Tim Hooper Posted December 27, 2010 Share Posted December 27, 2010 This is one that's been kicking around my head for while now. In fact I started drawing up the plans a couple of years ago, but other models and domestic circumstances took preference. And then I mislaid the plans themselves for several months.......... Anyway, Wiki gives us a bit of history; "In 1924, the Royal Aero Club organized a Light Aircraft Competition. £3000 was offered in prizes. An entry was made by Hawker Aircraft, which was a design by Sydney Camm, the Cygnet. Camm had joined Hawker the previous year. Two aircraft were built (G-EBMB and G-EBJH) and were entered in the competition, held in 1924 at Lympne Aerodrome, by T. O. M. Sopwith and Fred Sigrist. The aircraft were flown by Longton and Raynham and came in 4th and 3rd places respectively. In 1925, G-EBMB was entered again in the 100 mi (161 km) International Handicap Race, this time flown by George Bulman, who won at a speed of 75.6 mph (121.7 km/h). At the same meeting, the Cygnet came 2nd in the 50 mi (80 km) Light Aeroplane Race. In 1926, both aircraft were entered in the competition piloted by Bulman and Flying Officer Ragg, taking first and second place respectively. Design The aircraft were of wood and fabric construction, the fuselage being four longerons strutted in the fashion of a Warren girder. The wing was two box spars with Warren truss ribs. Initially the two aircraft were powered one by an Anzani and the other by an ABC Scorpion (both opposed twin cylinder engines). In 1926 the engines in both Cygnets were changed to Bristol Cherub III another two-cylinder engine. The airframe weighed a remarkably low 270 lb, and its weight when empty was only 373 lb. History G-EBMB was kept by Hawker in storage until 1946, when it was refurbished and reassembled at Hawker's Langley Aerodrome. It was later transferred to their new facility at Dunsfold, where it stayed, coming out for various displays and airshows, until 1972, when it was transferred to the Royal Air Force Museum at Hendon.[1] More recently it has been transferred to its site at RAF Cosford in Shropshire, where it can now be seen.[2] An airworthy replica is on display at the Shuttleworth Collection, Old Warden, Bedfordshire.[3] Specifications General characteristics Crew: TwoLength: 20 ft 5 in (6.22 m)Wingspan: 28 ft 0 in (8.52 m)Height: 5 ft 10 in (1.78 m)Wing area: 165 ft² (15.3 m² Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 27, 2010 Author Share Posted December 27, 2010 So here we have a very minimalist 2 seater bipe of around 28 feet span, so a 1/5 model should come out at 67" span. I reckon an AUW of around 8lb, with 800 watts up front should be more than adequate. Interestingly, even though there were only 2 Cygnet built by Hawker, there are at least three in existance today! One of the originals is on static display at the Cosford Air Museum, whilst there are at least two full-scale replicas based at the Shuttleworth collection. Speaking of the Cosford Cygnet, I was able to obtain permission a couple of years ago to climb over the barriers and to get some detailed shots of the aeroplane, and I've saved these pics to a gallery on this very website! http://www.modelflying.co.uk/albums/member_album.asp?a=13801 Now I'm not proposing to build a 100% scale masterpiece; rather this will be usual 'that looks about right-ish' sort of cartoon scale model, and I'll be fiddling the dimensions as I see fit, starting with the wing section which I've altered from an under-cambered nightmare to a much more friendly ClarkeY 12% for ease of construction! tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 27, 2010 Author Share Posted December 27, 2010 I've also collected a few pics of the replica Cygnets on my visits to Old Warden, so here's a couple to give a taste of the aeroplane. ......and here's a couple of detail shots from the original aeroplane from Cosford; Edited By Tim Hooper on 27/12/2010 15:09:56 Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 27, 2010 Author Share Posted December 27, 2010 So here's the results of my frenzied scribling...... .....and today I actually started the construction of the curvy bits, ie, wing tips, tailplane and rudder. I've plumped to laminate these from pre-soaked balsa strip, wrapped around foamboard templates, and PVA'd together. Now it might have been easier to use segmented arcs of balsa sheet for this, but as the finished model is destined to be covered in 'linen' Solartex the structure will be fairly visible beneath, and I think it'll look better this way! An upper wing tip, half a tailplane and the all-flying rudder. Edited By Tim Hooper on 27/12/2010 15:18:01 Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 28, 2010 Author Share Posted December 28, 2010 I normally like to get the wings out of the way first, but as I'm low on balsa (and the local model shop is closed until tomorrow), I've started on the rudder instead! For anyone who's interested the routine goes like this; First I draw the final plan. This is eventually submitted for publication after all the endless amendments and captions have been added. Second, and to avoid marring the Final Plan with pin-pricks and gobs of glue/blood/sweat and tears, I make a quick tracing of the part in question, and actually build on the tracing itself. A sheet of white paper under under the tracing, and a layer of plastic film on top keeps it all legible. Given that there's no fixed fin on the Cygnet, I've made the all-flying rudder quite substantial, in that in the event of a nose-over, it'll have to take the brunt of the shock as the model somersaults. So we have a core of 1/4" balsa, with additional external stringers. All will be sanded to an aerofoil section later. Here's the full-sized version. tim Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted December 29, 2010 Share Posted December 29, 2010 Hi Tim nice to see the build has started. What is the thickness of the laminate balsa 2mm?? , looks solid to me why not using pieces of sheet. Is there no cad drawing to start with and do you send in the drawing made with pencil and RCME makes a cad drawing. Good luck with the build. Ton Quote Link to comment Share on other sites More sharing options...
