Tomtom39 Posted August 9, 2012 Share Posted August 9, 2012 Robin, I have sent you Pictures to your email address. Quote Link to comment Share on other sites More sharing options...
Francis Routley Posted August 19, 2012 Share Posted August 19, 2012 Message to Tomtom39 Hi, can you please send me some pics of your electric conversion. Regards Francis Quote Link to comment Share on other sites More sharing options...
Tomtom39 Posted August 20, 2012 Share Posted August 20, 2012 Hello Francis, Have sent you message. I'll need your email address to forward you pictures. (To access your messages look at your account/profile box top left - should show no. of messages received) Regards Quote Link to comment Share on other sites More sharing options...
geoff dales Posted August 20, 2012 Share Posted August 20, 2012 i ve just put one of these together with an sc46 fitted. As everyone else i had to add weight on the front even to acheive the most rearward c of g. Today i ve been playing with the c of g and got it back to 100mm which feels just about right. and improves handling no end. My nose weight is now down to about 5oz instead of the origonal 8 i had Quote Link to comment Share on other sites More sharing options...
The Stig Posted August 21, 2012 Share Posted August 21, 2012 Hi Geoff, how does it fly with the sc46? Is it adequately powered? Quote Link to comment Share on other sites More sharing options...
geoff dales Posted August 21, 2012 Share Posted August 21, 2012 its plenty of powerand very plesant to fly. slows up easily and lands easily Quote Link to comment Share on other sites More sharing options...
Mike B Posted August 21, 2012 Share Posted August 21, 2012 hi I have had my acrowot artf now for a couple of weeks. I bought it to convert to electric and it is my second plane the other being a trainer. I have been flying rc planes for about eight months so not yet very good. anyway back to the point, I have used a tornado thumper 3548/5 motor on a 4s 5000ma swinging an APCE 12X6 prop. (getting 770W at 50A motor doesn't get hot at all even though its pretty much maxed out) The battery tray, I have used a small strip of mdf mounted on blocks. this runs from the front bulkhead right through to the servo tray. I haven't made a hatch (don't want to weaken anything besides its only two screws holding the wing on) but I must find a way to isolate the battery without removing the wing, thinking of wiring a deans plug in series on the live side out through the side and another deans with the pins shorted on the outside. The Motor mount, I made a stand off bulkhead using 4mm threaded rod screwed into engine mount holes backed up by locking nuts into a piece of 15mm ply again backed up by more locking nuts, this makes it easy to adjust for length and thrust line. initial setup using vernier callipers equal lengths from engine wedge. Then just mounted the motor directly to ply and esc behind ply hanging off threaded rods with wire ties. (Had to use 200g stick on weights from my local tyre fitters which were stuck on to the ply bulkhead) I haven't made any other mods to the airframe from stock. i have some pics here **LINK** Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 22, 2012 Share Posted August 22, 2012 Hi all Thanks for your interesting comments. just binned a mustang and will be replacing it with an acrowot artf at the nats this weekend. I have a wot 4 now on floats which flies very well from water. This has a Super Tigre 61 ringed in it. Guess what the engine from the mustang is going in my acowot.... You guessed a super tiger 61. Should be good as due to it's weight I should only need 4oz of lead up front not the 8oz reported in the RCME review. We also have an acrowot just built from a kit bought some time ago ready for test flying. This has a LASER 75 in it. Should be interesting. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 22, 2012 Share Posted August 22, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tomtom39 Posted August 22, 2012 Share Posted August 22, 2012 Message for Mike Button - Excellent conversion and great pictures on your link. I have sent you a PM which you can access via box (your account) top left. All the best with it - mines going pretty strong especially as I have worked out how to reduce some of that extra weight up front (not much but every little counts!) Quote Link to comment Share on other sites More sharing options...
John Allen Posted August 23, 2012 Share Posted August 23, 2012 Is that a diesel engine? Quote Link to comment Share on other sites More sharing options...
NigelH Posted August 23, 2012 Share Posted August 23, 2012 I had to do a double take when I saw that. In fact, I did many 'takes' so I did a bit of research and reckon that it's a PAW 60 TBR-RC or similar. Quote Link to comment Share on other sites More sharing options...
NigelH Posted August 23, 2012 Share Posted August 23, 2012 BTW, it looks very futuristic. That's probably what they use to power alien flying saucers. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 23, 2012 Share Posted August 23, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted August 23, 2012 Share Posted August 23, 2012 A facinating choice of engine....be very interested to hear how it goes....fit a big prop won't you!!!!!Southern Modelcraft sell a diesel brew....no idea how much but a good bit cheaper than the Modeltechnics stuff (great fuel though that is....)....!!! Quote Link to comment Share on other sites More sharing options...
Robin Kearney Posted August 23, 2012 Share Posted August 23, 2012 Andrew, you have made my day. Seeing a 10cc PAW in an Acro Wot is just wonderful! Please do report back on performance. It might need a crankshaft though for optimum performance r. Edited By Robin Kearney on 23/08/2012 21:30:24 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 26, 2012 Share Posted August 26, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Gordon Bushell Posted August 26, 2012 Share Posted August 26, 2012 Here are some photos of my electric conversion, which I'm quite pleased with. Edited By Gordon Bushell on 26/08/2012 17:05:50 Quote Link to comment Share on other sites More sharing options...
John Allen Posted August 26, 2012 Share Posted August 26, 2012 Well I screwed up, and drilled the engine mount for 120mm from the firewall, rather than the back of the mount. Any opinions on what to do? Leave it Wait for new mount and drill the holes in the right place Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 28, 2012 Share Posted August 28, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
John Allen Posted August 28, 2012 Share Posted August 28, 2012 I was thinking of a 14x8 on my ASP FS91 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 28, 2012 Share Posted August 28, 2012 i use a 13x6 on my OS 91 4st...have done for a while now..... ken anderson ne..1 ... OS dept. Quote Link to comment Share on other sites More sharing options...
John Allen Posted August 29, 2012 Share Posted August 29, 2012 The reason I was going to go for the 14x8 was that in the RCM&E review they used a 13x8 on an ASP 70, and the engine sounded fab, and it was blasting around the sky. Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 29, 2012 Share Posted August 29, 2012 Hi all, Got my artf acrowot at the NATS on Saturday. Just unpacked it and am looking for the mounting points for the wing servos. This is not clear in the instructions. Even holding the wing up to a strong light is not much help. Anyone with advice? Dont want to start cutting covering in the wrong place. Have changed my mind about the engine. Not going to use the Saito 61. Weight would help but silencer is huge and ugly. Instead have purchased a Saiti 80. Thought of a Laser but they are too long to. Fit nicely. Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 29, 2012 Share Posted August 29, 2012 CORRECTION not Saito 61 should read Super Tigre 61.! Quote Link to comment Share on other sites More sharing options...
