john stones 1 - Moderator Posted July 23, 2014 Share Posted July 23, 2014 Ooops been found out John Quote Link to comment Share on other sites More sharing options...
Ian Skeldon 1 Posted July 23, 2014 Share Posted July 23, 2014 Hi Gary, Great blog and great plane, shame about the quality of the kit ! I have read the blog twice now and I still can't see where you bought the undercarriage from, as I now need just such an item for a large model I own I wondered if you could shed some light? Many thanks and bounce free landings, Ian Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted July 23, 2014 Author Share Posted July 23, 2014 Hi Ian, I originally had a Carbon fibre undercarriage which was far too stiff so I gave up on it. I made a second one out of piano wire with some built in suspension. I have some pictures which I'll add on here. Elastic bands can be replaced to give the required suspension strength. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted July 24, 2014 Author Share Posted July 24, 2014 Hollow wall fittings used to make captive nuts. Can't use normal captive nuts because of the way the front end is fully boxed in, so I used these. **LINK** Trial fit of undercarriage plate made up from 3 layers of lite-ply. New undercarriage is interchangeable with the old Carbon fibre one. Finished with a bit of lite ply and colour coordinated covering. Quote Link to comment Share on other sites More sharing options...
Ian Skeldon 1 Posted July 24, 2014 Share Posted July 24, 2014 A very nice and clever solution, thanks for sharing that. Ian Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted August 28, 2014 Share Posted August 28, 2014 An update on my build, cooling slots for the ESC are now done, they will be fed from the vee slot in the firewall which in turn will be fed from the scoop on the cowl. It,s nice to start putting servos in ,etc. Should just about be done by the end of summer !! This should also flow air over the batteries. Keep the posts coming. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted August 28, 2014 Author Share Posted August 28, 2014 Looking good Dave. Make sure you put a good canopy latch on because you will get positive pressure it there. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 28, 2014 Share Posted August 28, 2014 Looking good Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted September 6, 2014 Share Posted September 6, 2014 Fuselage finished, Gary, thanks for the graphics, so far I've just printed them onto self-adhesive ink-jet gloss vinyl because I don't need them to be fuel-proof. The battery hatch is held down by two servo arms used as swing keepers at one end and a solid tab at the other. I have purchased some new (heavy duty) li-po's and done some more testing : - 21 x 8 falcon wood 12s - 4300w = 5.73 hp !!!! with a thrust of 28lb @ 7900rpm waaaay too much for what I need,but still impressive, still well under it's rated max.Intend propping down to about 4 - 4.5 hp for longer flight times. he he Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted September 6, 2014 Share Posted September 6, 2014 Gary, just a quickie, would you mind weighing your wing to give me an idea of flying weight. so far, fuse with everything in including batteries is 14 lb. Cheers mate. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted September 6, 2014 Author Share Posted September 6, 2014 I don't have any scales but I'll see what I can do with the kitchen scales when Mrs M isn't looking. Model is looking good. If that's a braced / unsprung undercarriage, you might find landing a bit tricky. I've not done a good landing yet! It wants to relaunch when rear end lowers and then the rear end wants to overtake the front end when power is reduced. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted September 6, 2014 Author Share Posted September 6, 2014 Borrowed the kitchen scales and weighed the wing - including 4 HD servos. It weighs - a bag of sugar and a medium sized lemon ! ...... or 2216g Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted September 6, 2014 Share Posted September 6, 2014 Thanks for that Gary, yes the undercart is braced but only the top third. I had them on another creation but they were too springy on their own. I'll see how they go ,if I need to I can take the brace off and try it without. That puts the all up weight under 20lb which is great !! Quote Link to comment Share on other sites More sharing options...
Peter Vestergaard Posted September 24, 2014 Share Posted September 24, 2014 Hi Gary Nice build and blog about it - just ordered my own kit, what are the flight weight of the plane and how long are the fuselage, can't seen to find any measurements other than the wingspan I'm putting a 53 ccm boxer gas engine in my version, and I'm also going dusty on the colorscheme Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 25, 2014 Share Posted September 25, 2014 Posted by Gary Manuel on 06/09/2014 12:47:15: Borrowed the kitchen scales and weighed the wing - including 4 HD servos. It weighs - a bag of sugar and a medium sized lemon ! ...... or 2216g Umm, that lemon may affect the c of g Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted November 1, 2014 Share Posted November 1, 2014 Hi gang, FINALLY finished, all up weight of 19.7 lb (but still needs lead to balance,I'm guessing about 0.5lb). Just awaiting it's maiden now,I'll let you know how I get on with the undercart Gary. Cheers all Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted November 9, 2014 Share Posted November 9, 2014 Maiden completed !!!! Took off straight and true, couple of clicks down to trim and that's all. HAPPY BUNNY . Gary, undercart fine, biggest problem I had was I slowed it down too much and nearly dumped it on the ground , but powered up to lift the nose and she came in ok. Must come in with a bit more power next time.although even at low speed she still remained responsive.AND I've got waaay too flap he he. Good luck to everyone. What about this farmhand get together ?? Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted June 9, 2015 Share Posted June 9, 2015 Hi all, Been flying "dusty" a bit now. I have propped down to a 20x8 falcon and the power is now 3250w @76A,which is still about 4.3 h.p.This is ample for vertical climb and massive loops. All I need to do now is drag a glider up and the job'll be a good-un. Anyone else flying there's yet ? I'll try and get some video to put on. Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted June 9, 2015 Share Posted June 9, 2015 Nice plane Dave and you flew it very well when I saw you the other day at the field, and it sounds just right. Edited By Mark Kettle 1 on 09/06/2015 10:20:20 Quote Link to comment Share on other sites More sharing options...
DAVE MATTHEWS 2 Posted June 9, 2015 Share Posted June 9, 2015 Cheers Mark, should be up there again tomorrow (weds 9th) . A bit more bonding Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted May 20, 2022 Author Share Posted May 20, 2022 Dusty is now up for sale. See HERE and HERE. Quote Link to comment Share on other sites More sharing options...