Wolfie Posted January 3, 2011 Share Posted January 3, 2011 Another one! Does this man never sleep? When you say the balsa is pre-soaked, is this just water or some other chemical that softens the fibres? Quote Link to comment Share on other sites More sharing options...
kiwi g Posted January 3, 2011 Share Posted January 3, 2011 I really enjoy these threads of yours tim. keep up the great effort. Laminated curved balsa, now thats real building , Quote Link to comment Share on other sites More sharing options...
Mowerman Posted January 3, 2011 Share Posted January 3, 2011 I love the laminated balsa outlines, they look much better and are far stronger than the usual bits of sheet. May take a little longer due to having to cut out the former then wait for drying time but worth it in the end. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 3, 2011 Author Share Posted January 3, 2011 Happy New Year guys! The hols are almost over, and I've been able to snatch some more time on the Cyggie.... Ton, the balsa I use for the laminations is 1/16th inch sheet. That's 1.5mm to the rest of the world! Yes, I draw it all with a pencil, send it to RCM+E, and they scan it into a CAD program. Wolfie, the balsa is dipped into hot water for a few minutes. Simple as that. It becomes quite malleable as a result. Each lamination gets a squirt of PVA glue beofre being bent around the foamboard and left to dry for a day or two. Here's the rudder, now sanded to a rough aerofoil section. It's light, strong and rigid. The tailplane is basically the same. A /4 core, with 1/8 falsa ribs top and bottom. tim Quote Link to comment Share on other sites More sharing options...
Wolfie Posted January 4, 2011 Share Posted January 4, 2011 Posted by Tim Hooper on 03/01/2011 16:33:34: Wolfie, the balsa is dipped into hot water for a few minutes. Simple as that. It becomes quite malleable as a result. Thanks for the explanation Tim. I need to roll a new exhaust tube for a earlier model that has split. Sounds like this might be the way to go. .....off to put the kettle on.... It's details like the laminated curved edges that give models like this an air of authentic charm. I think I would be reluctant to cover it. Quote Link to comment Share on other sites More sharing options...
Terry Walters Posted January 4, 2011 Share Posted January 4, 2011 Great subject Tim - I remember hearing a lecture some years ago by Bob Millinship, one of the collection pilots at Shuttleworths, on flying the Cygnet. I recall him referring to the rate of climb after getting out of ground as a long term investment and he was very relieved to clear the boundary hedge! (No he is not a fat bloke!) Maybe a better wing loading? Lovely subject Best of luck TW Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 5, 2011 Author Share Posted January 5, 2011 Terry, Having seen the Shuttleworth replica perform very ably, I'm going to install enough umph to make some basic aerobatics part of its repertoire! Right, the purchase of some balsa means that I've been able to start on one of the wings - the upper left panel, to be precise. Having no sheeted areas (and therefore no D-box), I'm relying on a hefty full-depth spar to take most of the static loads (although flying wires will be added later), cut from 'weapons grade' 1/4 balsa. So. here's how it goes so far..... The tip, TE and lower capstrips get pinned to the board..... .....prior to the chunky mainspar. Note the 6mm CF joiner. The LE and rear spar (with aileron LE clamped alongside) follow suit. I've cut the templates for the ribs and riblets from 1/16 ply. tim Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 5, 2011 Share Posted January 5, 2011 You don't hang about do you Tim, lovely subject Cheers Danny Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted January 6, 2011 Share Posted January 6, 2011 Progressing very well Tim. A very interesting aeroplane almost made to be modelled. 