Martin McIntosh Posted June 1, 2016 Share Posted June 1, 2016 Just downloaded a rather sketchy drawing for Tom Bretts 1962 Kenley winner Apogee. Anyone tried this and if so what motor? Quote Link to comment Share on other sites More sharing options...
Paul Jefferies Posted June 1, 2016 Share Posted June 1, 2016 I have not built an Apogee however I would guess that the original would have used a K&B Torpedo 45. I have found this pic of what I think is Brett's model and the motor does indeed look like a K&B 45....... However the prop is an 11x7 3/4 which I think would have been a bit too big for a .45...... Did K&B make a .60 back then? Quote Link to comment Share on other sites More sharing options...
Martyn K Posted June 2, 2016 Author Share Posted June 2, 2016 According to the GBRCAA (Photos not working though) Joint Winner and World Champion·- Tom Brett, U.S.A. Engine, K&B 45; Prop, Rev-Up 11 x 6; Model, Original "Perigee"; Span, 60 7/8"; Length, 50"; Weight, 84 ounces; Wing Area, 570 sq. in.; Wing Thickness, 15%; Radio, Orbit Superhet 10 Channel. Helen Brett cleans up model after its winning flight. Should be an interesting build Martyn Edited By Martyn K on 02/06/2016 07:48:07 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 2, 2016 Share Posted June 2, 2016 I got the two confused. Looks like the Apogee is a larger model for 60 size. Seem to remember tiny reproductions of the plans for each in one of the old A5 format mags. Saw those details of the Perigee which is what inspired me. Would probably go OK with an OS52 or West 36 maybe. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 3, 2016 Share Posted August 3, 2016 I decided to build the Perigee and it is now very near the covering stage. I found the build to be surprisingly difficult because the construction techniques are rather alien to me so the wing was built conventionally, mainly because I could not make out the 3/32 spar arrangement from the poor drawings. I have used a NACA 2 R 12 section modified to 14% which is as close as I could get to the original semi symmetrical one. Yes, I know that it did not have retracts but I could not resist fitting them. These along with the motor mount were a tight squeeze. It is pictured with the West 36 but provision has been made to fit an OS 52FS as an alternative. A YS 53 would also fit but this would be a bit OTT. I would expect the West to be OK if it is happy with a 11x6 prop. The weight is going to be way above the original 84oz because of all the beefing up. Some pics. in its raw state: Quote Link to comment Share on other sites More sharing options...
Martyn K Posted August 3, 2016 Author Share Posted August 3, 2016 Looks very nice Martin. Really nice swoopy back end Martyn Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 22, 2016 Share Posted August 22, 2016 The Perigee is now complete and awaiting its maiden. No particular attempt has been made to reproduce the original scheme since I don`t really know what it was like. Pleased that, despite the retracts and rather chunky fus. the weight is only 87oz, just 3oz above Bretts. Probably due to the lack of Bonner Duramites, reeds and relays. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 23, 2016 Share Posted August 23, 2016 Despite the wind blowing from a no fly zone at my field I took it up today, if only to check out the motor. I checked the incidence on a newly acquired meter and it looked like the wing was at minus 0.5 deg. but this was very dependent on the elevator trim setting. After much fiddling with the Taranis low throttle setting to get it correct I ran out of excuses and threw caution to the (strong) wind. No need to have worried, it flies with only minor trim changes. It flies with very much of the characteristics of a model of that vintage, the large amount of dihedral and the semi symmetrical wing section making themselves quite evident. It will probably need some aileron differential and various other tweaks no doubt but it is perfectly flyable. I need not have worried about the power since this is adequate, the motor now being very quiet on an 11x6 prop. That exhaust pipe position makes it a good muck spreader. Quote Link to comment Share on other sites More sharing options...
brian ball 1 Posted September 19, 2016 Share Posted September 19, 2016 Big thankyou to Martyn and Bill for a good days flying at Croft. Weather / BBQ good Lets have More Please. Brian Quote Link to comment Share on other sites More sharing options...
Charles Smitheman Posted September 20, 2016 Share Posted September 20, 2016 Martin, that is a really nice looking model. Well done, and glad to hear that it flies well. Charles Quote Link to comment Share on other sites More sharing options...
