Prop Nut Posted January 6, 2012 Share Posted January 6, 2012 Needing some stick-on weights, recently, an internet search threw up some that are 4 x 5gms and 4 x 10gms on an adhesive backing, which most model retailers price at around £4 for three strips. Postage can be quite eye-watering as, by definition, weights are weighty! (A well-known online model shop charges £3.50 for 3-5 day delivery). However, I found an Ebay supplier marketing the identical item as motorcycle/car wheel weights (though he also includes model aircraft in the body of his listing) at £5.69 for ten strips, with free First Class postage, a saving of around two-thirds! I ordered one day and received them the next. His Ebay member ID is budgettyres, or you can search for 'stick on wheel weights'. Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted January 6, 2012 Share Posted January 6, 2012 Aha, could be handy, I'm after a church roof's worth. (no it's not me putting up the crime figures ) Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 6, 2012 Share Posted January 6, 2012 Or you could pop along to the local car tyre fitter because stick on weights are used to balance alloy car wheels,they range from 2g right up to in exess of 30g. Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 6, 2012 Share Posted January 6, 2012 i went to the local tyre place too, 50 strips for a tenner, mind you, i also had 300quids worth of tires!!! bit i have bought them before, he says he buys them by the pallet load Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 6, 2012 Share Posted January 6, 2012 Same here get them from tyre depots. Quote Link to comment Share on other sites More sharing options...
RichieW Posted January 6, 2012 Share Posted January 6, 2012 Or, go to a local double glazing fitter and get some lead flashin waste for free. Add a bit of cw and, voila. Ian if u need some still when ur around next, let me know I've got a fair bit . Rich Quote Link to comment Share on other sites More sharing options...
Phil May Posted January 6, 2012 Share Posted January 6, 2012 Tyre depot for me to. Slip a lad a couple of Her Majesty's finest and come away with a pocket full. I do tend to wick a bit of cyano as a back up to the adhesive tape, never had one fall off, yet. Phil Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted January 6, 2012 Share Posted January 6, 2012 As piece of mind I also drill through and then screw the weights onto my planes. I've had a few come loose before when just using the sticky backed foam, particulary if any fuel gets near the adhesive. Better safe than tail heavy and sorry mid flight. Quote Link to comment Share on other sites More sharing options...
Paul Adams Posted January 6, 2012 Share Posted January 6, 2012 I melt mine down into a circular mold (two bits of mdf which I clamped in a vice and drilled into along the joint line). Then with the same drill, I drill into the model (somewhere not structural), then a bit of epoxy, glue them in flush with the surface. A bit of trim then goes over the hole to hide the end. Quote Link to comment Share on other sites More sharing options...
Malcolm Fisher Posted January 6, 2012 Share Posted January 6, 2012 I've balanced many a glider by drilling into the nose block then melting enough lead to do the job and pouring it in at just above melting point. There's a bit of scorhing but the weight never comes out. Malcolm Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 6, 2012 Share Posted January 6, 2012 Good luck on melting modern wheel weights, most of them are steel these daysEdited By Bob Cotsford on 06/01/2012 21:01:21 Quote Link to comment Share on other sites More sharing options...
GrahamC Posted January 6, 2012 Share Posted January 6, 2012 If you need a lot of weight, say to balance a war bird check out diving weights on eBay.Funy how sometimes modelers can be helped by other hobbies. Now diving weights are heavy and are only any good for those who are looking for a lot of weight, but I have a club mate who needs about a kilo on the front of his fairly large hurricane, and I reckon a 1kg lead weight for about ?7 is one of the easiest ways of fixing that kind of mass at the front of a plane. A few chunky cable ties should fix it easily given the shape. Also real lead shot is surprisingly cheap when bought for diving purposes if you want to melt it to make your own shapes. It is odd that lead is readily available to divers but not modellers. I reckon that the reason that we are not allowed to buy real lead from the model suppliers has to do with model equipment being classed as toys by the powers that be. Either that or they reckon we can't be trusted not to put it in our mouths! Edited By GrahamC on 06/01/2012 23:20:00Edited By GrahamC on 06/01/2012 23:32:52 Quote Link to comment Share on other sites More sharing options...
PlaneMike Posted January 7, 2012 Share Posted January 7, 2012 Working repairing full-size propellers, we use 'lead wool' stuffed up the bore for balance.Not the most convenient for models, it needs to be compressed firmly or else little pieces drop keep coming off, however Occupational Health and Safety told us at work never to touch it with bare hands, and always wash-up after. Never had it in a model since andnow just use the steel stick-on weights mentioned. As for melting, the fumes are toxic too. Fishing sinkers come cheap in all sizes, and we used to play with them as kids! My liver probably needs all the help it can get. Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 7, 2012 Share Posted January 7, 2012 For those that want to melt a bit down budget brands of air rifle pellets are cheap and easily available on the high street.i've just weighed half a tin of .22 caliber and it's 10 oz,so for about 6 quid you should get about a pound of lead in small easy melted peices. Edited By Del Wheatley on 07/01/2012 01:57:51 Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted January 7, 2012 Share Posted January 7, 2012 Posted by Del Wheatley on 07/01/2012 01:30:28: For those that want to melt a bit down budget brands of air rifle pellets are cheap and easily available on the high street.i've just weighed half a tin of .22 caliber and it's 10 oz,so for about 6 quid you should get about a pound of lead in small easy melted peices. Edited By Del Wheatley on 07/01/2012 01:57:51 and if it doesn't work, you can always shoot yourself........................... I have a nice large stock of remeltable to any shape/size lead piping, from my house, removed 1981 and still plenty stashed away down the bottom of the garden! Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted January 7, 2012 Share Posted January 7, 2012 BTW, if filling a nose, much easier to make pellets by dropping into water (and safely keeping your distance of course), then using epoxy to hold in place. Just dug an old recently inherited gliders pelleted ballast out of a nose to motorise it, been there OK 40 years plus ....held in by plasticine!! Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted July 30, 2013 Share Posted July 30, 2013 Posted by Reno Racer on 06/01/2012 19:57:24: As piece of mind I also drill through and then screw the weights onto my planes. The reason being that in use they are secured by centrifugal force exerting on the weight, forcing it towards the inside of the wheel rim. A 30 gram weight held on by the flimsy tape supplied will give when subjected to a high G turn. They are fit for the intended purpose of use as wheel balance weights, but in time the elements will weaken the tape... Do you feel lucky... David Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted July 30, 2013 Share Posted July 30, 2013 i repair /weld alloy wheels on a regular basis them sticky weights do take some getting off , my grinder usaly does the trick though.... Quote Link to comment Share on other sites More sharing options...
Ade Eades (Eadsie) Posted August 6, 2013 Share Posted August 6, 2013 I use the balance weights you get when you buy a home ceiling fan, they are quite weighty and sticky-back, i have a few in my flight bag now (i'm an electrician so fit a few) they feel like lead. great for my small sokhoi bird. Quote Link to comment Share on other sites More sharing options...
