Mini Panic maiden
Phil May
Hi guys.
I carried out the maiden on my Mini Panic today and it did not go to plan.
It took off great, but it was' ballooning ' really bad and needed loads of down elevator to keep it level-ish.
Something is wrong for sure, it looked tail heavy to me ( c of g is 90 mm from leading edge on the top wing.
Any opinions on this guys.
Heres a quick video of the flight, not thee best quality I'm afraid..
Edited By David Ashby on 30/05/2012 18:36:38
Mine was pretty much the same. Flew around like one of those dogs dragging its back end along the groundwink. I stuck a heavy motor up front and that seemed to tame it a bit. I still needed quite a bit of down to get it level. They can come out quite tail heavy from what I've heard. I have not flown mine for while now. Think I'll get the lipos charged up for the weekendlaugh. Even tho mine is tail heavy I still enjoy flying it. It certainly keeps you on your toes and does some really silly manouvers!
Andy
Looking at the video, I suspect that the engine has to much up thrust, but its hard to tell without actually flying the model.
Reasoning:- When the engine revs are low / off the model appears to glide ok (can not see the transmitter sticks so hard to tell if you are holding down in, but suspect not). then when you power up the nose lifts.
If this is the case try adding down thrust (add a couple of washers behind the top engine mounts). What you should be aiming for is a level flight path with engine at low to medium throttle and then when you power up the model it should just increase speed (not nose up).
If it was a rear CofG you would have found that when you powered down the engine, and slowed it down it would come very unstable. With the glide you have that does not appear to be the case.
Hope this helps. Mine flies brilliantly.
Did I notice a that the top aileron was drooping during the very last few seconds of the vid? If your ailerons are all slightly lowered they will act as flaps & raise the nose.....they should be in line with a straight line through the centre of the ribs if you get me...
Other than that I'd go with Paul Adams & check the thrustline......a touch of down might help here....
Thanks guys.
I did think it maybe the ailerons giving lift, so I'll reset as Steve suggested. I was holding in down on the glide.
The motor is well under powered, as we discussed before, so I'm looking at a 300 Watt 1400 kv set up ( hope that will do) and BRC do a combo for about £30.00.
Thanks again
Phil
Edited By Big Phil on 31/05/2012 11:51:33
I think it will be enough Phil....all I was thinking is that if you have a 300watt motor & you decide you really need 350watts you might wish you'd gone for a bigger motor whereas if you have a 350watt motor & you're happy with 300watts then everything is just fine.....
I usually like to have a bit of "headroom" in my installations....in case I want more power & also to make sure everything is working well within its limits...
What watts/lb do you have at the moment? I know we discussed it but can't remember for the life of me what set up you had....embarrassed
Don't think a Panic will ever be "fast"....thick wing section & a draggy airframe will see to that....something like a 9x5 or 10x5 should be good on that motor....keep the diamter up & the pitch down for lots of thrust & a low top speed....thumbs up
Incidentally was the footage taken with the famous Big Phil Hard Hat Head Cam???teeth 2
Edited By Steve Hargreaves - Moderator on 31/05/2012 17:12:39
Steve,
at the moment a rather punny E Max BL 2215/25 with a 10 x 5 prop.
Regarding the 'Hat Cam'.No, it was done with a key fob camera on my cap..
I may be crazy,      face 20      but there is no way I'm wearing that in a public park, that is for the slopes where few people will see me and defiantly no one who knows me..........
Edited By Big Phil on 31/05/2012 18:00:16
Just ordered the 300 W set up, budget would not stretch to anything higher..........
I will probably regret it but it will be better than what is fitted at the moment.
I've reset the ailerons as mentioned above so I will try it again over the weekend to see if i need to build in down thrust when I fit the new motor.
Phil
Ailerons adjusted, slight down thrust added..........and..........300Watts...........smiley
Now we are talking, unlimited vertical and a fair turn of speed as a bonus.
I think there is a slight to much down thrust but nothing I can not sort out with a couple of thinner spacing washers..
I could not give it a proper thrashing because I was flying at a local park and there were a couple of dog walkers about , so that can wait for my visit to the club later in the week.
I am in the process of editing a short video, as soon as its done I'll post the link.
Phil
Edited By Big Phil on 04/06/2012 19:48:17
It's entirely Phil's fault. I didn't want to do it, but BP's video forced me.
After nicking the electronics out of my MiniPanic last month for the Dogfighter, I've gone and stuffed some MG90's in it. A 4 channel FrSky Rx was lying about doing nothing so it's been reassigned to active duty, and a 40A Mantis esc ordered.
Fluoro-Panic will fly again.
Edited By Bob Cotsford on 08/06/2012 10:39:00
Mine's getting a bit porky from the various repairs it's had, and I keep losing press-studs off the wing tips, but it's still good for a laugh. I did have to brace the tailpane and fin with carbon rod joining the tips as the balsa for the fin was a bit soft, other than that it bounces quite well when cuban eights round the rogby post cross bar go wrong.