Djay Posted September 20, 2016 Share Posted September 20, 2016 my Super Kaos I have just built. powered by a SC91 2 st and is beautiful and smooth to fly as well as very fast. Darryl Edited By Djay on 20/09/2016 16:03:51 Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted September 20, 2016 Share Posted September 20, 2016 I must admit I am starting to take a liking to some of these classic aerobatic models. I guess that is another model for my build list Quote Link to comment Share on other sites More sharing options...
Djay Posted September 20, 2016 Share Posted September 20, 2016 another classic that unfortunately recently came to grief. Kwik Fly mk 2. until recently they were available here in Dubai as an ARTF. it was powered by a YS110 with a 15x10 prop and was the best flying aircraft I have ever owned. It would take off and do a half loop and go down the runway inverted about 10 ft of the ground then go vertical. it flew slow with the course pitch prop and would do every maneuver in the book at a low speed. It gave me the most confidence to fly and try new maneuver's than any other plane, until radio failure caused it to crash. Darryl Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted September 20, 2016 Share Posted September 20, 2016 Thanks Charles. The model has now had 8 or 9 flights and the only adjustments so far are some differential and a little weight in the left tip. It will actually do point and slow rolls quite well considering that it was never designed to do so. It certainly needs rather more fin/rudder area which I intend to add if I can remove the hinges without too much trouble because stall turns are very nearly impossible and it is a little unstable in turns. Quote Link to comment Share on other sites More sharing options...
Giuseppe Ghisleri Posted September 29, 2016 Share Posted September 29, 2016 Banshee. Flying in contest at Fiano Romano Quote Link to comment Share on other sites More sharing options...
TIM Shaw Posted October 7, 2016 Share Posted October 7, 2016 Hi Guys Just come across this group and blown away by some of the things on here. Recently re-discovered my love for this type of building and flying, so I wondered, can I play too. Tried to upload a pic of my recently built Mach 8, from Outerzone drawings, but although I thought I had managed to set up an album, it seems I still havw work to do... Tim Quote Link to comment Share on other sites More sharing options...
Pete B Posted October 7, 2016 Share Posted October 7, 2016 Hi Tim, Welcome to the forum! If it's any help, there is a guide to creating and uploading to an an album here; inserting pics from an album in a post is found here. Pete Quote Link to comment Share on other sites More sharing options...
TIM Shaw Posted October 8, 2016 Share Posted October 8, 2016 Thanks Pete Heres a couple of Pics of my scratchbuilt Mach 8, scaled down to 50" span so I could get in my MX5. Flew great with ancient Thunder Tiger PRO 36 Quote Link to comment Share on other sites More sharing options...
chris Bond - Bondaero Posted October 11, 2016 Share Posted October 11, 2016 Sadly not mine but managed to get a twiddle on the sticks of this at the weekend. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 11, 2016 Author Share Posted October 11, 2016 Is that a Taurus Chris? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted October 11, 2016 Share Posted October 11, 2016 Looks like one to me from what I remember. Seems to be the same as on the downloadable plan. Quote Link to comment Share on other sites More sharing options...
JOHN ADAMS Posted October 11, 2016 Share Posted October 11, 2016 Certainly is aTaurus, and in the original colours. What motor is powering it? Looks like a McCoy? Posted by chris Bond - Bondaero on 11/10/2016 15:03:04: Sadly not mine but managed to get a twiddle on the sticks of this at the weekend. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 11, 2016 Author Share Posted October 11, 2016 A cheeky reply - perhaps it was a McCoy once but now has an Outrunner as a prop shaft... I cant see a silencer Edited By Martyn K on 11/10/2016 16:40:54 Quote Link to comment Share on other sites More sharing options...
ron evans Posted October 11, 2016 Share Posted October 11, 2016 Posted by Martyn K on 11/10/2016 16:40:35: A cheeky reply - perhaps it was a McCoy once but now has an Outrunner as a prop shaft... I cant see a silencer Edited By Martyn K on 11/10/2016 16:40:54 Maybe not the real McCoy Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted October 11, 2016 Share Posted October 11, 2016 I have a kit of parts for a Tauros (updated structure but a Taurus outline) which I hope I'll get stuck into over the winter. I also have acquired a Veco 45 which I am reliably informed is not yet fully run in. I think the original engine used by Ed Kazmirski was a Veco 45. Quote Link to comment Share on other sites More sharing options...
