Gyro Fitted To Plane Rudder - Any Difference!
A Heli pilot at my club recently took up FW and after passing his 'A' Cert. Then fitted a 3 axis gyro to his .55 OS powered ARTF Wot 4.
He flew it in a 20mph wind. Switching the gyro off and on the difference was really noticable. The Wotty bounced around in the changing air current regardless; But when the gyro was on, the flight lines were very smooth.
The other Heli guys said it was cheating dont know
BB
On my Baronette I have set it up for heading hold on a switch. With heading hold it will track straighter on take-off and landing, but obviously needs switching out once the wheels are off the ground. Even in rate mode it has a marked effect on normal flying, causing the tail to drag in turns as it tries to oppose the turn - you can see what happens in the video with opposite rudder coming in as the model turns.
I really should dig it out and try using rate instead of HH for ground movements.
The gyro will only keep the tail straight when there is no input to the rudder stick, using the throttle (assuming mode 2) will cause small movements naturally to the rudder anyhow so unless you do not touch the rudder / throttle at all would be best for test the gyro.
You don't have to turn it on and off, normal rudder operation should prevail if the pilot wanted to use the rudder. Using the ailerons only would cause some interaction as the rudder would be moved by the gyro so mixing would help.
Edited By Delta Whiskey on 08/10/2012 10:05:14
Hi all smiley thanks for all the comments so far as it gets the grey matter working - most comments mentioned here are correct from what I have observed however there is a side of this to consider some may miss. Any input you make on the Tx stick is directly proportional to the feedback you get back from your eyes.enlightened - So if the rudder "fights your turn" from the offset of your stick command you automatically feed in more Tx input to compensate for what your eyes see and your brain requires indecision... I hope that makes sense - Its just a bit more to think about. For my part I used to fly scale heli's and I always flew the tail because I never had a heading hold gyro - that's the reason I used a cheap gyro for this test - to keep it simple. The gyro was wired straight into the Rx and the other lead from the gyro went to the rudder servo - simpleteeth 2 - the gyro gain was set to "mid range". I have often looked at tail draggers and noted the awful problems on take-off and landings which often occur (mine were my main concern) - on take off a blade of grass holding back a wheel for a moment longer before the model rolls could cause the take off run to skew off course and go wrong - like the wing beat of a butterfly compounded up and ending up as a hurricane... Anyway enough from me and I look forward to making the next video and see how it works in fair winds - I will even try cross wind take offs / landings. thinking Regards Peter
Posted by Phill Emerson on 08/10/2012 10:33:03:
DW - thats kinda what I was thinking - would the gyro be tricked into thinking there was wind interferance from the turn due to the ailerons.
When using gyros on a heli for example it wont encounter this problem as wind/engine tork is the only thing it has to combat.
Cheers
P
Not true on a heli with a heading hold Gyro you have to co-ordinate aileron (bank) and rudder in a turn or the gyro will try and turn the tail (rudder) in the opposite diection and it will then just fly sideways into the ground.
With a rate gyro you can do aileron turns only on a heli as per fixed wing.
So if you are planning on using a heli gyro in a fixed wing then the following would apply
- Rate gyro, plane will track round on an aileron turn
- Heading Hold Gyro - needs co-ordinated aileron and rudder in a banked turn
Phill and DW are both correct. if you use aileron and elevator only for turns, the rudder will sense the change and keep trying to correct its path through the air. As you say, Peter, the more ail/ele you use, the more the rudder is corrected, thus exaggerating the tail-down attitude in the turn.
The only way to deal with this is to use rudder to balance the turn, either as a stick command or by coupling the aileron and rudder. I have CAR on a switch so I can use it when I'm feeling lazy......smile
There's plenty more discussion on the 3-axis gyros going on in threads here and here.
Pete
ps Just seen Frank's post, which, ignoring the HH aspect, seems to be the opposite of what I've said...disgust
I understand the flight path concept in the heli with rate mode but in the fixed-wing, the tail will tend to drop in an ail/ele turn. Let's consider a turn to the right. The gyro will sense the tail moving from left to right as it drops and will apply left rudder to correct the movement, thus increasing the downward movement of the tail.
This quite clearly happens with my 3-axis gyros in flight. An ail/ele turn exhibits a deep drop of the tail. If I co-ordinate the rudder with a right stick command (or with CAR) the tail balances out and follows the turn.
