Tangental Posted February 7, 2013 Share Posted February 7, 2013 Hello chaps/chappesses, I'm refurbing my old IC stock and converting to leccy. I've actually had to scrap a few(most) as when stripping back the covering I noticed the wood beneath is thick with mould, but only where Pritt Stick was used to stick the plan copy to the balsa/ply. That's another issue but probably worth mentioning for anyone who uses this build method. My actual topic for discussion is, that on one model having cut away a mouldy old tail plane and fin I've rebuilt the very rear of the fuselage where they mount. It's a very slender fuselage with very little to mount to. I remember when building this one the trouble I had gaining a perfectly perpendicular tail plane. I'm toying with a 1/16" ply mounting plate recessed either into the fuselage or the tail plane and can't make up my mind which? Or is there anything to be gained? Tangey Quote Link to comment Share on other sites More sharing options...
Tangental Posted February 7, 2013 Author Share Posted February 7, 2013 It's OK! You can relax, phew! I went ahead and made a beautiful looking mounting plate and dang it looks perfick! Thank you for your kind consideration............blah blah etc. etc. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 8, 2013 Share Posted February 8, 2013 Phew! I'm glad you sorted that Tangental - I was all of a dither BEB Quote Link to comment Share on other sites More sharing options...
Bill Brown 3 Posted February 8, 2013 Share Posted February 8, 2013 Please can someone explain "tangental" and "pritt stick"?? I await your reply with anticipation. All the best, Bill Quote Link to comment Share on other sites More sharing options...
Tangental Posted February 8, 2013 Author Share Posted February 8, 2013 Hi Bill, Tangental is my nickname, it refers to my inane ability to go off at a tangent no matter the topic of conversation. I think it's called 'exploring all the issues' or 'thinking out of the box' these days Pritt Stick is a trade name for a glue stick normally used for sticking pieces of paper together. All the best Tangey Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 8, 2013 Share Posted February 8, 2013 Pritt Stick is used to stick pritts together ( they hold the cord wangles up), I thought everyone knew that Edited By cymaz on 08/02/2013 06:38:07 Quote Link to comment Share on other sites More sharing options...
Andy Green Posted February 8, 2013 Share Posted February 8, 2013 Its the non sticky sticky stuff. Andy Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 8, 2013 Share Posted February 8, 2013 I fit 1/8" sheet between the sides as a tailplane platform. Works well. Mind you, very slim fuselages are always a bit weak in that area. I use 3M Spray Mount to stick the bit of plan to the wood. Spray it on, leave for a few moments and you can peel the plan off the wood. Stick it down at once and it is bonded much more firmly. Expensive but better than Pritt Stick Quote Link to comment Share on other sites More sharing options...
