Chris Channon Posted June 11, 2011 Share Posted June 11, 2011 Hi all, just wondered why some people use dope on top of solartex ? Is it just to fill the weave of the covering or does it help to shrink it ? Thanks in advance Chris. Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted June 11, 2011 Share Posted June 11, 2011 keeps the shrink, and stops the staining Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 11, 2011 Share Posted June 11, 2011 Hi Chris I presume its to stop it getting dirty .I can't think that it would shrink it anymore than heat does. Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted June 11, 2011 Share Posted June 11, 2011 It does indeed tighten the fabric a bit more than heat-shrinking. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 11, 2011 Share Posted June 11, 2011 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Snorbitz Posted June 11, 2011 Share Posted June 11, 2011 I've just finished covering a wing in solartex and non shrinking dope. Reason was simply to fill the weave ready for painting. It took 3 good coats of 50/50 mix dope/thinners to do it but the finish is like glass after rubbing down. Lots of hard work and a week to do but worrth it i'd say. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 11, 2011 Share Posted June 11, 2011 If you don't want the textured effect, you can always use Glosstex which duplicates a full size painted fabric pretty well.... Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted June 12, 2011 Share Posted June 12, 2011 I've found it difficult to get (homemade) transfers to adhere properly to uncoated Solatex. Also there is some paint creep under masking tape with the weave. I use Clearcoat to overcome these problems, the use of which is a pity when building vintage models as it reduces the vintage effect. If a model is large enough to carry the extra weight, Solartex or Glosstex adds a great deal of strength to the structure. Quote Link to comment Share on other sites More sharing options...
Ultymate Posted June 12, 2011 Share Posted June 12, 2011 Glosstex is a painted fabric and if you touch it with your iron you will mark the painted surface.Used it once on a Goldberg Ultimate, it's also quite heavy and expensive. Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted June 12, 2011 Share Posted June 12, 2011 You can always use a sock on the iron though. Glosstex is designed to be used with an iron so maybe you had a duff roll. Quote Link to comment Share on other sites More sharing options...
Ultymate Posted June 12, 2011 Share Posted June 12, 2011 Yes I know you can use a sock in fact it's virtually mandatory I was just pointing out that the surface will burn, personally I wouldn't use it again just for the weight and cost issues Profilm under it's many different trade names gives a far better gloss finish is less weighty and more durable. Edited By Ultymate on 12/06/2011 09:20:22 Quote Link to comment Share on other sites More sharing options...
Ernie Posted June 12, 2011 Share Posted June 12, 2011 Hi Chris, they SAY it helps to stop it sagging in hot weather ernie Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted June 12, 2011 Share Posted June 12, 2011 Better get some of that stuff for myself then Ernie. Quote Link to comment Share on other sites More sharing options...
Ernie Posted June 12, 2011 Share Posted June 12, 2011 Sorry Barrie, Cant guarantee that it works, but what does? Maybe we need another thread about that ernie Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted June 12, 2011 Share Posted June 12, 2011 Yes, I reckon you're right Ernie. What do they say? 'The only things guaranteed are death & taxes'. Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted June 12, 2011 Author Share Posted June 12, 2011 Brilliant, thanks all. I will get on and spray !!! Regards Chris. Quote Link to comment Share on other sites More sharing options...