Having said, I'm aware of Frank's experience and I am hesitant about contradicting him! teeth 2
Edited By Pete B on 08/10/2012 11:34:44
Thanks for informing me of the other sitewink (see link from Pete B aboveyes) I had no idea this was going on. Its very interesting how sophisticated electronics are getting and the linked site shows this very clearly indeed however my approach was to "keep it very simple" and see the results which could be achieved with clear video coverage showing the results and with minimum cash outlay and effort. It is worth following the other site because this is truly "cutting edge" and mine is a bit "old hat" - I will still do the video and post it here to conclude the issue of this post for all who are interested. Regards Peter
Posted by Pete B on 08/10/2012 11:13:09:
Pete, I haven't tried any Gyros in my fixed wing so my experience with Gyros is all with helis. But a rate gyro just counteracts any uncommanded yaw, if the aircraft bank and turn are matched then the gyro shouldn't be seeing any uncommanded yaw so won't by trying to conteract this, but of course every plane is different so there maybe some unwanted effects.
A heading hold gyro though will try and hold the heading and will hence use the rudder to try and adjust the heading unless otherwise instructed.
The above has kindled my curiousity and I'm going to fit an old rate gyro into one of my planes just so I can check out the effects, I've also got one of the 3 axis stablisers winging its way to me at the moment.
Posted by Bob Cotsford on 08/10/2012 13:15:33:
Flying on HH was amusing to say the least.
You're not wrong, Bob! teeth 2
I'll continue to report my finding in the 3-axis thread, but my Eagle A3 Pro gyro gives both rate and HH options. The rate is fine but on HH, you've got to think about lots of things at once......smile o
Once you have everything set up correctly - and having the model perfectly trimmed is essential - it's interesting to set the model off on a heading with HH switched in, take your fingers off the sticks and just watch it make its way unerringly to where you pointed it!
I've seen videos of the shockie boys prop-standing with a HH setting but my models are not suitable for that - nor is my ability! The best I've achieved is to steer a course, pull in a bit of up elevator and then neutralise it. The model continues climbing, hands off - wondrous to see..........face 1
Pete
Posted by Frank Skilbeck on 08/10/2012 13:12:24:
I think I see what you mean, Frank. The two conditions that will affect this will be the amount of yaw induced by the turn and the amount of gain set. A constant rate turn should cause only a marginal reaction by the gyro, probably not enough to be noticed from the ground - and that reaction will depend on the amount of gain.
Peter,
I can only say that, in my experience, the 3-axis gyro hasn't made me a better flier but, when I want it for, say, scale-like flight, it has made the experience more enjoyable. I wouldn't be surprised if there is a club-size ARTF available with a 3-axis gyro in the near future (micro AX3 types excepted).
I don't think they are permitted for the BMFA tests - and rightly so! However, as you say, who's to know in the future?
Pete
So many questionsface 1 from so many but the answer for you is to try it and see cheeky - wont make you a better pilot sad but it could help you in some instances with some planes angel 2- Seen any heli pilots without a tail gyro of late? dont know Remember this project was started as a bit of "fun / interest" with the idea of keeping it very simple . smile p (No need to be a qualified electrician to wire it). nerd
This is the final video I promised you star which was made in winds from 10 to 16 MPH so have a look and see for yourself as the final choice has to yours and with your model.
So are you going to give it a trythumbs up thumbs down - let us all know...
Pete
Sorry, but ............... not my experience at all !!!! (40 plus years fixed wing, five years rotary and have four planes with 3 axis gyros, the first fitted several months ago and flown lots since, along with unfitted ones and switched in/out ones). This reads like you are locked into a corrupted form of heading hold!
I get no interaction of aileron/elevator into yaw with gyro that isn't there without, and even that is reduced ...................other than that, each axis gyro works as it should, for that surfaces effect alone, without unwanted interaction.
Something rotten in the state of Denmark, methinks.................... wink 2
BTW - they have markedly increased the usable wind range of every plane I have fitted them to, and make slope gliders much easier in bad rotor landing and launching zones. They do not take the skill out of it, they just widen the scope for lunacy!!!
Just to add remember you need to let a gyro initialise, a few seconds after power on is normally enough with no movement of the model or stick input - good luck all !
As part of my heli startup routine after initilising and before starting the engine, I always move the tail to ensure gyro is working correctly.
