advised to uninstall the phoenix 5.01 and reinstall it along with the upgrades in one operation ,
Now I cant even run the phoenix at all ,
I just get a message "Phoenix has encountered a problem and has to close now "
I dont know what to do next to get it up and running again
Any suggestions ?
Noel
Thanks for the suggestion Dave ,
My problem now is that Phoenix wont open at all !
Every time I try to open it ,I get a message saying
"Phoenix has encountered a problem and has to close "
If I try to down load from the Phoenix web site ,it wont recognise that I have a disk installed.
I,ve got the Phoenix Icon on screen but it wont open at all.
It wont proceed past that point and I have to close it ,
Are there any computer buffs or Simulator jockeys who can suggest a remedy ?
I,m REALLY MISSING my simulator fix
Noel
By the way r6dan, did you solve your problem with the downloads ?
Edited By Noel Eaton on 06/03/2011 11:06:32
Noel.
I take it you still have the disk itself...
You may need to remove the phoenix programme from your computer, Reboot and do a disk defragment and cleanup.
Then re-install Phoenix from your disk and when that has completed, go to the website downloads section and upgrade fully from there!!
That should get it running again
Sounds like something has had a conflict with the programme and by doing the above, it should clear up the issue and allow you to fly again!!
Let me know how it goes please.
Dave
You should find a "safe mode" exe in your Phoenix folder
Run this everything should be okay, you can then close it and run the normal version. Safe mode turns down all the graphics and other stuff this will allow it to save configuration as it closes ready to be read back in by the normal version.
If this doesn't work you will need to reinstall from your disk.
If anyone needs it, I have all the upgrades from 1.5 saved on my hard disk, happy to share if anyone is having problems downloading from the site. Do note you will need a legit initial installation for the updates to work.
Pm me your email address and I'll dropsend them to you
Hi again,
OK .. so I deleted ALL references to Phoenix in "my computer" "control panel" etc
and uninstalled,
Then ran disc clean, and defrag etc, This took ALL of Sunday evening !
Then reloaded disk and downloaded up grades to v3.0.mThis took nearly three hours last night !
I tried to open phoenix v3.0.m and....
Got message
" Phoenix has encountered a problem and has to close sorry for any inconvenience"
I could have cried !
What is wrong with the $%^&*() thing
rActive thanks for the offer but will it make a difference ?
As i seem to have downloaded all the upgrades ,
but it just wont open !
Noel
Edited By Noel Eaton on 08/03/2011 18:22:31
rActive
Thanks for your suggestion
How do I access "safe mode" ?
Phoenix wont let me in AT ALL,
I press to run Phoenix ,it goes to start up screen and then IMMEDIATELY says ;-
It will not respond to any requests or comands it will only. . . . CLOSE !
please advise how to try" safe mode"
Thanks Noel
I appologise ..
I just read that back and it sounds like I,m ...QUITE IRRITATED !
I suppose it,s because I AM QUITE IRRITATED !
But not at you
Thank you for trying to help,
I,think it,s time to call it a day for me ,, I,m off to bed ,before I chuck this ruddy thing out the window !
Noel
I've certainly been impressed with Phoenix support. I emailed them about a problem I had during the beta testing of an earlier version (probably 2.0) I sent the email at around midnight on a Friday and really didn't expect any response before Monday morning. 15 minutes or so later back came a response with the answer I needed.
