Brian Clamp Posted August 29, 2012 Share Posted August 29, 2012 CORRECTION not Saito 61 should read Super Tigre 61.! Quote Link to comment Share on other sites More sharing options...
KingKade Posted August 29, 2012 Share Posted August 29, 2012 OHHH... I have an (original balsa kit) acrowot in my loft (unflown) with a satio FA80 ready for it on a 'parc amber' soft mount, i dont think they sell those anymore? Its had gunk on it for 20 years (the engine) so its getting a strip down and service shortly. Let me know how this handles, you'll be in the air before mine is sorted out!! SB Quote Link to comment Share on other sites More sharing options...
KingKade Posted August 29, 2012 Share Posted August 29, 2012 I have a feeling its going to be a (lovely sounding) rocket!!? Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 29, 2012 Share Posted August 29, 2012 Hi sammyboyy, Will be posting info and pics.. We also have a 'proper' model of the acrowot ready for testing. This has a Laser 75 in it. just need to locate mounting ponts for wing servos in the ARTF. Quote Link to comment Share on other sites More sharing options...
Gordon Bushell Posted August 29, 2012 Share Posted August 29, 2012 I located the servo cut outs on mine by feeling for a hole in the sheeting beneath the covering. Got them both right, but maybe I got lucky? Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 29, 2012 Share Posted August 29, 2012 located aieleron mounting points.firdt impression aws correct, just needed confirmation and encouragement.thanks.position can be found by holding wing up to a strong light. dissapointed in the size of the apperture. will have to fill and cover the gaps to prevent ingress of muck. I found it necessary to iron around the aperture prior to cutting the covering it was loose. have had to iron our some wrinkles as well. keep the covering iron at the ready during the build. I am fitting the servos and linkages priot to glueing the wing halves together. easier to play with smaller pieces in my shed.used 1.5mm ply spacers to centralise aielerons whilst glueing hinges. shall I continue as I progress or will it get too boring? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 29, 2012 Share Posted August 29, 2012 Saw one of these flying for the first time tonight - I see it still fishtails at high speed! BEB Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 30, 2012 Share Posted August 30, 2012 Thanks for that nice to know in advance. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 30, 2012 Share Posted August 30, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted August 30, 2012 Share Posted August 30, 2012 Maybe it depends what engine is up front, the one that you saw BEB, what did it have? CS Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted August 30, 2012 Share Posted August 30, 2012 Hi, has anyone tried it with flapperons. Am considering setting it up that way. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 30, 2012 Share Posted August 30, 2012 Posted by ConcordeSpeedbird on 30/08/2012 09:33:07: Maybe it depends what engine is up front, the one that you saw BEB, what did it have? CS Laser 70 I think CSB. Why fishtailing happens is a long story - I did cover it in an article in last years special edition of the mag if you have that handy. BEB Quote Link to comment Share on other sites More sharing options...
Briman Posted September 23, 2012 Share Posted September 23, 2012 Does anyone know the covering type on the Acro Wot ARTF so that I know what temperature to set my covering iron to get rid of the bubbles? thanks, Brian Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 23, 2012 Share Posted September 23, 2012 hello briman--it'll prob be a version of profilm.......set your iron to a mid setting and give it a go - or use a heat gun - or even her indoors hair dryer......one or the other will do the trick... ken anderson ne..1 .... hair dryer dept.... Quote Link to comment Share on other sites More sharing options...
Briman Posted September 23, 2012 Share Posted September 23, 2012 Thanks Ken. I'll check out the Profilm web site as I have just bought a fancy Prolux digital iron which displays the temperature so that - hopefully - I can set it just right. cheers, Brian Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted September 23, 2012 Share Posted September 23, 2012 Hi Briman, i hade problems with all the control surfaces having bubbles. I found that the same setting as for solarfilm worked perfectly. Do not use the heat gun it does not shrink the covering down to the surfce. Only use the iron. Mine flew for the first time yesterday perfect straight from the building board. Many thanks to Adrian a fellow club member for the maiden flight. At the moment getting 8 mins fromthe supplied tank using a Saito 82. Not fully run in yet though. Quote Link to comment Share on other sites More sharing options...
Briman Posted September 24, 2012 Share Posted September 24, 2012 Thanks Brian. I read through the Solartfilm info on the web and did some experimentation yesterday and starting at 100 C moved up to 140 C which worked fine on the bubbles. Not so good on the wrinkles though which my old iron produced. They may be beyond fixing, but I'll keep experimenting. cheers, Brian Quote Link to comment Share on other sites More sharing options...
LYKA Posted September 24, 2012 Share Posted September 24, 2012 Anyone know if the Laser 80 will fit in the ART Acro Wot I been told it will not fit in the cowl Quote Link to comment Share on other sites More sharing options...
Brian Clamp Posted September 25, 2012 Share Posted September 25, 2012 Hi chris, I looked at a laser and found the dim from the back to the prop driver was longer than the dim given for the engine position. Resorted to a Saito 82. Check the dimensions on the Laser web site. They are complete with pictures. Quote Link to comment Share on other sites More sharing options...
Eddie67 Posted September 27, 2012 Share Posted September 27, 2012 Hi folks, I'll shortly be putting together an artf Acrowot. Any opinions on the suitability of a Saito FA65 for this model? The recommended size for a four stroke is a .70 - .90, but I have the aforementioned Saito looking for a home. Any advice appreciated. Regards, Eddie. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted October 1, 2012 Share Posted October 1, 2012 Biggles' Big Bruvver - the foamy AcroWot will fish-tail too - at least mine does at speed. My initial thought was the carbon reinforcements in the fuse were partially masking the single 2.4 aerial. I moved the Rx and aerial but she still fish-tails --- at least I'll stop worrying now! Quote Link to comment Share on other sites More sharing options...
Greybeard Posted October 1, 2012 Share Posted October 1, 2012 Mine was less like a fish’s tail and more like a mole. Quote Link to comment Share on other sites More sharing options...
Briman Posted October 4, 2012 Share Posted October 4, 2012 Can anyone confirm how the closed loop rudder system should be arranged - parallel(ish) wires or crossed? The reason I ask is that a crossed system would have the wires directed at better angles and not bent round various internal formers etc as in a parallel arrangement. thanks, Brian Quote Link to comment Share on other sites More sharing options...
Robin Kearney Posted October 4, 2012 Share Posted October 4, 2012 Hi Brian, I crossed mine for the reason you state. It is working fine. r. Quote Link to comment Share on other sites More sharing options...
Briman Posted October 4, 2012 Share Posted October 4, 2012 Thanks Robin. I was leaning towards crossed but thought I'd ask the experts first. cheers, Brian Quote Link to comment Share on other sites More sharing options...
