Alex Leigh Posted December 13, 2010 Share Posted December 13, 2010 To Deans preferred. But other options available. Can find extension cables but nothing that'll mate with my charger. Ta Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted December 13, 2010 Share Posted December 13, 2010 Why am I not allowed to view this file? Garry Quote Link to comment Share on other sites More sharing options...
DH 82A Posted December 13, 2010 Share Posted December 13, 2010 I am not allowed either. Garry are you using AOL like me? Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted December 13, 2010 Author Share Posted December 13, 2010 It's due to where it was hosted... sorry try this Std balancer but the plug is a 2 pin which isn't like anything I've seen before. I think this is the same: http://www.giantcod.co.uk/mini-jstxh-wire-extension-10cm-p-404516.html which would act as an extender, but that's not what I need. Edited By Alex Leigh on 13/12/2010 17:16:14 Quote Link to comment Share on other sites More sharing options...
Ultymate Posted December 13, 2010 Share Posted December 13, 2010 So cut it off and fit a Deans if as you say in your OP that is what you want Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 13, 2010 Share Posted December 13, 2010 That's either some mighty wiring or a very small LiPo... Why not whip the funny connector off and use your favourite plugs and sockets? Sorry Ulty - you beat me to it while I was typing! Edited By Martin Harris on 13/12/2010 17:18:18 Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted December 13, 2010 Author Share Posted December 13, 2010 Can't do that. Female end is attached to the ESC and it's integral! I suppose I could somehow extend the ESC side and then change both ends but there's not much room for anything bigger.Edited By Alex Leigh on 13/12/2010 17:19:37 Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted December 13, 2010 Share Posted December 13, 2010 Charge it through the balance connector, it is small, so the wires will take the load. Quote Link to comment Share on other sites More sharing options...
Kozmyk Posted December 13, 2010 Share Posted December 13, 2010 You could take one of those extension leads and put 4mm bullets OR 4mm banana plugs on the charger end. Or Deans of course. OR You could buy one of these Multi Charge Lead Edited By Kozmyk on 13/12/2010 17:55:27 Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted December 13, 2010 Author Share Posted December 13, 2010 Thanks all. One of those plans will work. Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted December 13, 2010 Share Posted December 13, 2010 Looks like it wasnt us Rex. Yes I am on AOL. I blame it for everthing but not that. Garry. Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted December 14, 2010 Author Share Posted December 14, 2010 Just for clarity, this is what I need to charge!Edited By Alex Leigh on 14/12/2010 09:53:53 Quote Link to comment Share on other sites More sharing options...
Pete B Posted December 14, 2010 Share Posted December 14, 2010 Posted by Steve W-O on 13/12/2010 17:28:12:Charge it through the balance connector, it is small, so the wires will take the load. As Steve says, can't see a problem with that, Alex, you don't need to connect the main leads on a battery of this size. It'll save a lot of messing about with the plug. Pete Quote Link to comment Share on other sites More sharing options...
Kozmyk Posted December 14, 2010 Share Posted December 14, 2010 Posted by Steve W-O on 13/12/2010 17:28:12:Charge it through the balance connector, it is small, so the wires will take the load. My charger reports a connection fault if I don't connect the main discharge leads; it's a LiPro Quad 6.I'd be interested to learn if there was a way around this. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted December 14, 2010 Share Posted December 14, 2010 Posted by Kozmyk on 14/12/2010 11:59:34: Posted by Steve W-O on 13/12/2010 17:28:12: Charge it through the balance connector, it is small, so the wires will take the load. My charger reports a connection fault if I don't connect the main discharge leads; it's a LiPro Quad 6. I'd be interested to learn if there was a way around this. Connect the main leads to the balance leads, the two end balance leads got to the main leads anyway. Just make sure you know which lead is which, or you might end up with some excess heat or flames. Quote Link to comment Share on other sites More sharing options...
Kozmyk Posted December 14, 2010 Share Posted December 14, 2010 Posted by Steve W-O on 14/12/2010 12:27:11: Connect the main leads to the balance leads, the two end balance leads got to the main leads anyway. Just make sure you know which lead is which, or you might end up with some excess heat or flames. I see you're logic there but that's just another way of adapting the main lead route as opposed to just using the balance leads on their own.It doesn't really matter to me as I make up the necessary adaptors as required. I was just curious to see if it could be done with my charger in case I encountered a battery with incompatible main connectors.. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted December 14, 2010 Share Posted December 14, 2010 Posted by Kozmyk on 14/12/2010 13:19:13: Posted by Steve W-O on 14/12/2010 12:27:11: Connect the main leads to the balance leads, the two end balance leads got to the main leads anyway. Just make sure you know which lead is which, or you might end up with some excess heat or flames. I see you're logic there but that's just another way of adapting the main lead route as opposed to just using the balance leads on their own. It doesn't really matter to me as I make up the necessary adaptors as required. I was just curious to see if it could be done with my charger in case I encountered a battery with incompatible main connectors.. Yes it is just another way to adapt the main lead, but my suggestion was in reply to the OP, and balance leads are easy to obtain, so he would not need to find a connector for his main leads. There are chargers that can charge through the balance lead. Again, by adapting an easy to get balance connector, you can charge a battery with "incompatible" main connectors. Quote Link to comment Share on other sites More sharing options...