'Weapons Grade Balsa' seems to be appearing quite often these days in a few too many kits! Cheers Richard Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 6, 2011 Author Share Posted January 6, 2011 Cheers lads! Just a quick post to show all those luvverley wing ribs...... Now I need to sort out the tapered tips, add the upper capstrips, shape the LE, then sort out the myriad riblets! Then there's just three more panels, and the upper centre-section to tackle..... tim Edited By Tim Hooper on 06/01/2011 15:40:28 Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 8, 2011 Author Share Posted January 8, 2011 I've been contacted by the owner/builder of the Cygnet replica G-EBJI, Colin Essex, with a link to his website that documents the 17-year build of this wonderful, scratchbuilt aeroplane. Turns out he's an aeromodeller too! https://sites.google.com/site/colinessex1/index tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 11, 2011 Author Share Posted January 11, 2011 I've spent the weekend building the second outboard panel, and then this morning I got them on the bench to help set up the centre-section. The carbon fibre rods plug into aluminium tubes..... The upper wing has no dihedral, and spans around 67". Coming next - The Joy of Riblets.....tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 12, 2011 Author Share Posted January 12, 2011 Another constructive morning! More structure added to the centre-section. Just needs the spars sanding to height before adding the capstrips and riblets. I'll work out the cabane mounts later on. Speaking of riblets - here's 60 of them.......... ......and here's some of them CA'd in place! tim Edited By Tim Hooper on 12/01/2011 13:29:04 Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted January 16, 2011 Share Posted January 16, 2011 Tim, Really nice work any more progress would love to see some more pics. Don't know if your doing it already but I normaly stick some sandpaper on the templates so it does not slide away from the wood when cutting the parts. Ton Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 16, 2011 Author Share Posted January 16, 2011 Posted by Ton van Munsteren on 16/01/2011 13:14:55:Don't know if your doing it already but I normaly stick some sandpaper on the templates so it does not slide away from the wood when cutting the parts. Ton What a good idea! I'll remember that for future use! OK, so there's more progress to report in that all the riblets are fitted to the upper wing, and the whole thing has been rough sanded. With the upper wing put to one side, it's time to make a start on the (much smaller) lower panels. So the plans were fettled a bit..... Where they really differ though, is that whereas the upper wing is flat without any dihedral, the lower panels sport 33mm of dihedral on each side. So what I did was to cut the spars out of hard 1/4 sheets, pair them together, jack up one end by 33m (using a scrap of balsa sheet, and use some steel blocks to mark where the carbon fibre joiners will go. That done, it's a simple matter to add the cf joiners with a dab of thick CA. I'll epoxy it all together later! Oops....almost forgot to mention that I've spent some time doing some online shopping, so the motor, ESC, cell pack and servos (6) should be on their way very soon! Not to mention re-organising Netty's garage.................. tim Edited By Tim Hooper on 16/01/2011 20:00:16 Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 21, 2011 Share Posted January 21, 2011 Very cool. I like your wing structure. It's the same as what I am contemplating for my 1/8 Scale BE2c. The only difference being thatI will be undercambering my wings. Glad to see wombody else doing the hard yards to prove the concept. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 21, 2011 Author Share Posted January 21, 2011 Thanks Hugh!I like the sound of your BE2c. What sort of span does 1/8 scale yield?I built the 36" Peter Rake version some years ago, and was delighted with it's performance.tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 22, 2011 Author Share Posted January 22, 2011 There didn't seem much point in giving a blow-by-blow account of the lower wings, as they're pretty similar to the top ones! Apart from size, the only area in which they differ is that they have a small amount of dihedral. Rather than mess about with those daft little gauges to tilt the root rib, I tend to jack up the tip to the required amount (33mm in this case), and then use a set-square to set the root rib. Works well! Some serious online shopping saw the next-day arrival of the main hardware.Rapid Models in Kent (my usual motor supplier) furnished the Turnigy 42-60 500Kv outrunner, 60A ESC and UBEC, whilst GiantCod delivered the 6 digital servos (4 standards, 2 minis) and the 5S 4000Mah cell pack. The 10 metre roll of linen Solartex was sourced locally. The motor will marry up to a 14 or 15 inch prop. Right then, back to installing the leading edge riblets in the lower panels.....tim Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 24, 2011 Share Posted January 24, 2011 Hi Tim, 55". Which is perfect to fit in the back of my car fully rigged. I love the BE2c. Probably my favourite aircraft of all time! Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
